Bloody washer dryer Hotpoint wd420p 606200214
Hallo,
My washer dryer doesnt seem to be getting hot anywhere(water/dryer) I have changed the Cable Thermal Cutout and the Thermostat but to no avail.
Is there a reset switch/button somewhere.hope you can help and thankyou for your co-operation.
Terry
  • 2 more comments
  • Horsemano1 Jan 22, 2008
    Its no getting heated at all,its me thats getting heated.
    Thanks for your help
    Help
  • Horsemano1 Jan 26, 2008
    I will check on those thing and let you know
    President:
  • 1,314 Answers
Most of the time this problem occurs its because of poor venting or blockage the vent should be 4inches not wound up like a snake and clear from the back of the drier to the out side if it droops down then comes back up water can fill it from the condensation of the clothes second cause of this problem is improper voltage don't assume that just because the dryer runs its getting full voltage driers will run on 110 but will not heat so check your out let for proper voltage loose wires etc third did you check the thermal over load there are three thermostat in a dryer thermostat safety thermostat and thermal over load the third is tiny looking thermostat with two wires or a tiny white banana looking piece usually on the body of the drier or on the vent tube somewhere
Posted on Jan 22, 2008
    Scholar:
  • 111 Answers
If It is covered by the 5 years parts warranty. You might just want give Hot Point a ring, if the Module has failed it is likely the motor or other component has caused it to fail, they don't usually go of their own accord. Can't suggest anything else at this time.
Hope this helps
    Guru:
  • 1,894 Answers
At what point is that getting heated up actually?
Aquarius 1200 washer/dryer WD62. Why isn't it washing/rinsing clothes properly?
If your washer /dryer is correctly connected to hot and cold water supplies, replacing the fill valve would be a good place to start.
Mar 26, 2016 | Hotpoint Washing Machines
I have a hoover hsw2125m washer dryer. the powder is not emptying from the drawer but i dont know how to check for blockages?
A lot of times the hose gets just clogged. What you do is get a tea pot, and boil some water. Then carefully pore some hot water slowly down the drawer, little by little until it breaks up the soap to unclog it. Another affective way is buy a can of air in a can. Compressed air in a can is used for many uses, such as cleaning a key board or lightly blowing out electronics, can get it at almost anywhere they sell computers. Then you do small burst of air in the detergent drawer. However I would try the hot water first, and save some hot water for a cup of tea as your patience of having it work. Thanks Mike
Apr 07, 2012 | Zanussi FLE1416W Front Load Washer
Aquarius WD420P has something stuck in its output hose
Here is a tip that I wrote that will help you with your dishwasher2_bing.gif not draining problem...
Dishwasher2_bing.gif Problems - Water will not drain out
http://www.fixya.com/support/r4078724-dishwasher_problems_water_will_not_drain
heatman101
Jun 04, 2010 | Hotpoint Ariston Aquarius WD420 Front Load...
Control panel lights ALL flashing on hotpoint aquarius washing ma
my lights are all flashing on my control panel, its takes water in then pumps out straighaway doesnt wash or spin i have changed the brushes so i know it isnt that please help it only about 3 years old
Dec 06, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
What kind of motor installed in hotpoint washer/dryer model No. WD420P
It is a brush type motor, rated at 1400rpm.
Runs on mains 240v
Trust this is the info you require.
If you need more info, e-mail me.
Thanks.
Dec 06, 2009 | Hotpoint Ariston Aquarius WD420 Front Load...
Hotpoint bwd129 washer dryer won't dry my clothes.
my Hotpoint dry will not dry my clothes. It will run for hours and the clothes still haven't dry just felt hot.
Oct 05, 2008 | Washing Machines
I have a hotpoint wd420p washer dryer and its stopped mid cycle. its full of water and i need to know whats wrong
To fix the problem I stripped down the pump and discovered it was jammed with a hair clip!!
Aug 02, 2008 | Hotpoint Washing Machines
Hotpoint WM64 doesnt seem to be taking in enough water
Close your faucet valve & unscrew your hoses to check screens on hoses & machine. Clean out well. Refit, check for leaks. Water shd be in good pressure. If this is not the problem change your inlet valve, it is easily done. Suggestion: use powders for front loaders.
May 08, 2008 | Hotpoint WMA32 Front Load Washer
Hotpoint Aquarius WMA 32
please check the outlet hose of the detergent drawer. it could be clogged with soap.
Feb 13, 2008 | Hotpoint WMA32 Front Load Washer
Hotpoint wd62 leaking from the drawer
Hi, check the electrict valve winding busted hot and cold.
Jan 27, 2008 | Hotpoint WD62 Front Load Washer / Dryer
Washing Machines Logo
70 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
