Question about Brother MFC3240 Multifunction InkJet Printer
Won't print right.
It sounds like bad when I try to print, like something is on the slide. It will only print certain things from the page, like the header. The quality is not very good either. It is hit and miss though, the last fax I received came out fine. I do use refill kits. Please help!
Thanks,
Lance
  • aldawaia Jul 13, 2008
    AFTER FEW DAYS FROM BUYING THIS PRINTER DO NOT PRINT RIGHT. KEEP ON CLEANING USING INK MANAGEMENT BUTTON TO NO SATISFACTORY PRINITING RESULTS. INK RUNS OUT TOO FAST. IT IS TOO COSTLY THE INK CARTRIDGES IN SAUDI ARABIA. ALMOST U.S. $19 PER LC47BK CARTRIGE AFTER DISCOUNT. IT SEEMS ONLY CHOICE IS TOO THROW IT IN TRASH
I have a problem with the printer and scaner
Posted on Apr 29, 2008
6ya staff
SOURCE:
My Toshiba Satellite P755-s5320 letters and number will not work. Even the number pad on the right side won't work, and yes the num lock is on. I'm thinking my cat may have pushed a button or...
Yes you are correct the print box is displayed when Ctrl + P are pressed. When the Ctrl button is held down one will not be able to type numbers at all.
I think your Ctrl button is stuck, try pressing it repeatedly to unstick it.
Worst case you will need a new keyboard.
Take care!
damnor01
Sep 11, 2012 | Computers & Internet
The black ink on my Brother DCP-130C won't print and it's a brand new ink cartridge. I thought it was a defected cartridge so I bought another one, same thing. The other 3 colours print ok though....
I have the same problem. Everything on the printer is working just fine. It'll do a test page just fine, so everything's working right. The %$^ thing just won't print. It makes noise like it's printing when you give it a print job, but it spits out blank pages.
Sep 08, 2011 | Brother DCP-130C InkJet Printer
My printer simply wont print, I just get blank pages even when printing the test page. I have tried cleaning, deep cleaning nozzle alignment, everything!
HI there,
It sounds like you've done everything right, and it still won't print. Your printer is dead - and you need a new one.
May 19, 2011 | Office Equipment & Supplies
My hp p3005 laserjet it's hanging
This is a common problem with that model. It generally means that there is something going on with the formatter assembly. The easiest thing to try first is to remove any cards from the EIO slots
The next few steps will narrow down if the formatter is bad or the print engine itself.
First remove the right cover by sliding it towards the rear of the printer
Then stick something "non metallic" in the hole indicated to press the engine test button. This will tell you if print engine is working (a good thing!)
If you get a page to print out, that means there is something wrong with the formatter and you should have a service technician replace it.
If you don't see a page, be sure you are pressing it in all the way and if there is still nothing, it's time to have a technician come take a look at it.
May 02, 2009 | HP LaserJet P3005n Printer
Only thing that prints is page after page of tiny words
Go to your printer, right click, choose properties or preferences, main tab, and restore defaults.
Advanced tab too.
(( tab at bottom restore defaults ))
click this, you will get standard A4 prints.
hope this helps
Regards.
Apr 16, 2009 | Office Equipment & Supplies
Paper problem/I missed something
Have you pulled out the catch tray located right beside the photo tray? If not slide it out and give it a try...
Dec 10, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
I am trying to print something from a web page on the internet and it will only print from the left to the right, leaving about 2 to 3 inches of info out. How do i get it to print the entire thing?
I would guess you are using Internet Explorer when you try to print this. Internet explorer has a bad habit of not printing the whole page. Go to a search engine and search for "Firefox". That is another browser and it will print the entire page when you use it to print out webpages.
Nov 10, 2008 | HP Office Equipment & Supplies
Printing in my e-mail message from someone it only prints half of it. Also it cuts of on the right side.
These are general things you should consider in a checklist fashion when trying to troubleshoot problems printing documents from certain applications. I have no specific information for your specific printer and the behavior you are observing.
Things to check to ensure proper printing:
1) Make sure that you have installed the LATEST driver software for your printer (you can get drivers online from the HP web site. Make sure it is working properly by printing a test page, if you have not done so yet.
2) Does your email software have a print preview? Make sure that the printer selected in your email software is the HP printer, then do the preview. How does it look? If you see your problem in the preview, then you need to do something in the software. Set the printing to be in default font style and size, as well as page margins.
3) When you print, does your printer report an error message that could indicate why it printed it only on the part of the text, and why it was cut-off on the right side. Check page orientation (portrait vs. landscape). In Windows systems, the print dialog windows also contain options for adjusting the page content to fit the page (auto-zooms, etc). Look at these options carefully.
If you have additional information to add after going through these checks, then do it.
Nov 08, 2008 | HP PSC 1210 All-In-One InkJet Printer
Nothing there
Did you try cleaning the print cartridge nozzles.
Press Function once and up arrow 2 times
Press the right arrow once and the up arrow once
Press Start/Memory button
It will print a test parttern page
Once you insert the new cartridge did the machine recognize the new cartridge? You had to press 1 for new
When 1 is selected you will get a prompt New Cart: OK?
OK press start.
If you selected NEW the display will show the alternating messages at right. Align Cartridge----1 Print 2 Set
Press 1 to print an alignment page
Hopefully, it will printed. Let me know one way or the other.
Mar 27, 2008 | Sharp INKJET FAX UX-A1000
CheckitRight
CheckitRight
James Cagle
James Cagle
Jim Keysor
