Question about Apple iPhone Smartphone
How to forward another wireless device to iPhone
I have a Verizon number that is being ported to a Nokia N95 device that I want to forward to my iPhone. Can you help?
    Problem Solver:
  • 8 Answers
The iphone can not be used on the verizon wireless network unless it is unlocked.
Posted on Jul 13, 2008
Get verizon lg voyager
Posted on Jan 22, 2008
I can't seem to remotely connect and view my lorex cameras. What am i doing wrong...it was working fine till I got Verizon FIOS
You may need to reopen the ports necessary for the Lorex to be available for remote viewing. You should be able to look at the function on the Lorex menu to get the port numbers, then call Verizon to have them forward the ports. Without port forwarding, your video stream is being blocked at the Verizon FIOS Modem.
Feb 01, 2013 | Lorex Home Security
Pls how can i flash my nokia N95
No matter what network your Nokia N95 phone currently runs on, you can unlock it---or "flash" it---to run on any GSM network. You will only be able to use your unlocked Nokia N95 phone on networks that use SIM cards---such as T-Mobile and AT&T---and not on CDMA networks such as Sprint and Verizon, which do not provide SIM cards.
Read more: How to Flash a Nokia N95
Unlocking the Handset
Remove the back cover and the battery from your cell phone. Locate a silver sticker with a bar code on it. Take note of the 15-digit IMEI number printed on it. At this time, also remove the SIM card and write down the numbers printed on the back of it. The SIM card is the small, white data chip in the silver cradle right next to the sticker. You will need these numbers to obtain your Nokia unlock code.
Request a Nokia N95 unlock code from your service provider. If they cannot provide you with an unlock code, you can buy one online.
Replace the SIM card, battery and cover. Fully charge your handset.
Turn on your handset and type "#PW+".
5
Enter the unlock code given from your phone company or website. Make sure you dial the number exactly as it was given to you. If you dial this number incorrectly three times, you will be permanently locked out of your handset.
6
Dial "+1#". At this point, the screen on your Nokia N95 should read "SIM Restriction Off."
Inserting SIM Card
Switch your handset off and remove the back cover and battery.
Remove the SIM card.
Insert the new SIM card into the SIM card slot. Now that the phone has been unlocked, this can be a SIM card from any U.S. service provider that uses SIM cards.
Replace the back cover and battery and switch the cell phone on. The screen should now read the name of the new service provider
Nov 30, 2011 | Nokia N95 Cellular Phone
How do I open ports 500, 4500, 53, and 52428 on Dell TrueMobile 2300 wireless router. Need to open them for Verizon Network Extender
1.Open the router interface by checking the default gateway
2.Under FIREWALL, you can find an option that would say "Virtual Servers"
3.Enable these ports, along with their types(TCP/UDP/Both) and assign an IP address that your Verizon Network Extender is going get( you to set that manually on the verizon device)
Save the changes and the ports will get forwarded!
**Note: In this case, DMZ under FIREWALL will NOT work!
Jan 18, 2010 | Dell Wireless 2350 Router
I want format my nokia N95 handphone. can u help me
Here are a couple of codes to soft/hard reset/format a Nokia N95 mobile device:
Soft reset code *#7370#
Hard reset code *#7780#
If the hard format code mentioned aboive does not work, try the following manual method to hard reset/format Nokia N95:
  • Turn off the mobile device.
  • Press and Hold the following three buttons: the Green Call Answer button, the * button, and the number 3 button.
  • While holding these buttons, turn on the phone and keep holding the keys untill the mobile phone restarts and prompts you to enter details.
Note: All the data will be lost including Phone Contacts, Apps,Games....SO DO BACKUP ALL BEFORE FORMATTING.
If I was helpful, Kindly do Rate!
Regards,
Waqar.
Sep 02, 2009 | Cell Phones
Venta:Apple Iphone 3g 16gb,Nokia N96 16gb,Samsung Omnia I900,Htc
FixYa is not a place for adds. Remove this add from the sight imediately.
Jan 14, 2009 | T-Mobile Wing™ Smartphone
Water damaged n95
try this :
This works on most mini electronic devices like cellular phones and degital cameras etc .
it sounds crazy .
Remove the back (or Cover ) of the phone( or Camera ), battery, and SIM if your phone ( or Device ) uses one , DIRECTLY
Then, with a q-tip (or something similar), dab the connection points (shiny, goldish) on the battery, SIM, and phone. This should aid in drying.
Finally, place all contents in a bag of uncooked rice (separately, do not put back together just yet). it sounds crazy , but it draws the moisture out.
It normally is working after just 7-8 hours, but I would wait 12 hours or even 24 hours before attempting to use (just to be sure).
beware the water damage, despite being dry now, will void any warranties. Also, the phone's hardware is now weakened and if you drop it, the green mother board and circuitry could shatter - so be more careful.
This does work on electronic devices aside from phones as well. Simply tailor it to your device. If you do not have a SIM (Verizon phones, cameras, all others), remove only the battery. If you have an iPhone/iPod or GPS and cannot remove the battery, simply make sure it is all the way off, then put it in the rice bag. All electronic devices react the same to the rice trick.
related link is here : http://www.youtube.com/watch?v=0-Otjgd48nY
rate if useful please !
Dec 29, 2008 | Nokia N95 Cellular Phone
Lincese key of smartmovie 3.41
guys here's your smart movie license
356406015251423
key: 10661
352061028048060
key: 35786
356996011925491
key: 42273
352913022128159
key: 22385
353954012048592
key: 62545
354835017716417
key: 36983
358064010816944
key: 23080
353094024317667
key: 24355
354829027127202.
key 10536
356406012565718
key: 44341
35336000229197
key: 29198
354813017111004
key: 30032
359362004494093
key:25795
Jul 17, 2008 | Nokia N95 Cellular Phone
The problem is in your connector where u connect the cable to your phone.
May 12, 2008 | Nokia N95 Cellular Phone
Nokia copy
ineed softwiar n95
Mar 26, 2008 | Nokia N95 Cellular Phone
Apple iPhone Smartphone Logo
194 people viewed this question
Top Apple Cell Phones Experts
David
Marvin
Marvin
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
