Question about Kenmore 24 in. 17262 Built-in Dishwasher
Door won't close
Hi, i have a kenmore elite 17262 and it has been fine till this morning. i loaded it as usual but the door won't latch shut. can you help me? i checked it and nothing is in the way. thank you.
I have the same dishwasher and the latch has never worked. Finally after 9 months and many service trips I went back to the store and they gave me a new dishwasher. Dealing with Sears has been a nightmare.
Posted on Mar 30, 2008
6ya staff
SOURCE:
F22 error persists on my washer, does the door gasket have to do with it?
F22 is usually a door latch error on Kenmore washers so you are working on the right area. The door gasket rip should not cause that unless it is stopping the door from closing all the way. It is usually the door latch itself which has switches built into it that causes that error or the main board is not reading the latch operation.
Mar 21, 2015 | Kenmore 4.7 cu. ft. High-Efficiency Top...
My dryer door won't stay shut while drying
Dryers have a Door latch that is female and the strike that is male. When the door is closed, the door latch hooks up to the strike and keep the door closed. PLEASE inspect these items. Also, make sure that the door is loose from the screws that hold it to the body.
Dec 03, 2014 | Kenmore HE4t 3.8 Cu. Ft. King Size...
I have a Kenmore Elite front loader model 42198900 , this morning shut the door ,light stayed on and no power to controls, any ideas
Did you ever get an answer to your issue? I am having the same problem. The light stays on when the door is closed and no power to the machine. I have unplugged it and done some other things to no avail. thanks
Jan 27, 2013 | Kenmore Elite 45986 Front Load Washer
Error Fdl on kenmore
This is a door latch problem. Check the door itself and make sure it is shutting all the way. Sometimes the hinges bend slightly or the door becomes loose which prevents the door latch from locking. If the door is OK I would recommend replacing the door latch.
Nov 01, 2012 | Kenmore Elite 45986 Front Load Washer
Kenmore front load washer door won't latch lock light on
On some Kenmore front load models, if the black gasket around the door opening is unseated (for example, because you drag some heavy wet laundry over it) the door will not engage the lock and stay closed. This is a feature to prevent the washer from leaking when the gasket is not sealed. To fix it, simply reseat the gasket and the door will close and lock.
Jun 21, 2012 | Kenmore 44102 Front Load Washer
Kenmore elite microwave 721.80833 stops cooking intermittently
Check the door switches if one is bad it may think the door is being opened and stop the unit from running. If it is from a bad connection it will get worse as it gets hotter while running.
Oct 04, 2017 | Kenmore 80809 Microwave Oven
Kenmore front loading washer
brand new and you changed the latch mech.? door latch or lock asm.? DU is door unlock error, it tried to unlock and cant. usually replace lock asm (inside machine) for this problem. may have latch out of alignment.
Dec 01, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore elite washer oasis he, mod 110.27062603
to andreya ,,, the code dl means door latch ,,,, you door latch is bad on your machine
to afinebalance ,,,, the f1 code is the control board and it too is going out and it isnt cheap ,,,,
if ya'll want to send me your complete model and serial numbers i will check on the parts for both or you.
Larry
Oct 25, 2008 | Kenmore 24032\24036 Top Load Washer
Door Lock Problem
with panel off reach up to lock location pull down on small tab door latch will click (at this point door would pop open if it were closed ) retry operation to see if ok if code dl reappear may to replace door lock if f11 may need new control module under top rear..ck wires first ..good luck
Sep 09, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite problem
1. Remove the lower panel under the door by loosening the three screws under the bottom edge on the front of the washer. HINT: If you prop up the front feet of the washer with some small blocks of wood, this will make access to the screws much easier.
2. With the screws removed, the lower panel should drop down then come off. If the panel sticks, a light tap on either side will knock it loose.
3. Reach your hand up inside the washer behind the front casing on the right-hand side. This is where the door latch assembly is located.
4. At the bottom of the door latch assembly is a small pull tab. This is the manual release for the door. Pull the tab straight down and the door will come open.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.%^@#
Apr 28, 2007 | Kenmore Elite 45986 Front Load Washer
Kenmore 24 in. 17262 Built-in Dishwasher Logo
619 people viewed this question
Top Kenmore Dishwashers Experts
vince
Israel Pineiro Jr
David Patricia James
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
