Question about ViewSonic VX924 19" LCD Monitor
Computer monitor I leave my computer on all the time and recently my monitor will not stay on. The power light is green (not orange for standby) but the screen is black. I can turn the monitor power on and off and it will come on for a brief second and then go black again. If I do this numerous times, it will eventually stay on. If I restart my computer it will sometimes stay on but not every time.
  • 286 Answers
This is a generic symptom that could happen to any LCD monitor.
The following is a generic answer applicable to most.
Two possible causes are bad capacitors or a bad light inside the LCD panel.
Open the unit and check to see if any of the capacitors in the power supply or other boards look domed or vented on the top.
Replace any capacitors accordingly. Use the same value capacitors. Most often, 1000uF 16V or 25V, 470uF at 16 or 25V, 220uF at 16V or 25V.
If this doesn’t solve the problem, try checking the surface-mount transistors on the inverter board that run the lights. Some times these transistors go bad. Check the area for any cracked or overheated ceramic or mylar capacitors.
Also, you may have a bad light inside the panel. This is tough to test without a spare light to use for troubleshooting.
You can take the panel apart and inspect the lamps but it is very tedious. It's tough enough to get them apart and back together again never mind keeping the layers clean. You have to try not to get any dust between the layers or you will see it in the picture.
There are usually two light fixtures each of which holds two lamps. One fixture is at the top and one at the bottom. Remove them one at a time and inspect the lamps to see if any are broken or very dark on the ends. If one looks out of place, it could be bad.
You'll have to find replacement lights on the net. It's not easy to replace them, but if you've gone this far, good luck. You should be able to get generic instructions off of the site that sells the lamps.
Posted on Feb 14, 2008
Blinking orange light
Is the Orange light the power indicator for this model or the standby (standby would be on all the time)
Dec 05, 2012 | BenQ FP553 (White) 15" LCD Monitor
Please can you help us. when we turn the computer on the monitor light stays blue with the screen remaining black, when we turn the tower off the light stays blue when it usually has the orange standby...
There is probably a conflicting setting in your power management options. My recommendation is that you check the monitor setting in Windows and see how you have it set up. In Windows it is under CONTROL PANEL>POWER OPTIONS. There are a few differences between WINDOWS 7 and XP from here on out, but in general, do not select a scheme and do not select any hibernate, standby, or sleep modes. If you stick with a simple power saving option, like "TURN OFF MONITOR: After 15 mins." you should not have any further problems.
Many of the Windows "green schemes" will not work right with different combinations of BIOS, Hard drive, motherboard, and monitor. It is best to avoid them, unless you are very patient and willing to go the trial and error route. Good Luck!
Mar 08, 2011 | ViewSonic VX2235WM Monitor
Monitor is only on standby mode and will only go to green when the cable is removed from the computer
Now that is just weird. The green light indicated it's getting a signal while the orange (standby) light indicates lack of signal.
Try a second monitor so see if it is working. If it is, the first monitor is bad and must either be repaired or replaced.
Mar 23, 2010 | Dell Computers & Internet
What does it mean when that blinking green light turns to orange one in lp 350?
Hi
This would be "Standby"
When you press standby, the display and audio turn off and a blank screen is displayed for 15 minutes.
You can change the amount of time the projector stays in standby mode; see “Standby Time” on page 27 for details.
The LED lights orange while the projector is in standby.
• If you press standby again within 15 minutes, the projector returns to normal operations immediately. The LED changes from orange to green.
• If you press standby again after 15 minutes, there is about a 60 second delay before the lamp turns back on. The LED flashes green while the lamp is re-lighting.
• If you don’t press standby again, the lamp turns off after 15 minutes. The LED lights orange while the projector is in standby.
The full manual can be found here:
Infocus customer support
Infocus LP350 Manual
I hope these help
Mike
Sep 18, 2009 | InFocus LP350 Multimedia Projector
Monitor comes up white on computer start up
see if you have bent pins on cable.
Aug 19, 2009 | X2Gen MW22U Monitor
MONITOR KEEPS SWITCHING TO STANDBY
Either the power supply is going bad (power light will be orange or off when it goes dark) or the screen itself has the problem (inverter?). If the power button stays green but the screen goes dark, that'll be the problem.
Jan 10, 2009 | Computers & Internet
Flat Panel Monitor goes off two seconds after turning on the computer. It will not stay on. System is about five years old. could the monitor be bad?
Have you moved it recently? The monitor has a sensor that tells when the computer is on. Some times the computer settings tell the system to go in to standby mode and this will remove the signal that tells your monitor to stay on. Check your computer to see if it's running. Usually a green or yellow light on the machine will blink. If everything is good, check the pins in the cable from the CPU to the monitor. Check both sides. If a pin is bent or bad. replace the cable. Trying to straighten it might break off in the plug. Also, the video part of your computer may be bad. Try the monitor on a diffrent computer to see if it powers up.
Sep 04, 2008 | Sony Computers & Internet
Monitor lives its own life ;) Turnes off and on in random moments
It sounds like there's a problem in the power supply or inverter section and it's just teetering on the edge of failure. The disruption of the signal is apparently just enough to kick it over the cliff until it's reset. Sooner or later, it'll need some help, like connections, capacitors, output transistors, capacitors, transformers. Those are the most common failures in these. I think you'll see it get worse
Jan 25, 2007 | Dell E173FP 17" LCD Monitor
Monitor switching to standby - CV735 monitor with Presario 5000 series desktop
my compaq crt monitor not showing color. its shows only blue, green colors . u please tell me. what is the problem in.how to solve it.
is the monitor fault or any other.
Oct 30, 2006 | Compaq CV735 17" CRT Monitor
ViewSonic VX924 19" LCD Monitor Logo
49 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
