All the dryer does is move air,if the steam can't move to the outside from a blockage of some sort your gonna find water droplets building up on and around the dryer,you need to clean out the dryer and this should be done every year so you don't have a fire also more so if it's gas with an open flame in the dryer,if you have a long vent line run from the wall to the outside use a leaf blower to clean out the line,first run the dryer and check outside to see if the flapper is blowing fully open,if there is a cage on the hood,throw it away,all it does is collect lint,if you want to keep it go out and clean it every month,if it's low to the ground this is used so no animals can crawl into the line,now unplug the dryer,take off the front panel and vac out the inside,then clean the duct that the lint filter slides into,ge drums ride on a rear bearing and the heater is on the back wall behind the drum,if you look inside you'll see holes in the back wall of drum,if you have a shop vac put it on blow and blow out the holes in the back of drum,alot of lint collects in there,hope this helps,you definetly have a block somewhere and the is is being restricted
