Question about Lucent Stinger FS+ Concentrator (300431905)
Stinger FS+ reset when Power Fluntuate
The stinger box reset and rebooted to the BOOT> prompt, we can still access the stinger via telnet meaning that the IP that will configure on it is still intact but we cannot get to the admin prompt. All the subscribers ports are completely down.
Please can u assist me, do I need to reload the software. The boot loader version is 9.7.1 and hardware revision : 2.1 model B
Kindly assist.
Thanks
Ayo
2 Suggested Answers
6ya staff
SOURCE:
legolas
  • 6 Answers
SOURCE: How can I reset it back to original configration
Hey Eric, I do use same Avaya switch at my lab at office. To me what you have to do is quite simple, first of all you have to get from your network administrator the following info: - Free IP to assign to the switch - Subnet - Gateway (If you ping such IP from a machine of same subnet, there will not be an answer). Then log as superuser (#) and do this: 1. Type set interface inband Replacing , and with the VLAN, IP address and netmask provided by your network administrator and press Enter. (for VLAN you can list them and decide which one to use, but normally you should use 1) 2. Type reset and press Enter to reset the stack. 3. After the Reset, perform login again as superuser.  4. Type set ip route , replacing and with the destination and gateway IP addresses. (If you want all packets not from your subnet to be send to the gateway, then use 0.0.0.0 as destination, list routes set on device for more info) 5. Press Enter to save the destination and gateway IP addresses. That's all. Your switch will be rechable from your same subnet and from other networks if your gateway is working properly and there's no other element blocking you the access. Good Luck!
Posted on Aug 11, 2007
The red light in the stinger charger is blinking on and off rapidly. Is that normal?
not with my stinger flashlight
send it back, lifetime warranty... you have to build an account online and then print a shipping label... WONDERFUL company to deal with
Dec 29, 2013 | Stinger Camping, Backpacking & Hiking
I need to access my NetgearN150 from a command prompt as the GUI is not working can someone tell me if there are telnet or ssh commands available for this unit? The following lists the systems I am...
I think if you're using stock firmware you might be out of luck using ssh.
Still try telnet. (telnet IP address) if it was enabled before on the router (disabled by default.) If you have Win 7 you have to enable telnet in "Programs and Features/Turn Windows features on or off".
Find more info here.
Anyways - I would first try a 30-30-30 reset.
  1. Hold reset button for 30 sec.
  2. pull power whilst holding the reset button for another 30 sec.
  3. plug in power and keep the reset button holding for an additional 30 sec.
Let me know how that goes.
Aug 13, 2013 | NetGear Computers & Internet
I am unable to access my omnistack 4024c using telnet or through Hyperteminal, how i can reset the switch to its factory settings
  1. You need to connect via a console serial cable with suitable terminal software running.
  2. Power on the switch.
  3. Hit any key when prompted by boot process about 10 seconds after power-up to get to boot/diagnostic menu.
  4. Enter c
  5. Press enter (which accepts the defaults) until line displays: "Boot Flags :0xb"
  6. Enter 0x1000
  7. Press enter until back at the "[Boot]:" prompt
  8. Enter S to save settings (thats a capital S)
  9. Enter @ to boot
The switch should now be back to factory defaults.
Mar 14, 2011 | Alcatel OmniStack 4024C Networking Switch
My computer does not start in normal mode .... i suspect there is a virus infected application which does not uninstall ..
ok boot windows in safe mode
click start>run> and type there "msconfig"
aaarwind_12.jpg 1st select the tab "Startup"
2nd click "diable all"
3rd click "apply"
4th click "OK"
after that windows will ask for restart. do restart the windows. if you have virus problem this method will fix most of the cases. if same problem persists you check RAM or DISPLAY hardware and drivers. best of luck.
Jan 20, 2011 | Computers & Internet
I have a suunto stinger dive watch after i changed the battery the ACW stays on the screen .
open watch again and press tiny reset 'button' with a pin. That's how I fixed the same problem
Jan 11, 2011 | Suunto Replacement Strap - Stinger...
I have a virus on my laptop notebook acer and i can no longer open it..what should i do...
The best solution I can give you is to try Stinger from McAfee. You'll need to download it and either burn it to a bootable CD or Floppy Disk. You should still be able to access the Bios at start up if a virus is the problem. Set your Bios to boot from the CD or Floppy drive depending on what type media you used and equipment you have. Stinger actually comes in several versions. The version you use depends on which Virus you have. If you do not know which one you actually have get all the versions and run them one at a time until you clear the virus out. Your other option would be to take the computer to Best Buy or Office Depot and have them do it. If you can not access the bios at boot or the computer will not power at all you most likely have a different problem which will take a tech to resolve.
Dec 18, 2009 | Acer Aspire 3000 Notebook
My computer has a virus and now it won't let me download any security software. what do i do?
If your PC wont let you download any security software then you should go to a public library and download your software, save it to a disk and go home and install it....run the software and check for updates if you cant update, run the software without updating after the scan attempt another update, I recomend AVAST ANTIVIRUS HOME its free for a year with registration and works great
Sep 27, 2009 | Dell Inspiron 6000 Notebook
Rechargable Stinger new bulb is dim orange
Could possibly be a bad switch, I would also get that battery tested out also. If you still have a receipt it should be covered under warranty. If not try sending it in anyway. Limited lifetime warranty does not include bulb, or batteries but, anything else on that Stinger should have a lifetime warranty. Of course that excludes abuse. Check out the website www.streamlight.com and go to FAQ for a nearest Authorized Service Center or send it directly to Streamlight. Address also listed on the website. Hope that helps ;)
Jul 03, 2009 | Stinger Streamlight XT Rechargeable...
Jl 1000/1 popping fuse
well you need to check to see if nt no shottage with the amp and also check if the fuse is not to low amp 20,,,, 25 if not put the amp in a separet 12 volt battery
Dec 10, 2008 | Jl Audio 1000/1 Car Audio Amplifier
Lucent Stinger FS+ Concentrator (300431905) Logo
89 people viewed this question
Top Lucent Computers & Internet Experts
Tom Chichester
JonSnell Electronic
JonSnell Electronic
Gaurav Kr
Gaurav Kr
Are you a Lucent Computer and Internet Expert? Answer questions, earn points and help others
