I have a HP 3309 fax, scanner, copier - fax machine not sending or receivin - How do I reset fax machine - two days ago I lost power - turned on and I'm not receiving faxes - realized also the telephone cord needed to be replaced. when I call the fax number I get a busy signal. Please help! Greg
    President:
  • 3,085 Answers
Hi Greg, call the busy number from a regular phone and listen for busy or fax tones.
Posted on Dec 17, 2009
SOURCE:
I need to know what staples go in this machine and where I can buy them
Printer uses a C8091A
Purchase directly from HP in their online store
Feb 24, 2011 | HP® LaserJet M5035 MFP Laser...
HP 6300 fax machine won't send documents. Result is "no answer" but the recipient machine is on auto answer.
Unplug the power and phone line and then replug it. Also try a manual phone on the line. Tell me what you get? thanks.
Jan 05, 2010 | HP OfficeJet 6310 All-in-One Printer...
My HP scanner in my all in one wont work
I called HP and they told me that the reset for this is unplugging the power cord from both ends and waiting for a count of 60. At first this worked but each time the power goes out in our home, the next time I turn it ion, it does this and tells me there is a scanner error after trying to initialize. Keeps running back and forth somewhere inside and not clicking in. Unplugging and counting no longer work. One day I fooled with it all day and it finally stopped. Now power went out again and it's happening all over again! Very frustrating. Can anyone help?
Oct 07, 2009 | HP PSC 2210 All-In-One InkJet Printer
Can not receive or send fax. When I send a fax, it says no answer, when I try to receive a fax, the other side hear it was ringing on and on, but they did not get the receiving signal.
hi,
HP Officejet 5610 All-In-One InkJet Printer has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.hp.com/printer/prob676ijt65/solution
aswq22
Aug 18, 2009 | HP Officejet 5610 All-In-One InkJet...
Faxing from scanner rather than feeder.. help.
ideadly the scanner needs to scan to get the image to send out in fax form. The feelder paper feeder that is for recieving fax
Jul 31, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Scanner failure error code
You can try a reset on the printer using the # and the number 6,holding them down
while plugging in the power cord at the back of the printer.if it still does not work
then you can try the same with the # and the number 9.If it still does not work,get
your printer serviced.
Jan 06, 2009 | HP Photosmart C7280 Printer
I have a new HP Photosmart C7200 All-in-One Series printer, scanner, copier, fax. I can send faxes, but am not able to receive incoming faxes. According to the fax log, several faxes per day have tried...
Is the phone line for the fax dedicated? an answering machine? it would need to be plugged into the fax machine. Set the number of rings very low,
If you have another phone line, call the fax & see what it does, alternatively, have a friend call with a fax machine & monitor the progress.
Jul 18, 2008 | HP Office Equipment & Supplies
Can not send or receive faxes
You may have to reset printer. Directions as follows:
Re-initialize the HP All-in-One Force the HP All-in-One to reinitialize by following the steps below:
  1. Turn the unit off by pressing the ON button.
  2. Disconnect the power cord.
  3. Wait five seconds, then reconnect the power cord.
  4. If necessary, turn the unit back on and try fax again.
  5. If the unit fails to read the card again, reset the All-in-One. Repeat Steps 1 – 4, but before plugging the unit back in, press and hold the # and 6 keys on the HP All-in-One numeric keypad. Continue to hold these keys down for a few seconds after plugging the unit back in to reset it. Once the All-in-One reestablishes communication with the computer, reset the language and country/region.
You may have to reset the fax at this point.
Apr 15, 2008 | HP PSC 2210 All-In-One InkJet Printer
HP Officejet 7410 prints OK, but copy and fax comes out black all but 1 inch
The problem is on the scanner...
You have to change "scanner assembly". But... here in Greece this unit has not spare parts.... The repair procedure is "unit exchange". You have to contact HP Service in order to inform you if they can change only the scanner assembly and not whole unit... You can call telephone support.
Apr 07, 2008 | HP OfficeJet 7410 All-In-One InkJet...
HP 7140xi scanner failure error
Please click on the web link given below and perform the steps as given in the web page to fix the issue.
http://h10025.www1.hp.com/ewfrf/wc/genericDocument?docname=c00787271&cc=us&dlc=en&lc=en&jumpid=reg_R1002_USEN
For further information contact HP chat support, its free of cost.
CLick on the web link to chat with HP technician.
http://welcome.hp.com/country/us/en/contact/chat_1.html
Have a great day!
Oct 13, 2007 | HP OfficeJet 7410 All-In-One InkJet...
Open Questions:
262 people viewed this question
jasbo
jasbo
Ekse
Marvin
Marvin
