Question about Kenmore 62602 Electric Dryer
Repair on Kenmore dryer
How do I replace tumbler rollers in electric dryer
  • Anonymous Jan 25, 2009
    How do you raise the top?
  • 958 Answers
Lift the top cover, remove the front panel, remove the belt, remove the drum, then replace the rollers.
Posted on Feb 19, 2008
Kenmore HE4 dryer is making loud noise, like a shoe is in it. The back bottom roller appears to be very loose. How to tighten?
ALWAYS UNPLUG YOUR DRYER BEFORE STARTING ANY REPAIRS
Your problem sounds like drum rollers have flat spots on them .
Check your drum rollers for flat spots or wear, if they have flat spots
or wear on them replace them.
If the drum rollers don't have flat spots or wear on them then they probably
only need lubrication. Lubricate the shaft of the rollers with a good grade
of machine oil such as 3 in One oil.
Reassemble the dryer, plug back in. This should solve your noise problem.
Please rate me
Dec 09, 2010 | Kenmore Elite HE4 Electric Dryer
The tumbler dryer will not turn, It will not go around. There is heat
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Sounds like your problem may be a broken belt, or the belt may have slipped off of the motor pulley, or idler arm pulley.
If you have to check/replace/repair your drum motor or belt and if you have a front loading machine:
Note: This method works for most front loading machines.
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer. Be real careful not to knock any of the wires off of the timer switch or other electrical connections.
Remove the lint filter and the screws that hold the filter housing.
Then remove the top of the dryer.
Note: Some of the tops tilt backwards and do not have to be removed completly.
Remove the front of the machine, this will expose the belt and drum, remove the drum and belt and this will expose the drum rollers, idler arm bracket with pulley, and motor with pulley. Pay attention to the route of the belt, this will come in handy when you go to reinstall the belt and drum.
Sometimes the belt will slip off of the idler arm or motor causing the drum not to turn.
While you have the drum out, I would recommend that you lubricate the drum rollers at the shaft of the roller with a good grade of machine oil like 3 in One oil. This will save you a problem later with the rollers getting noisy, also check your drum rollers for flat spots, if they have flat spots on them this will cause a noise like a thumping type noise. You will need to replace the drum rollers if they have flat spots on them.
Please rate me
Sep 11, 2010 | Kenmore 400 6942 Dryer
Tumbler not rotating, metal on metal smell
Bad idler or roller? Broken belt? Open it up and take a look see. Here's HOW
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
May 21, 2010 | Kenmore 67632 Electric Dryer
My electric Kenmore fabric care dryer dries but is loud
check the rollers. might be worn.its what ur drum sits on
Feb 08, 2010 | Dryers
How to stop sqeeking from back of dryer
All dryers have to have a way of allowing the tumbler (that's the thing you put the clothes in) to turn freely, not all of them are the same tho,some use bearings, some use slides,others use rollers. Over time these rollers will need to be oiled,the slides will get thin and start metal to metal contact causing a noise, The rear bearings will then start to make their way to china and cause the tumbler to rub into the heating element and OUCH! These things will cause the motor to prematurely DIE! Its best to examine the dryers, rollers, and slides when you first hear the noise, but who does?
Dec 28, 2009 | Kenmore 84052 Dryer
Neptune dryer tumbler rubs very noisily against its mounting in the upper right (as I face the controls). The tumbler (basket) has a deep gouge where it is rubbing against the housing.
Your problem sounds like drum rollers have flat spots on them or in need of lubrication
If you have a front loading machine,
Be REAL CAREFUL not to knock any of the wires off of the timer switch. Then remove the top of the dryer.
Remove the front of the dryer. This will expose the drum and belt. Remove the drum and belt and this will expose the drum rollers, idler arm pulley and motor.
Now is a good time to check the belt to see if it has slipped off of the idler arm pulley and also check the belt condition for wear.
Be sure to note the route of the belt, this will come in handy when you go to reinstall the belt.
Check your drum rollers for flat spots, if they have flat spots on them replace them.
If the drum rollers don't have flat spots on them then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve your noise problem.
I will include these two websites for parts and further help:
http://www.partselect.com/
http://www.appliancepartspros.com/index.aspx
Both also have chat assistance 24/7.
Good Luck,
I hope this helps
Nov 12, 2009 | Maytag Neptune MDE5500AY Electric Dryer
My electric dryer sparks when i hit the start button from the back of the dryer, what is the problem? I checked the cord and thats not it
All dryers have to have a way of allowing the tumbler (that's the thing you put the clothes in) to turn freely, not all of them are the same tho,some use bearings, some use slides,others use rollers. Over time these rollers will need to be oiled,the slides will get thin and start metal to metal contact causing a noise, The rear bearings will then start to make their way to china and cause the tumbler to rub into the heating element and OUCH! These things will cause the motor to prematurely DIE! Its best to examine the dryers, rollers, and slides when you first hear the noise, but who does? Some repair pictures
Sep 12, 2009 | Dryers
Belt replacement
Visit youtube.com and type in Kenmore dryer repair. You'll find step by step instructional videos to service your unit.
BUT.... You've probably burned a belt, but this may only be a symptom of another problem. Something caused the belt to freeze up and burn on the motor pulley.
Check the roller bearings while it's apart... Make sure that the motor's turning free and all related rollers, pulleys etc are in good shape... save yourself from having to open it up twice..
Good luck and let me know how it goes.
k
Jun 22, 2009 | Kenmore Dryers
DRUM/TUMBLER ISSUE
look at the rollers of the drum, it could have been dameged already and needs to be replaced.
Mar 21, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Maytag frontload dryer MDE9700AYW
take the door off. take the front panel off. take the belt off the tumbler. take the tumbler out. you should see the roller. everything is held with regular phillips head screws.
Nov 10, 2007 | Maytag MDE9700AYM Electric Dryer
Kenmore 62602 Electric Dryer Logo
199 people viewed this question
Top Kenmore Dryers Experts
Sal De
Marvin
Marvin
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
