Question about Canon FAXPHONE L170 Plain Paper Laser
Menu locked on a super g3 3170 laser fax machine
Need to change the time but can't get the menu to work
Need to change the time and date and can't seem to get the menu to work properly
Posted on Oct 24, 2008
Changed toner cartridge and now keeps stating error...change toner cartirdge
In the menu on the printer have it run a thorough cleaning on the print heads. Should be in the set up menu.
Nov 13, 2014 | Brother PPF-5750E 33.6K bps Super G3 Fax...
How do I reset my machine so we can receive faxes
You do not reset the machine to receive fax. Just go in the Initial menu and select accordingly on Receive Mode the option Fax or Fax/Telephone. make sure that you have a phone cable on the machine on the Line connection
Oct 16, 2014 | Brother Office Equipment & Supplies
The drum on my fax machine is not working properly. need user manual brother super g3 33.6
No. It should be working but maybe you still have the Replace Drum on the LCD ? in this case, reset the drum counter
Oct 14, 2014 | Brother PPF-5750E 33.6K bps Super G3 Fax...
Confirmation for a fax that is being sent
Press the menu(dataregistration button) go to report settings under Fax settings edit TX report,change it to - output yes.
Sep 09, 2009 | Canon Office Equipment & Supplies
Cannot receive faxes
Make sure that the telephone line from the wall is plugged into "LINE" and not "PHONE" on the fax machine. You might also call the fax number from a different phone to see if you can hear the fax tones.
Aug 20, 2009 | Canon FAXPHONE L80 Laser
Don't want a transmission report after each sent fax
On the machine there is a menu button.
the menu can be printed out so you can see all the areas to select.
If you scroll to through the menu, you will find a set up or incoming fax menu.
You need to set confirmation to off.
This will take some time to find the right menu, so be patient with the machine.
Good luck.
Feb 23, 2009 | Xerox FaxCentre F116 Plain Paper Laser
I Have a Cannon, Laser Class 710, Super G3 Fax Machine and need to know the procedures to reset the time and date. Can't find my manual.
lift up the 3 speed dial panels
use Data registration key
select date/time settings
use the 4 direction arrows to navigate thru menus
and after changing info use set key to lock in setting
let me know if ya need more help
these are great faxes
May 23, 2008 | Canon Office Equipment & Supplies
Showing incorrect date - how do I change the date?
Please change the Leithium battery fixed inside your fax machine, usually this the problem.
If the Date time is running in different date & time.
Please press Menu, then scrolle left of right arrow key. When you find set Date/Time enter the key mentioned in the Display key and change to your date & time.
After some time see if the date/time working normally. If not change the above mentioned battery.
regards.
Jan 07, 2008 | Canon - SUPER G3 FAX BOARD-T1 (0450B002AA)
Fax, Copy, Scan Buttons do not change
Sounds like switch inside operations panel has broken, there is no reset that will fix it, will need new operations panel.
the reset code on this machine is menu # 2 8 6 4 then maintence shows enter 99, the first bit must be done super quick.
Nov 28, 2007 | Brother MFC-8440 All-In-One Laser Printer
Canon FAXPHONE L170 Plain Paper Laser Logo
96 people viewed this question
old marine
old marine
