Question about Bosch Exxcel WFX 2467 Front Load Washer
Bosch WFX Excel
My Washing machine starts to fill, about 2-3 seconds later , the fill stops and nothing else happens. Also, when the Machine is OFF, the drum fills with water. Any ideas ?
  • Anonymous Mar 31, 2014
    just keeps filling with water and nothing else happens
    President:
  • 1,294 Answers
You have to replace the water inlet valve, the valve where water enters your machine.
Posted on Jan 22, 2008
Washing machine doesnt work kelvinator smartdrive 085 0.5kg
you have to check 1- water pressure switch (wps) , 2- the hose which fixed between wps and drum may disconnected or broken.
Jun 12, 2017 | Kelvinator Washing Machines
Frigidaire model LTF214OES0 no water filling drum at start up
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Oct 02, 2011 | Washing Machines
Normally the machine used to start after taking required amount of water. Now the machine starts only after the whole drum is completely filled with water making it difficult to turn. Even later when it...
Washing machines stop filling when water pressure from the bottom of the tub goes up a plastic tube and into the water level switch. If the tube is obstructed with debris or anything foreign, the switch will fail to stop the water from overfilling. It is possible that the switch is defective, of course. Check the tube for obstructions, kinks, or a loose connection.
If it is the switch, have your make and model handy and look up the part here:
http://www.repairclinic.com
Good luck.
Mar 03, 2011 | Washing Machines
Press the start button,you hear a click,water runs for a second or so, water stops,that's it. Nothing else happens. Any suggestions. Thank you,S.Nielson
heatman101
Feb 19, 2011 | Frigidaire Washing Machines
Push start and machine wont fill and draining/unlocking light sarts blinking about 2 seconds later
My machine had the exactly same problem:
1. Push Start button to wash, but Draining/Unlocking light will flash right away. The drum started to run and stopped
2. No error code shown up
3. Run Quick test: no error code
4. Run Universal Test: error code F25 (later, found nothing wrong with the CCU)
What I did:
1. Clean the bump: found coins and strings.
2. Clean the drain pipe from the pump to tub: found more coins.
3. Clean chamber of pressure switch at the tub: found nothing.
4. Clean the gap between tub and drum: found a credit card!
After the cleanings, the Draining/Unlocking light would still come back and I almost gave up. Amazingly, I ignored it and a few minutes later.... the machine started to run as normal!
It seems that CCU needs sometime to reset itself after the failure.
Jan 24, 2011 | Whirlpool WFC7500VW Washer
Timer programme
Drain pump may be obstructed or defective. You may have to call your engineer back. Maybe he disrupted something.
Nov 13, 2017 | AEG Lavamat 72640 Front Load Washer
Asko 10505 runs through was cycle in approx. 30 seconds, then wont drain. Simply stops. It doesnt matter which cycle I start with, the dial moves quickly to stop. It fill with water and spins. ANY HELP...
hi sir' start the wash machine empty and see if it happens when nothing is in it.
2. When machine is off, open the top grab the centerpiece inside the wash machine and pull and push it slowly, does it move? (For safety unplug the machine)
3. Make sure machine is 100% level (front to back, left to right)
The most common thing is bad drum bearing, which force the wash machine out of whack when in spin / wash. Which are common and the best thing is to call Maytag.
thank u .........................................please rate
__________________
Sep 11, 2008 | Asko Washing Machines
Bosch Exxcel WFX 2467 Front Load Washer Logo
462 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
