Question about Mustek MDC-5500Z Digital Camera
LCD Display gone white
The LCD display on the camera just displays white, when the camera is turned on. When the view changes you can see a change in the white as though the white is just a blanket over the images, but nothing else is seen, what could be the problem?
0 characters
1 Points
Change from lcd moniter to view finder
Try this, in your manual at the bottom of pg. 229 that says, "If you turn off the power while the 'shooting settings display' screen is displayed, the same screen will be displayed when you turn on the power again. To avoid this, press the <INFO> button to turn off the display on the LCD monitor, then turn off the power switch."
The converse also applies. Get into the shooting settings display with the INFO button and power down. The display will come on when you power up again.
It also solved my problem of getting the mode selection button selections to show on the LCD when needed.
Jul 13, 2014 | Canon EOS 7D Digital Camera
Display is white inside & out
try hooking it up to your PC and using the REMOTE FEATURE, see if you can change the whiteness lvls from there or see anything on you pc, if you can then your lcd screen is shot and might need to be replaced or checked at your local service place.
Sep 17, 2007 | Canon PowerShot S2 IS Digital Camera
Camera display is constantly red
problem in LCD (display) replace it
Oct 25, 2009 | Pentax Optio A30 Digital Camera
I can't view my pictures after the shot,it very blerr
I'm not sure if you are talking about the quick view of a picture just taken, or using playback mode to view shots taken. Either way, I suggest changing batteries so they are fresh.
There are 3 different LCD choices when in "Shooting Mode."
Press "DISP."
The display mode will change each time you press this button.
1- Standard (no info displayed, just pic)
2- Detailed (infor displayed)
3- Off
If you have tried this, then you may want to perform a reset to the cam. This will reset any screen/LCD settings that may have been changed.
Goto the Setup Menu and select "Reset All." Select "OK" and press "Func. Set."
This reset WILL NOT reset the following:
-Current Shooting Mode
-Date/Time, Language, & Video System settings
-White Balance Data (of you have custom settings changed in the custom white calance function)
Apr 30, 2009 | Canon PowerShot A450 Digital Camera
Screen has gone white
Either your LCD is damaged or the cable connecting it to the rest of the camera is loose. I would suggest taking it to be repaired.
Sep 09, 2008 | Canon PowerShot A540 Digital Camera
White Display on Screen
I fixed the camera myself as follows:
1. Hold camera firmly in left hand
2. Smartly rap front of camera with knuckles of right hand on the "Cyber-shot" logo.
It worked, now the LCD is working again for free.
Guess I don't need to pay Sony $111.00 for repair service.
Best Regards .
M.R.Mohajeri - I.R.Iran
Sep 07, 2008 | Sony Cyber-Shot DSC-S40 Digital Camera
Diplay turning white on mju 700...
Sounds like your camera was dropped and the LCD was damaged. The white screen you see is typical for a defective LCD screen. The only way to repair the camera is to replace the bad part with a known good one.
One solution would be to buy a defective camera online that has a good LCD screen and swap them out.
Good luck from Darntoothysam com
May 01, 2008 | Olympus Stylus 700 / 700 Digital Camera
White screen on kodak C643 easy share digital camera
This sounds like either a broken LCD screen (they don't have to display the liquid in the display to be broken) or a cable that has partially been disabled.
You can try to open the case and reseat the LCD cable and try that.
Dec 18, 2007 | Digital Cameras
Camera repair
Time for a new Camera. It is about 150.00 to replace the LCD. it is cheaper to replace it unless you can just use the viewfinder alone!!
Nov 13, 2007 | Kodak EasyShare Z612 Digital Camera
Sony cybershot dscp73 view screen
Good Day, LCD display is defective, pls contact nearest service center, no longer user serviceable, still u can use it using optical viewfinder, but you can no longer change settings, cause infos are displayed on the LCD screen. Thanks
Aug 27, 2007 | Sony Cyber-Shot DSC-P73 Digital Camera
Mustek MDC-5500Z Digital Camera Logo
22 people viewed this question
Top Mustek Digital Cameras Experts
Steven Wander
Steven Wander
Are you a Mustek Digital Camera Expert? Answer questions, earn points and help others
