Question about Nikon D70 Body Only Digital Camera
PICTURE WITH BLACK SPOT
WHEN SEE TRUE THE VIEW, PICTURE HAS NO SPOT, AFTER PICTURE TAKEN, SPOT CAN BE SEEN AT THE SCREEN.
CHANGING DIFFERENT LENS SAME PROBLEM.
HOW TO CLEAN THE BODY.
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 206 Answers
CCD sensor has some dirt/dust on it . Set camera to B ( in manual mode scroll until 'bulb' is displayed in the top display ) . Take lens off and release the shutter and keep the button pressed down so that the sensor is exposed : use blower to remove dust/dirt but NB do not touch sensor surface as you will make it even dirtier. Take some shots to see if the spot has gone and repeat if it has not disapear.
Posted on Jan 22, 2008
--cannot view anything to take a picture of--the view screen is black but I can see al menu items and can display settings. Flash works. I can see cannon signal clearly when camera is turned on. I am...
The A6XX series is prone to stuck shutter problems, particularly if the camera isn't used very often. Lens lubricating grease can coagulate on the shutter, immobilizing it. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Oct 29, 2011 | Canon PowerShot A630 Digital Camera
The screen is black and if I take a picture it is also black, I can view older pictures that have been taken
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Jul 31, 2011 | Panasonic Lumix DMC-TZ3 Digital Camera
I have a Cannon PowerShot S2 IS digital camera, about 5 years old. The LCD Monitor and Viewfinder both only show a black screen with some of the Dispay Icons across the top and bottom, and after a few...
Jun 06, 2011 | Canon Cameras
My LCD screen is black. The camera seems to take
its actually probably the display. there is 3 different displays. 1. shows picture with icons 2. shows just the picture and 3. is a solid black screen. just hit the display button to cycle through until your desired display is present
Feb 07, 2010 | Canon PowerShot A620 Digital Camera
Black screen
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
Oct 06, 2009 | Canon PowerShot A510 Digital Camera
Black screen, black pictures
Set to auto shooting mode, take pictures, if still get black pictures, you need to repalce the lens unit. CCD or shutter defected.
Jul 08, 2009 | Olympus Stylus 720 SW Digital Camera
Canon Powershot A510 black screen when taking photos
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see the following for further info and a simple fix that may help:
http://camerarepair.blogspot.com/2009/05/simple-fix-for-stuck-shutter.html
Jun 20, 2009 | Canon PowerShot A510 Digital Camera
Black screen through screen and eye view finder
Jun 07, 2009 | Canon PowerShot SD870 IS Digital Camera
Canon Power Shot S1 IS
canon has a recall on this camera. call them and they will send you a box to send it back. If you are one of the lucky ones the will send you a canon s5is back...really nice camera
Oct 29, 2008 | Canon Power-shot S1 IS Lens Converter
Pictures appearing black- olympus FE 170
You checked the obvious, lens cover? (sorry had to ask) any grinding noises when you take a picture or focus\zoom?
Aug 26, 2007 | Olympus FE-170 Digital Camera
Nikon D70 Body Only Digital Camera Logo
124 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
