Question about Canon imageCLASS D780 All-In-One Laser Printer
Paper wrapped around fuser roller
How do i get the fuser out of this machine so i can get the paper out of it?
  • Anonymous Mar 28, 2014
    small piece of paper wrapped around feeder roller pushes the finished copy out to the top
  • 64 Answers
Http://www.precisionroller.com/fuser-assemblies---units-for-canon-imageclass-d780/products.html
im not 100% familiar with this printer but iv replaced ALOT of parts on ALOT of different types of laser printers(color and mono) the fuser invariably will come out either the left or the right side, last place would be the middle. either way they are always fairly easy to get to being they are the second most common part replaced in a laser printer. Tipicly located right by the toner in the paper path. this should be easy to find.. IF you still need help finding it send some pictures with either side taken off or the "hood" up. and ill point it out to you. BE CAREFUL OF the contra wire. it will zap you.. even if the printer is unpluged.
Posted on Jan 22, 2008
OKI C711 928:fatal error
Just to confirm that Jeff Hughes is correct. 928 does refer to paper wrapped around the fuser rollers making the thermistor see nothing hence the 928. If there is no paper in the fuser then it will need to be replaced. Remember to turn the machine off when removing or replacing the fuser.
Nov 09, 2016 | OKI Office Equipment & Supplies
Error c3451
Fuser not getting warm enough, first check if there is paper wrapped around the upper fuser roller, if so remove it and reboot the machine.
If this is not your problem then your thermistor inside the fuser unit needs to be replaced
Oct 15, 2013 | Minolta bizhub 200 All-In-One Printer
Paper is getting stuck in the fuser rollers
remove the fixing unit and clean the charge roller (aluminume roller) in case you are cleaned for long time this coudbe in black color clean well and refix it, the machine will be alright.
Jan 28, 2013 | Canon imageRUNNER C3200 Copier
I have a Samsung SCX-4600, great machine but I've got a paper jam and I can't get at it - the troubleshooting guide is very helpful for jams everywhere except in this location - the paper has wrapped...
it sounds like it is wrapped around the fuser roller. is the roller around an inch or 2 around? if so it is the fuser roller and be carefull to no scratch this roller or you will get all jams. the fuser can be taken out with care to look at all the plugs and screws.
Jun 20, 2017 | Samsung SCX 4600 multifunction Laser...
WE HAVE A PAPER JAM ON THE BACK FUSER OF HP LASERJET 2420. A PIECE OF PAPER IS COMPLETELY WRAPPED AROUND IT.
You can attempt to remove the fuser from the machine to have better access to the paper inside. It is very easy to damage the fuser roller and film when removing a piece of paper wrapped around inside.
We recommend calling for service, but worst case is you try yourself and can't get the paper out then you would just order a new fuser.
We can get you the fuser. Just call 262-993-1551. We offer free shipping.
Sep 02, 2010 | HP LaserJet 2420 Printer
I had a piece of paper wrap around the fuser of my Oki C5650 printer. I have removed the paper (all of it.), but now it is displaying a 980 Fatal Error code. What do I do now?
I just had a service call with a 980 error. i removed the paper wrapped around the fuser roller but the error persisted. The only thing that cleared the error was to replace the fuser. I am not sure why but the fuser was shot after it had the paper wrap inside it.
There is no reset to clear the error. The only fix was to replace the fuser.
Aug 18, 2010 | Office Equipment & Supplies
How does one clean a panafax uf-770 fax machine? the copies are coming out black and it comes off on your hands.
You probably have a piece of paper wrapped around the fuser roller. You will need to call a technician
Apr 13, 2010 | Panasonic Panafax UF-595 Plain Paper Laser...
There was a paper jam, I cleared it and it will not reset. The machine won't print at all, just keeps showing paper jam.
There are flag sensors in each machine. The have to sence if the paper is moving properly through the machine. They are sometimes black in color, that flag sensor might be jammed in an up postion, or broken look at where that paper stopped and look for a flapper toggle unit that senses the paper. There also might be paper still in the machine, check the fuser unit, the hot area look to see if paper has wrapped around the upper fuser roller.
Aug 28, 2008 | Ricoh Office Equipment & Supplies
Hp laSERJET 1200 PAPER JAM
If you cant get paper out from inside after removing cartridge then there is No easy fix, and the roller at rear is called a fuser, these parts dont come out easy,machine will need all covers removed, plugs disconnected and brackets removed, gears pulled off and fuser removed, maybe replaced if there is a reason why it wrapped around roller
Oct 18, 2007 | HP LaserJet 1200n Printer
Canon imageCLASS D780 All-In-One Laser Printer Logo
180 people viewed this question
old marine
old marine
