Question about Kenmore 46462 Front Load Washer
My front loader door gasket broke, I ordered a new one but
I can't figure out how to take off the old door gasket, anyone know how? The washer is unusable cause it leaks, any help is appreciated. thanks
    Novelist:
  • 139 Answers
Go to this web site and enter your complete model number in the search field in the upper right corner of the page. You will be able to search for a parts listing that includes diagrams that may be helpful.
Posted on Jan 22, 2008
6ya staff
SOURCE:
I have the LG Tromm direct drive system and it is leaking from the front door. Can anyone help. Thanks Doris
The first thing that springs to mind is that the large rubber seal or gasket around where the door closes may be perished or damaged in some way. Obviously the door is not making a perfect seal when it's closed. If all appears to be normal, check that there is no visible gap when the door is closed, if it is even slightly out of alignment it would be enough to cause a leak.
If there is no apparent problem, you could try these links and query it with the manufacturer, the appliancejumk one explains how to replace the gasket if this proves to be the problem. I hope this helps.
http://appliancejunk.com/forums/index.php?topic=6459.0
http://www.lg.com/us/appliances/washers/index.jsp
Aug 22, 2011 | LG Washing Machines
Kenmore HE 2t washer is leaking from the front
thats called a bellow. from a scale of 1-10 id say a 9. front assy of washer needs to come apart to be able to get to gasket rear. that is why it leaking just a small tear or bend on the gasket bye the door will cause it to leak. ive done about 50 of those and it takes me about 1 hr. good luck .if u need furthur assistance let us know. thank you.
Oct 07, 2009 | Kenmore Washing Machines
LG Washer leaks from front door
search the parts stores on internet then check ebay i find many times the common parts such as door gaskets can be had cheaper on ebay
Sep 29, 2009 | LG WM-2277HW Front Load Washer
LG front load washer leaks from door gasket
This is best left for a proffessional to repair
Affordable Appliance Repair
LAke Forest, CA. 92630
Aug 21, 2009 | LG WD-3274RHD Front Load Washer / Dryer
Front loader washer leaks from bottom center of door osmetimes
Check inside the door on the bellows gasket to make sure the inlet area (normally at the 10 o'clock position) is properly positioned around the water inlet, sometimes these work themselves off the inlet nozzle and can casue a leak when the washer is filling up.
Also, carefully run your hand around the bellows gasket to see if you can find any small holes that cold be letting water leak out. You'll need a flashlight to make this easier. It is hardly ever the hinges that causes a leak since the hinges are mounted outside of the door seal gasket (bellows gasket) and aren't ever exposed to the water.
Jul 27, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Leak at the door
If you are still having this problem, try moving the spring on the tub gasket clamp (right at the bottom of the door opening) about 90 degrees to the left (to right by the hinge). Let me know if this solves your problem. Thanks.
Feb 02, 2009 | LG WM-2277HW Front Load Washer
LG WM1812CW washer smell
This is a problem with LG design. There are 2 problem areas that I have seen. One is that bottom on the rubber gasket and the other is in the filter drain pipe.
Beside throwing out the machine I believe you need to remove the rubber gasket and clean the mold from it, and also clean the filter drain pipe at the bottom.
I am not expert so I will let you know how this goes as I am trying it tonight. I just need to figure out to how to remove the rubber gasket .. as I see there is actually mold in there.
Jul 02, 2008 | Washing Machines
Washer is leaking
Check the rubber bellow (gasket) around the door. This is the symptom of a door gasket that it starting to leak. Pull the rubber folds back and check the area where the gasket attaches to the wash tub. You may have a crack or tear. If the gasket is worn please replay back to this post and I can give you advice on how to replace it and where to get a replacement gasket.
May 14, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore 665-15962 Elite 8 yrs old
Won't start nor drain. what could the problem be? please help.
Apr 02, 2008 | Kenmore 15872 Dishwasher
Bosch front load needs new gasket
Bosch WFMC 3200 Front Load Washer needs to replace
door gasket.
This video will show you how to change a door seal or gasket on this Bosch front loader washing machine and also where to buy parts!
we have all bosch repairs in our channel.
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
Feb 22, 2008 | Bosch WFMC 3200 Front Load Washer
Kenmore 46462 Front Load Washer Logo
32 people viewed this question
fordexpert
Harvey Mahal
Kristen Denison
Kristen Denison
Level 1 Expert
