Question about Sony Handycam DCR-PC1 Mini DV Digital Camcorder
No picture My cam is not playing back on the cam LCD screen
0 characters
1 Points
Blue screen on lcd screen
The playback head is probably dirty and cannot show the picture - the screen is blue. Run a blank tape in the tape drive and execute a record all the way through the tape. Then play back a pre-recorded tape to verify it plays back ok.
Nov 11, 2010 | Sony DCR-HC30E MiniDV Camcorder
I can turn my camera on, but there is no screen or sight for recording or play edit.
normally, if you can turn the camera on everything should work including the lcd. if its just an issue with the imaging sensor, you wont see anything on the viewfinder (for the viewfinder to work you need to close the lcd screen) but should at least see the indicators, same in the lcd screen and view your videos in playback mode. if its an lcd screen issue, there would be nothing coming up in any mode the camera is set to. you can try to reset cam back to default settings (press reset while cam is on, its located on the side where you have the handstrap, just below the speaker), or do power reset (remove the batt and ac adapter for at least a minute). if still the same, your unit may require service. thanks. hope this helps.
Jul 21, 2010 | Sony Handycam DCR-HC21 Mini DV Digital...
My Handycam shows a bluish screen(DCR-HC32E)
did you happen to drop the cam? there could be a technical error with the LCD screen. take it to the nearest Sony service center and have them take a look at it. you can try resetting the cam and see if it changes anything.
Jun 11, 2010 | Sony Handycam DCR-HC32 Mini DV Digital...
This is a feature not a bug...The LCD is designed to flip the picture when you rotate the screen. This is so that you can see what you filming or be in the picture and see yourself filmed. I can't remember if it flips automatically or not. But, I would first try inverting and reverting the LCD screen to see if you can get it to detect orientation, then check and see if there is a setting to manually set the orientation of the LCD instead under the menu options.
May 05, 2010 | Sharp Viewcam VL-Z3U Mini DV Digital...
Play back is in black and white
Set your TV in auto mode or according with your CAM system PAL or NTSC and some of the CAM you can set for AV out in PAL or NTSC system
Nov 03, 2008 | Sony Handycam CCD-TRV308 Camcorder
model # is required for me to help you.
Sep 09, 2007 | Canon DC10 DVD Camcorder
Lost LCD Screen
You MAY just have a dirty playback head. Purchase a head cleaning tape (Bestbuy, Target, etc., for about $20) and try cleaning your playback head. Colored lines is ONE symptom of a dirty head. A blue screen is ANOTHER. I had that symptom yesterday (9/7/07), got a cleaning tape and solved the problem. I can now again see on the LCD display what I recorded on the tape. Good luck.
Aug 21, 2007 | Samsung SC-D363 Mini DV Digital Camcorder
Recoding and viewing
sir , the lcd flap of the camera has been spoilr\ed due to this the image is not coming on lcd , only u have to take the image through view fider , lcd fpc has to be changed / repaire u can contact me also
Mar 28, 2007 | Sony CCD-TRV228E Camcorder
LCD screen goes plain grey
i think it's the case of damaged flexible cable to the lcd screen from the camera. a replacement will do the job
Jun 27, 2006 | JVC GR-DVM5 Mini DV Digital Camcorder
Sony Handycam DCR-PC1 Mini DV Digital Camcorder Logo
32 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
