Question about Canon PIXMA MP510 All-In-One InkJet Printer
Printing All of a sudden the printing is off centre, which means I loose the right edge. HELP!!
  • 619 Answers
Hi , check recock the breaker ,the outlet may lose ,switch on again will return to right side.
Posted on Jan 22, 2008
My hp priter is printing pink lines in the edges of my paper
Your magenta toner cartridge or magenta print cartridge is leaking should replace it (magenta is the red one).
Mar 23, 2014 | HP LaserJet Office Equipment & Supplies
My printer won't print on a full scale.. meaning
this has to be set from the wizard for the printing job ...look for the edges size..but when you print on paper ..something like a full size A4 image will always leave a 5 mm edge as default setting ..But like I said..initiate printing ..and in that wizard set the edge to 0 or to remove edge if it is possible..anyway if it is possible there is the only location where you can change it ...and I'm not sure if it can be done permanently
Apr 29, 2010 | Office Equipment & Supplies
Print runs to the right as it prints the page, moving closer and closer to the right edge of the sheet as it prints down the page.
The printer is losing traack of the zero position of the carriage.
Possible problems:
1. carriage drive belt is too loose or teeth have been lost off the drive gear.
2. There is too much stiction of the carriage and the stepping motor "slips a cog".
Nov 28, 2009 | Office Equipment & Supplies
Is is not printing right. The printing comes out
Go to start->all programs->Lexmark X74-X75->Lexmark X74-X75 Solution centre
Then click on the maintenance tab in the far left corner. then, under Select a Maintenance Tool:,
select "align to fix blurry edges. that should fix it.
Jul 15, 2009 | Lexmark X75 All-In-One InkJet Printer
Prints offset
So which OS are you using? 98, XP or Vista? Have you tried delteing the printer from your machine, downloading and then installing the latest driver from Epson?
Jul 16, 2008 | Epson Stylus Photo R300 InkJet Printer
HP Deskjet 6540 Alignment
Yeah, the only thing that can cause this is paper feed problems.
There must be either something loose in the paper feed mech (look for wobbling "tires") or there is still some paper or other foreign debris in the paper feed path.
Jul 03, 2008 | HP DeskJet 6540 InkJet Printer
Paper is printing but top edge of paper is creased and torn
It sounds like your maintenance kit is defective.
The excess oil leads me to believe that.
Jun 04, 2008 | Xerox Phaser 8200 Laser Printer
Print margins too large on Xerox DocuColor 12 - How do I reset?
Not sure this is what your needing but ,,
The Edge Erase default setting is No Erase, which enables the copies to print within 2 mm of each page edge. This is normally sufficient to remove shadows from the edges. If the dark edge is closer than 2 mm, you must set Edge Erase at Variable Erase.
The Variable Erase option enables the copier / printer to vary the amount of erasure from 0 to 50 mm in 1 mm increments. The same amount of erasure is applied to both top and bottom edges or right and left edges of the document.
  1. Select [Edge Erase] on the Added Features tab. The Edge Erase screen is displayed.
  2. Select [Variable Erase]. The Variable Erase screen is displayed.
  3. Under Top & Bottom Edges, use the [Up] arrow to increase the amount of erasure at the top and bottom edges. Use the [Down] arrow to decrease the amount of erasure at the top and bottom edges.
  4. Under Left & Right Edges, use the [Up] arrow to increase the amount of erasure at the left and right edges. Use the [Down] arrow to decrease the amount of erasure at the left and right edges.
  5. Under Original Orientation select the page orientation that most closely resembles the orientation of the document on the Document Glass.
  6. Select [Save]. The Edge Erase screen is displayed.
  7. Select [Save]. The Added Features tab is displayed and shows the new Edge Erase values.
Feb 05, 2008 | Xerox DocuColor 12 Printer
32 inch rca color
If this is a 32 inch TV then it is a standard picture tube set. If the colors have suddenly gone out of whack, and the set has not been dropped or had any large magnets near it recently, it means that the degaussing thermistor has come loose from its legs. This is very common in the RCA regular picture tube sets. If you look in the back of the set you will see a large black coil of wire wrapped around the edges of the picture tube, with 2 white wires going down to a jack on the main PC board. Right next to that jack is the degaussing thermistor, which looks like a small silver disc, like a nickle, with 2 legs loosely soldered to its sides. One or both of those legs are probably loose, and if you are very careful you can solder those legs back onto the thermistor. If you do not have experience soldering small parts, allow a qualified tech to handle it for you.
Aug 26, 2007 | RCA HD61LPW175 61" Rear Projection HDTV
Canon PIXMA  MP510 All-In-One InkJet Printer Logo
old marine
old marine
