Question about Amana ACD2232HR Side by Side Refrigerator
Amana evaporating motor keeps going
Have changed the motor 3 times now could there be a reason it keeps going
    Scholar:
  • 42 Answers
Hello, Your question does not state in it what is wrong with the motor when you have to replace it. If the windings of the motor are burning out causing the motor not to run, I am sorry but I can't tell you anything except that is very strange.
If your motors bearings are going bad you will need to replace the fan blade because the blade is causing the problem.
I hope this helped you
supertechks
Posted on Jan 25, 2008
Freezer is cold but it is not freezing foods.
When it comes to refrigerators I always have a most likely to least likely formula to try to solve the reason of why the freezer or fresh food compartment is or is not cooling properly. So knowing that the cold air comes most times from the freezer compartment I would look to see if the fan inside that compartment may just be slowing down because it is possible there is frost building behind the freezer wall due to most likely defrost not taking place and creating a huge block of snow and ice blocking air circulation.. Ice will show on the outside wall of freezer also if possibly the defrost heater is burned out. There are so great testing tutoral'son the following links! So now having your model number that most people don't think about I will look to see just what type of defrost system your model has=> ABB1927DE EVAPORATOR AREA and Rollers location 16 in photo. That part is your models=> 67002135 Defrost Heater
Amana, ABB1927DE User Manual
Sometimes the 67003636 Evaporator Fan Motor goes bad but thawing is more severe when the evap. fan goes bad and may be tricky stopping and starting on its own before true-ly burning out=> 67003636 Evaporator Fan Motor
here is a Amana ABB1927DE Wiring Diagram=> HERE
67003426 Defrost Thermostat Hey I know there is a lot of material here so I will be here if you should have questions, Thanks, Sea Breeze
Jun 01, 2011 | Amana ABB1927DE Bottom Freezer...
Freezer cuts on every 3-4 minutes. stays on 8-10 seconds. some thawing occuring
If I understand you correctly the compressor is short cycling. The more it does this the worse it gets by causing the compressor to overheat. Sometimes the problem is because the condenser fan or evaporator fan being defective. Pull away from wall and remove cover over compressor unplug and feel top of compressor and if too hot to keep hand there keep unplugged but do examine the evaporator and condenser fan to eliminate them as a reason. The most likely reason is start relay and or start/run capacitor and sometimes a worn out compressor.
Overload relay click here=> 67002527
Run capacitor click here=> 65889-4
Location Click Here=> MBB1952GR Compressor Components
Parts in that photo are marked as 10 overload/relay, 11 is the run capacitor and 3 being condenser fan motor. Condenser and evaporator fan motors do not always stop completely when bad so make sure both run while compressor is running. If this has been helpful please rate if you have more questions please let me know, Thanks Sea Breeze
Dec 10, 2010 | Maytag MBB1952GR Bottom Freezer...
I have an Amana BX21VW refrigerator and both the freezer and refrigerator stopped cooling. The fan is still going and there is power, but no cooling of any kind. What is going on?
Hi!!
Check
Temp. control knobs,
Most likely, the evaporator coil is covered w/ice, obstructin the air flow thru it and to the fridge side of the unit.
Remove freezer back panel (where the little fan is) and check for iced evaporator coil, if so, unplug unit and use a heat gun or hair dryer to melt ice, make sure all ice is melted andthe air duct going to the fridge is clear.
Once this is done, restart unit and set temp. 1/3 of the dial, ie. if the dial goes from 0-9, set it on 3. wait 24 hrs to make adjustments
Keep me posted!! Rate this post!!!
Aug 12, 2010 | Amana Refrigerators
Amana BX518VW refrigerator not getting cold enough
Amana is not a S.African make, but all work on the same principle. What i think you have is an evaporator fan motor that is located in the freezer compartment that has jambed up with ice. The freezer needs to be defrosted to allow freezer panel/s to be removed to allow access to the evaporator.Check motor for free movement and if turning freely, switch fridge back on and try and determine if fan comes on. (open door periodically to inspect) If so, replace panel/s and retry. Not sure if you have an auger motor controlling the frost intake to the fridge but if you do, it could also cause problems. Check to see if it can move freelt.
May 20, 2010 | Refrigerators
Ammana Fridge-Evaporator Fan not working
Replace the defrost bimetal . On older Amanas' , the coil has to be cold , before the evaporator fan starts ( bimetal closes ) . This way , heat from the defrost cycle , will not be blown into the refrig section .
Oct 07, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Stuck in defrost mode after changing timer and thermostat
Amana adaptive defrost:
Press refrigerator light switch five times in six seconds to initiate defrost cycle. Pressing five more times within six seconds will cancel defrost and go straight into the run mode. Similar operation on both bottom mount and SxS refrigerators. After the defrost terminator/thermostat opens, six minutes of dwell time occurs before the compressor and condenser fan motor will operate. After defrost terminator/thermostat open, 10 minutes of dwell time occurs before the evaporator fan motor will operate.
May 05, 2009 | Amana 25.8 cu. ft. Side-by-Side...
Control board reset?
Amana version of adaptive defrost : Press refrigerator light switch five times in six seconds to initiate defrost cycle. Pressing five more times within six seconds will cancel defrost and go straight into the run mode. Similar operation on both bottom mount and SxS refrigerators. After the defrost terminator/thermostat opens, six minutes of dwell time occurs before the compressor and condenser fan motor will operate. After defrost terminator/thermostat open, 10 minutes of dwell time occurs before the evaporator fan motor will operate.
May 04, 2009 | Amana ABB2224DEW / ABB2224DEQ / ABB2224DEB...
Ice form in evaporator
you have defrost problem 1 timer 2 heater 3 heater remove the back panel in the freezer turn timer on till fridge go off if heater come on change timer and defrost thermostart
Apr 07, 2009 | Amana ABB2224DEW / ABB2224DEQ / ABB2224DEB...
Two warm in refrig
Hi. The most common failure for this make refrigerator is a bad evaporator fan motor. You should feel air coming out of the diffuser in your freezer. If not, either the fan motor is bad or you have alot of frost build up on the evaporator. You would see alot of frost on the back wall of the freezer where the evaporator coil is located. If this is the case, most likely the defrost bimetal thermostat. But if no frost, the evaporator fan motor is most common and likely to be your problem. Visit me on Ebay username: themackshack. Good luck! Mack
Dec 12, 2007 | Amana ABB1921DE Bottom Freezer...
Amana ACD2232HR Side by Side Refrigerator Logo
42 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
