Question about Efficient Networks Siemens SpeedStream Powerline 2510 DSL/Cable Router (936-2510-001)
Factory defaults on ss2510 powerline router
How do I set a ss2510 back to factory defaults. I cannot get SpeedStream to work for the password.
  • jdillard Jan 23, 2008
    Thanks a million. That did it.
    Jimmy
    Novelist:
  • 139 Answers
Look for a small reset button. It would typically be concealed in a small hole where it can be pressed with a paper clip. Try pressing the reset button for about 15 seconds, then release it. If this fails to reset to defaults, turn off the power...press the reset button....turn on the power while holding the reset button in...continue to hold the reset button for about 15 seconds.
Good luck...and I hope this is helpful!
Posted on Jan 22, 2008
6ya staff
SOURCE:
I HAVE SPEEDSTREAM 6520 AND WANT TO CHANGE MY WIFI PASSWORD BUT THE PROBLEM IS I LOST MY ADMIN PASSWORD IT IS ASKING WHN I WANT TO CONFIGURE HOW DO I GET MY PASSWORD BAC AND GO FURTHER WITH MY CONFIGURING...
The only way to get in to the router without password is to reset it to factory reset. RESET will bring all the settings back to what it was when you got it out of the box. Any custom settings will be lost and you will need to input them back in to settings (like your wireless network name or SSID, password and any open ports). Reset is done by pushing is little reset button (little round hole) that is usually on the back of the router and most times it says reset or it is different color than color of the router. You can use a pen or little screw driver but make sure not to press too had so you don't damage it. Router needs to be on and then when you push in the reset you need to hold it in for 30 seconds (make sure it is 30 per clock not just your count to make sure it worked). Once time is up just remove the pen or what ever you used and you can now log in to your router with default user name and password. This is probably on the paperwork you got with the router. If you don't have it just Google your model and most times you can find it there. If not you might have to call support and just ask them. Hope this helps.
Apr 09, 2011 | Siemens SpeedStream 2624 (SS2624) Wireless...
Need password to my netgear router n 300
what is the model #?
Most netgear routers default to a username of "admin" and password is either " admin ", "password" or it is just blank. Those are the defaults unless someone changed it.
If you cant get in you can hold down the reset button on the back for 30 seconds (while it is plugged into power) and that will set it back to factory default settings then one of the above should work.
If this was a help please give me 4 thumbs up as I am trying to build up my rep on this site!
Mar 02, 2011 | Computers & Internet
HOW TO UNLOCK SPEEDSTREAM 6300 ? THANKS
In order to get your router back to the original settings, you must push in the reset button (usually on the back of the router) for somewhere between 10 and 30 seconds depending on the router. You may need a pin or something small to push in the button, because it can be recessed. Once you have reset the router, the username and password will be changed to the defaults, admin and password, respectively. One thing you must remember is that resetting the router will change all of the router settings back to the factory settings. This means you will lose all of the changes you made since you got the router. Make sure to write down any things you've changed, so you can change them back after the reset. Also, I recommend updating to the latest firmware after the reset.
If you need more help post back! Thumbs and testimonial are welcome!
Jan 21, 2011 | Siemens SpeedStream 6300 (33A6300001)...
I need to retrieve my password on the Speedstream 6520 Router so I can log in wireless with my iphone.
not possible to retrieve a password! that's why they are secure... if you have your ISP ADSL setup details you can reset the router to factory default and reprogram it from scratch, or call their help desk BEFORE you do it and ask them to email you the connection details before you start. then WRITE the password on a label and stick it to the router.
Mar 25, 2010 | Siemens SpeedStream 2624 (SS2624) Wireless...
Need to reset router
If you reset the router you will lose all the settings of the router.
On the router you will find a small reset button .
Hold it down for 30 seconds.
Unplug the power cable and plug it back in.
wait for 30 seconds and then reconfigure the router.
Click Here for more info about router set up.
Oct 20, 2009 | Siemens SpeedStream 2614 Router (ss2614)
What is the routers address for configeration
192.168.254.254 is the default IP address of Efficient Networks Speedstream 2623 router.
Default password to login is 'admin'.
Oct 12, 2009 | Siemens Efficient Networks SpeedStream...
Speedstream router - password retrieval
Try using the following default user name & password:
Username : admin
Password : hagpolm1
Dec 19, 2008 | Siemens SpeedStream 2624 (SS2624) Wireless...
Speedstream SS2510 Ethernet Router
Try Speedstream.com and specifically:
http://kb.efficient.com/display/1n/index.asp?c=&cpc=&cid=&cat=&catURL=&r=0.9983179
Feb 09, 2008 | Efficient Networks Siemens SpeedStream...
What is the default password for Powerline devices?
The default password is SpeedStream. Note that this password is case sensitive.
Feb 19, 2006 | Efficient Networks Siemens SpeedStream...
I have a large house (e.g. 4,000 sq ft). Will the Powerline network work throughout my house?
While the homeplug 1.0 standard was optimized for homes of around 2000 square feet, our Powerline devices have been tested with excellent results in homes of up to 7,000 square feet.
Open Questions:
See all Efficient Networks Siemens SpeedStream Powerline Questions
Efficient Networks Siemens SpeedStream Powerline 2510 DSL/Cable Router (936-2510-001) Logo
152 people viewed this question
Top Efficient Networks Computers & Internet Experts
pongta rajkumar
pongta rajkumar
Jeffrey Groves
Jeffrey Groves
Duncan Mutch
Are you an Efficient Networks Computer and Internet Expert? Answer questions, earn points and help others
