Question about Kenmore 22422 Top Load Washer
Frozen My washer is located in the shed kitchen which is basically a back porch w/ no heat and it freezes up on real cold days and night but I have nowhere else to keep a washer and dryer. what a way to defrost whatever freezes because it's not the hoses. or water lines into the washer?
Ok " could heat tape the water lines comeing in.
works on pipes for winter
Posted on Jan 22, 2008
Water will not come on in faucets, it was running just a few minutes ago now nothing, checked and no burst pipes. Could a pipe be frozen? we have had below freezing temps for days.
yes thing to do is to remove the aerator's
from them open them up and see what happens. don't close them cuz if it's warming up we hope... it'll help them flow better to get the water moving thru the pipes.
if it is just one open the vanity doors, or any doors that contain the fixture plumbing. let some heat get in there.
is water ok running in other areas? or whole house?
Jan 07, 2018 | Water Water Heaters
Hot water in kitchen only froze
good idea to let the cold water to run a bit to stop freezing up . Pity that you didn't do the same with the hot water. There is only hot water in the tank but the water in the hot water pipes will freeze as the heat goes out of the pipes. (Always to have to wait for the hot water to come through when you use the shower or bath.) The water will freeze up right back to the hot water tank
Jan 29, 2014 | Cars & Trucks
Washer fluid wont work
Start with basics. check if resevoir is empty. most likely a frozen nozle. Maybe a frozen, blocked or kinked/broken hose. If you are in cold area, warm up car in garage add washer fluid with low freeze temperture. If not froze; look up diagrams online and check hose, filter screen in resevoir, and tip of nozle.
Dec 13, 2013 | 2003 Mercury Mountaineer
Kenmore 13 (1989) model 253.9103221 has been unplugged and safely stored flat in an non-climatized shed for seven years. I plugged it in outside in the carport, night temps getting in the high 30s low 40s....
Moving it inside will most likely fix the problem. The thermostat is often located in the frige side, so it's basicly too cold outside for the unit to run right.
Oct 26, 2013 | Whirlpool Refrigerators
I have a kitchen aid superba side by side black with ice maker and water dispenser. Questain is I have it outside plugged in, during the day sun is on it, will this affected the feezer side from keeping...
yes, the insulation in the fridge is not designed to handle that kind of heat, and it being black only compounds the problem. eventually the refridgerator will overheat and fail. it doesnt need to be in the a/c, but it does need to be out of the sun
Sep 26, 2013 | KitchenAid Kitchen Aid Superba Series...
Why does my AC keep freezing (Carrier FB4ANF036). I have replaced the blower motor less than a month ago due to the same problem. Just last night we had a lightening storm and shortly after that the AC...
if your system is a heat pump you can switch to heat and see if coil outside gets cold while indoor blows warm air - then switch back to a/c - both coils should not be cold at the same time - low freon pressure / dirty coil / dirty filter / low air flow causes freezing
Sep 22, 2009 | Carrier Heating & Cooling
Not really cold, Defrosted it and put everything back from the coolers and the water btl on the door hasn't frozen all day. The frozen meats are holding their own and staying frozen but not real cold in...
u've brocken the coolent circulating pipes which v;ll be surrounded in the freezer box....!! due to the leakage of compressed gass....its not getting cold,.
thnak u sir...
all d best, have a great day
Jul 18, 2009 | Freezers
water is frozen in your hoses. defrost hoses
Feb 09, 2007 | Kenmore 24722 Top Load Washer
Kenmore 22422 Top Load Washer Logo
71 people viewed this question
Sal De
 Brian Main
Brian Main
