Question about Conair GMT182CS
Wattage im overseas and need to know if the wattage is under or over 50 watts thanks travis
  • 619 Answers
Hi, wattage means strenght of brigthness of bulb or the electricity consume by the machine .
Posted on Jan 22, 2008
What does 50wx4 mean? i am trying to find speakers for the rear deck and don't know what wattage the radio puts out
There are four outputs rated at 50 watts each. You will need speakers rated at 50 watts or more to handle maximum output without distortion.
Dec 12, 2016 | Cars & Trucks
What is the rated wattage for the mastercraft drill
the wattage is on the plate attached to the drill and will still be the same as before you attach a step down transformer to get to the correct voltage
get a step down transformer that has a large wattage rating for 120 volts ( say 1200 watts ) as most 1/2 drills are 750 -1000 watts )
the wattage is for the rated current through the transformer and if the drill is of low wattage , it just gives the transformer a greater degree of serviceability in the duty cycle
Nov 16, 2015 | Audio Players & Recorders
Will Freezer run overseas on a transformer?
Step Down Voltage Converters You can use this link to find a converter that should work. There are several other sites as well. You need to get a converter with enough wattage capacity to operate the freezer. I recommend you get one with a somewhat higher wattage rating than the freezer's wattage rating. For instance if the freezer is rated at 700 watts, I would get at least a 1000 watt converter. Good Luck !!! and Bon Voyage !
Mar 30, 2014 | Kenmore 7.5 cu. ft. / 212 liter Upright...
SINGER Futura XL-400
230 V @ 50 Hz; 64 W for European version, so 0.27 Amps ; if you're in the US, just call a retailer and ask them to read the voltage and wattage or amperage off the nameplate of the machine. Watts = Volts x Amps. Since US voltage is 110, 64 Watts would mean the machine was drawing about 0.6 Amps. That's assuming it's an equivalent motor to the European version.
Feb 12, 2014 | Singer Sewing Machines
My problem is that Model 16N5-K, 120v 60Hz 12 amp Bissell Vacuum cleaner has no wattage indication in the unit itself, in the box, in the product brochure. our power output in the Philippines is 220v. I...
All the information you need is in your text :>)
Volts, Amp Watts To determine the wattage, use a simple multiplication formula. The ampere (or amps) is the amount of electricity used. Voltage measures the force or pressure of the electricity. The number of watts is equal to amps multiplied by volts.
How to Calculate Wattage (Formula and Tools) - wikiHow
To find a step down transformer for 1440 watts, you will buy a new vacuum cleaner cheaper.
volts amps watts equation Google Search
Oct 01, 2017 | Vacuums
How to check if my power supply is already not ''at the limit''?
1 or 2 extra hdds and ram does not require much extra power and your coolmaster should do the job. But if you intend to use a newer graphic card you should check the requirenments for wattage at your new card manufacturer product specification webpage. I am pretty sure that almost all newer graphic cards require at least 500 watt to run without problem. My advise is to buy at least a 550 watt psu although i don't know what is your hardware. Try to post your hardware specs and calculate for each component (cpu wattage+graphics wattage +etc) your power supply need to be over 50 wattage. Hope that helped!
Mar 22, 2010 | Cooler Master (RS-430-PMSR/P) (RS430PMSRP)...
1 watt,Service Manual I have says RK42 3.3ohms RK46 1.8ohms RK50 2.7 RK54 1.5 RK58 3.9 RK62 2.2
Dec 30, 2009 | Hitachi 50FX20B 50" Rear Projection...
Volume wont go past 50
this sytem is unable to go past 50 and because its only 80 watts it wont get louder.
80 watts is divided by all the speakers
so a 5.1 system gives 20 watts to the woofer and 15 watts to each of the other 4 speakers.
plus its in rms (root means square)
which means you loose some wattage in fricton so take another 25 to 50 % of the wattage.
so all this said you get what you pay for.
Apr 21, 2009 | Durabrand 5.1 Surround Sound Computer...
My low voltage landscape lights are constantly going on and off once the timer activates them initially. I suspect there is a short somewhere, but is there a good way to locate the short besides pulling up...
Your transformer must have output greater of the total wattage required of the entire system. Example: Putting lights that draw a total of 250 watts with only a 180 watt transformer will result some lights not working, or dimming and flickering, or intermittent power outtages. I learned this from experience. Always go with a transformer that has more wattage available than what is needed. Also, using the incorrect gauge of wire can cause the same issue. Wire creates resistance. Distance the power must travel through the wire creates more resistance at the end of your run than the beginning.
Mar 29, 2009 | Garden
The output power for model MA-780 was 700 watts, so I'd bet yours is either 600 or 700 watts.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jan 02, 2008 | Goldstar MA-782M Microwave Oven
Conair GMT182CS Logo
54 people viewed this question
Top Conair Health & Beauty Experts
Are you a Conair Health and Beauty Expert? Answer questions, earn points and help others
