Question about Sony KP-41T65 41" Rear Projection Television
Kp-57ws500 sony projection tv convergence problem
Hi, I have a kp-57ws500 sony projection tv with a convergence problem. I know this because I have fixed another samsung tv with the same problem. The only thing is with the samsung I just replaced the whole board. I was wanting to just go ahead and try to replace the ic's myself. I have found directions on how to do it and I think I have a good shot at it. If not,what is the part number for the board? I can't find it online. The one bad thing about the whole situation is that I have no experience in soldering. Do you think I should just replace the board?
  • priorityone Aug 24, 2008
    i have my board out to replace ic's and i also need to replace the pico fuses....but i'm not sure that my set have any..there is 6 resisters that are cream color under the heat sinks with a mark on them 120u y3j-27f i'm not really sure if these are the fuses ..help me please
    Filmmaker:
    Uploaded 5 video answers.
  • 162 Answers
Your convergence has failed and needs to be repaired. Once quick test is to goto your convergence menu and see if you can adjust red and blue. If not its has failed and needs to be fixed. You can call in a repair shop or you can get the parts and instructions from www.TvRepairKits.com and do the repair yourself. Its a fairly easy DIY fix.
Posted on Aug 11, 2011
    President:
  • 4,402 Answers
Sony convergence problems
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Sony Convergence
http://www.techlore.com/article/19631/Sony-Convergence-Procedure/
look for the board that has heavy heat sinks on them the ic will be stk392-XXX
no experience in soldering i would send the board into ptscorp.com and have them repair it.
Posted on Jan 22, 2008
2 Suggested Answers
  • 8457 Answers
SOURCE: I have a KP-57WS500 57 in. Rear Projection
No,U have solderwicks?U can buy it,in any Radio Shack store.Use solder iron on top of the solderwicks to soap up the solders out ICS pins.Replaced the ICS use any kind solders just resoders ICS back to the heatsink.Tries Websites Tv repair World.com,Tv repairkits.com to buy a complete convergence kit.
Posted on Mar 06, 2010
I have a sony kp-57ws500 and the images are randomly destorted now, looks like they are almost 3d.. red blue black yellow and green. help me please
Your TV has whats known as a convergence failure which is common. You will need to find and replace the convergence parts to fix it. You can get the parts and step by step instructions from sites such as www.TvRepairKits.com
Jan 16, 2012 | Sony KP-57WS500 57" Rear Projection...
Can I manually adjust the convergence on a Sony KP 57WS500
that model has an auto focus so if thats not correcting the issue then the ICs will need replacment. The sony type 1 convergence repair kit from www.tvrepairworld.com should solve the issue.
Feb 22, 2011 | Sony KP-57WS500 57" Rear Projection...
My tv is a 57ws500 and the picture is shadowed by red color and can't seem to get the red out. what do i need in order to have picture in excellent working order?
Ur convergence is dead.Must know how to solders?Must replaced 2 STK convergence and some or all it resistors.Tries Websites Tv repair World.com,Tvrepairkits.com to buy a convergence kit to repair it ur self.The shop will cost u $300 for parts and labors.
Mar 17, 2010 | Sony KP-57WS500 57" Rear Projection...
Mar 06, 2010 | Sony KP-57WS500 57" Rear Projection...
Have Sony KP-57ws500 rear projection i had the bulbs replaced 3 years ago now itseams as if everyting is out of focus.images outlined in green and red.
It sounds TV got convergence out ICs failure problem and causing 3D image or outlined picture.
There are 2 convergence out ICs mounted on D board in TV that need to be replaced.
Let me know if you need part number of ICs if you want to replace by yourself or call local Tv tech to fix it.
Thanks.
Dec 04, 2009 | Sony KP-57WS500 57" Rear Projection...
Tv turns on but has a shadow around evrything
Do you have any speakers or magnets next to the tv? If so, that is not good.
It may be a convergance issue. Check to see if you have any adjustments on the back of your tv to adjust picture. If not, if may be a faulty capacitor that needs to be replaced
Jul 02, 2009 | Sony KP-57WS500 57" Rear Projection...
Double vision in red and green
Its failure of convergence ICs and will be replaced.
Convergence ICs are mounted on silver heat-sink on D board of TV
Let me know exact model number to help you with more technical info.
Mar 21, 2009 | Sony KP-57WS500 57" Rear Projection...
Sony kP-57ws500 picture is distorted not right
It calls convergence problem due to failure of convergence output ICs.
If you want to repair it at your own, let me know if you have basic electronics knowledge and little experience to guide you more.
Nov 08, 2008 | Sony KP-57WS500 57" Rear Projection...
Major problem with sony kp-57ws500
BTW if you appreciate the help I have given you, please rate me! Thanks!
Oct 25, 2008 | Sony KP-57WS500 57" Rear Projection...
Sony KP-57WS500 57 inch TV
Probable convergence IC failure = replace both for reliability..T.
Nov 24, 2007 | Sony KP-57WS500 57" Rear Projection...
Sony KP-41T65 41" Rear Projection Television Logo
1,002 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
