Question about GN Netcom GN 9120-28 Wireless Headset
GN 9120 Headset & RHL
Thought the internal battery wouldn't hold a charge, so replaced that and charged fully. Still, with use of RHL w/ headset, RHL lifts, battery fully charged on headset, on-line indicator is lit but when using headset, I get no dial tone at all....missing my headset capability a lot....can you help??? Thanks!
  • 4 Answers
SOURCE: No sink?
Yap i did solve the issue, thanks
Posted on May 28, 2009
0 characters
1 Points
Is a replacement battery available for 9120 I've used for a number of years?
GN Netcom probably would know. If you can identify the battery type, you can try obtaining a replacement from some other source.
Jul 07, 2014 | GN Netcom GN 9120 Professional Headset
Nakamichi wireless headphone nw6000 beeps every 5 sec while using in wirelss mode. but when used with a direct audio jack it works fine.
battery is flat and will not re-charge, pries apart headband from body, locate two tiny screws holding battery in and remove by sliding
change battery and allow to charge on base for a full 24 hours
May 22, 2014 | GN Netcom GN 9120 Professional Headset
Battery for GN9120 is not staying charged; what can I do?
The battery is no longer charging just like your car battery only lasts for so long and then dead no matter how long its been on charge
try and get replacement if not should think about a new headset
Aug 28, 2009 | GN Netcom GN 9120 Professional Headset
I can not get my headset GN netcom 9120 to sink-up with the base
this has not synch up keep headset in cradle and remove power at mains plug or power lead from base count to 5 and replace power if no flashing is seen then you might have to repeat the same procedure a few times for synch to happen
the only other reason for no synch is battery in headset is not charged enough
Aug 08, 2009 | GN Netcom GN 9120 Professional Headset
No sink?
May 27, 2009 | GN Netcom GN 9120 Professional Headset
Battery Light Won't Go Solid. Lot's of clicking sounds and lights flashing (GN Netcom 9120).
It sounds like it may be a defective unit in that the charging points on the base and the earpiece are making intermittant contact, hence the clicking noise you get when the unit goes into headset mode and the fact that the battery never reaches a fully charged status.
A couple of things to try:
  • Check the charging points/contacts on the base and the earpiece for damage.
  • If they look ok, gently clean them with some spirits and try again.
Nov 07, 2008 | GN Netcom GN 9120 Professional Headset
Cannot hear anything out of the earpiece of my GN netcom 9120 wireless headset
I was also experiencing the same problem (also after a power failure / storm) -- apparently good battery charge, connections ok, etc. I then tried removing the battery from the headset itself, waited 30 seconds, and then reinstalled the battery. This seems to have resolved the problem.
It is fairly easy to open the clamshell, but you will need a very fine Phillips screwdriver to remove the battery hold-in (it's really not a hold-down, it just keeps the battery in place. Reassemble the same way -- be sure to keep positive to positive and negative to negative.
Sep 01, 2007 | GN Netcom (9120-48) Wireless Headset
GN Netcom GN 9120-28 Wireless Headset Logo
37 people viewed this question
Top GN Netcom Headsets Experts
Steve Morris
Steve Morris
Level 1 Expert
Tom Chichester
Are you a GN Netcom Headset Expert? Answer questions, earn points and help others
