Question about Home & Lifestyle Software
Reinstalation of mcaffe
Ive mccaffree software with I bought with Dell. I have warning that there was na error when updating mccaffee. I need reinstalation
  • 265 Answers
Re: reinstalation of mcaffe
Your software can be diagnosed and / or repaired by McAffee for free. Go to their Support website:
Posted on Jan 22, 2008
Posted on Feb 25, 2008
0 characters
3 Points
Program shuts down when starting if for the 2nd time.
The game must have been corrupted.
The only way is to uninstall it then reinstall it again.
Also make sure that your pc meets the system requirements to run the game. Free up your disk space too, before you reinstall the game.
Jan 02, 2010 | Dell Mickey Mouse Preschool (Ages 2-4)
When I download Flipshare software for the first time I get a message reading That there is a problem with this installation package. A script required for this install to complete could not be run,...
try to check your hard disc for errors, you do it in this way ; Highlight your hard drive (normally it is C:), you find it in My Computer, right click on it and choose properties, select the second tab and choose "check this drive for errors", apply all the possibilities and press ok and restart the computer. Let the program run and then try again.
For be completely sure then you have to download the setup file again and reinstall it, you do it in this way : remove the software in Add and Remove programs in Control Panel, reboot the computer and install it again.
Then try to run Ccleaner,
Please see my article here on how do you use Ccleaner :
Defragment you hard drive, you can use Defraggler here, that is better than windows own integrated :
Portable (USB, no install) version you find here :
Now you have done all the possibilities, and your computer should be in good condition, but only one thing here, Your are Running onservice pack 2 !!??, you should update your machine at least to service pack 3, you find the updates in Internet explorer under the feature Tools (Windows Update), select it and follow the instructions on the screen, then choose quick search here and install the updates it find. You need to run it until Windows Update write "there is no more updates/ 0 updates".
One last thing, Is it windows xp 64 bit you are running or 32 bit ??, not all the programs are running under 64-bit version
Hope that helps
IF NOT then try to return here
Have a nice time over there
Dec 28, 2009 | Home & Lifestyle Software
If I download my Quicken 2010 does it load my quicken material that I have now???
Short ans "YES".
Warning.!!! Not all do what they are supposed too?
Always Back up your data/files you wish to continue too an alternative indepenant sorce.. Then start your "New" install.
Treat it as an Update Download, they give you the new prog and assimilate data already on the Poota?
Nov 13, 2009 | Dell Home & Lifestyle Software
When my daughter plays sims the screen goes pixelated and an error appears she can not save her progress and has to shutdown
i need detailed info abt ur system, to solve better..
howevr try reinstalling the software..
try increasing virtual memory..hope ur using licensed and updated antivirus and there is enough hdd space esp on drive, install and run microsoft kb890830..
try reinstalling the os, if above fails..
the RAM(s) may b faulty too..!!
contact ur system admin/vendor....
Oct 29, 2009 | Home & Lifestyle Software
Welll thanks 4 such good help....welll.. ihave an acer extensa 4630z.. and it has win xp on it....its just been 2 months i purchased it...well...and it has 1 gb ram expandable to 4 gb....what would it...
You can check prices for ram on, but the price ranges from $30 to $45 for each GB of ram. So the cost to you would be about $100. Yes, your Windows is genuine, most likely unless you bought it from some secondary source like Joe's Computer shop, who could have used a pirated copy. I have a brand new Sony and this same problem happened to me after an update. If you click on the window that tells you that its not genuine, there should be a link there that allows you to contact the Microsoft website. The website will check the system and take away the warning if it deems it ok after the check. If you did this already and it still has the problem, then it means that the validity checking software still thinks you are on a different machine (in error, of course). Since you bought the machine from a major manufacturer (presumably), that would be an issue that they would be responsible for, not Microsoft, since its an OEM software issue. If you bought the Windows from a box at a retail store, then it would be something that you would go directly to Microsoft for. On my machine, I went to the Sony support website and looked up the info for my exact model and they had a download fix for the problem.
Sep 16, 2009 | Home & Lifestyle Software
I have apple software update on my computer. I used it to download itunes + quicktime 8.2.1. It had a problem and a window came up saying to select download only. Well, I did and it's done. But now it says...
The software should have a list of the Apple products that you own that can be updated by the Apple Software Update. You need to select the product from the list, and then it will give you the option to Install.
If, for some reason, the software is not working correctly, you can always reinstall iTunes
Aug 04, 2009 | Apple Home & Lifestyle Software
Cant get rid of Error 15103 Document Viewer
Error 15103 error symptoms can include program lock-ups, slow PC performance, system freezes, shut down and startup problems, and installation errors
uninstall regcure uninstall ccleaner and then cold start the pc reinstall quickbooks .....reboot
good luck
Apr 05, 2009 | Intuit QuickBooks Premier Accountant...
It may not work at all on Vista, many programs and hardware do not. (scanners and printers etc. -- no new drivers)
Is there any way to update the program?
Go to the company website, check for Vista compatibility.
You may have to purchase an updated program.
Nov 13, 2007 | Zondervan Bible Study Library: Family...
Error message and texture problems
I found I needed to change the user to a Power User and it solved the initial error problem.
Dec 08, 2006 | Punch Professional Home Design Platinum...
Home & Lifestyle Software Logo
225 people viewed this question
Top Home & Lifestyle Software Experts
john smith
Are you a Home and Lifestyle Software Expert? Answer questions, earn points and help others
