Question about Frigidaire 24 in. PLD2850 Built-in Dishwasher
Dishwasher won't start
My dishwasher won't start the light is on and the setting is correct it just flashing
  • 1 more comment
  • snappahead Jan 23, 2008
    I am having the same problem. The lights flash but the cycle will not start. This happened out of the blue and the unit is under three years old.
  • elloco160 Feb 26, 2008
    turns on but will not wash it just blinks
  • kmikes Jan 17, 2009
    I had the same problem, brand new Fridgidaire dishwasher, used only about 4 times just stoped working. I pressed start and the light lit up but no sction; the water didn´t start to fill and the motor didn´t turn on. I read the suggestion mentioned above and checked if something was obstructing the arms ( I spun them around a few times and nothing seemed to be in the way). And voila! I closed the door and it started right up. Maybe the controler thought something was in the way.
It's the switch in the handle. I just took the black panel off and disconnected the wires to the switch and reconnected them and it is fine for today.
Posted on Feb 01, 2008
Check to see how it's loaded. If something is obstructing either of the spray arms it will not start. I had this same problem and checked to see if there was something impeding the arms - I found there was. Reloaded the unit and it's running like a champ now!
Posted on Feb 09, 2008
  • aj74 Feb 14, 2008
    The dishwasher went on the fritz again. I took the control module off the door (just undo the screws) and found a service repair data sheet just inside the door - this gives you all the possibilities of the problem when the lights are blinking. I ended up replacing the latch assembly. I ordered the part from and it came it 2 days. I was also under $30 for the part and shipping. It's simple, takes literally 10 minutes to install and it should solve your problem.
My problem was get this... ANTS! Apparently ants had gotten inside and disrupted the contact. I just had to clean out the ants and voila!! Put Bay Leaves around the unit to discourage ants(they hate the smell).
Posted on Jan 31, 2008
I have the same problem. The dishwasher isn't even a year and half old. It ran fine yesterday, but won't start now. If you figure out the solution, please post it. I will do the same.
The CLEAN light is flashing on my Kenmore QuietGuard3 , but it won't clean anything. It starts a cycle for a few minutes, stops and starts flashing clean again. Any suggestions?
You will have to reset the dishwasher. First try and turn off the mains power and back on after a short time. If the clean light flashing starts again then you go through the hard reset procedure.
press NORMAL WASH then HEATED DRY buttons one after the other until all the lights on the board lit up (3X's). The dishwasher will enter into a cycle; Press Cancel. This should stop the flashing.
If you are supplying dishwasher from hot water inlet then make sure the inlet water temperature stays within the recommended range of 145 deg F.
Apr 21, 2013 | Dishwashers
Whirlpool dishwasher model Gu2548XTPS7, clean light flashes 7 times and won't start.
Check, if you have water in the machine, if yes, your control board could at fault
Mar 20, 2013 | Dishwashers
I have a whirlpool adp6600 dishwasher. the green light just keeps flashing (i think it's 7 times in a row each sequence) and the cycle won't start. have tried turning it off at the wall, clean
Dishwasher is in fault mode hold start/pause button for a few seconds this will reset the unit run your cycle again if dishwasher faults again call you local service man.good luck
Aug 02, 2012 | Whirlpool Dishwashers
Lights flash on dishwasher but it won't turn on
maybe a problem with the sensor 'door open/door close' check if its dirty or stuck if mechanical. press door to close and hold tight close while starting to identify.- or no sufficient water supply- or used water cannot drain out
Jun 15, 2012 | Frigidaire Dishwashers
Clean light keeps blinking; dishwaher won't turn on
Hello Brian, welcome to FixYa.
Based on your post I understand your dishwasher is a Kenmore and the clean light is flashing and it won't start, correct ?
If so, this is usually an error code indicating there was a problem in the heating process the last cycle it ran, however if you could provide the complete model number I could speak specifically to whether it applies to your machine and potentially what to do about it.
Thank you for choosing FixYa and I look forward to your reply.
Macmarkus :)
Oct 12, 2011 | Kenmore Elite Stainless Steel 24" BuiltIn...
My dishwasher ( 66517269400) won't turn on. Circuit is fine. It is getting power. I replaced the fuse. Clean light is flashing 7 times. Manual says "dishwasher has malfunctioned. Call for...
The F7 error code(light flashes 7 times) is a one of these, Flow meter failure. Flow meter defect. Water inlet valve defect or water inlet hose blocked.
So what you need to check is if the correct water level is in the tub,to check that start d/w let it fill and once you longer hear water entering,open door and the water should be level or just above the heat element, if not enough water first check water pressure to inlet valve,if pressure is good replace the water inlet valve part # 8531671 it could be picked up from your local appliance parts store,or online at;
Aug 20, 2011 | Kenmore 24 in. 17269 Built-in Dishwasher
Hi I have a Whirlpool dishwasher ADP5740, Condenser. My grandson pressed the start button before I had set a programme, now the light is stuck on the pre-wash and the start light is flashing and it...
If you have a reset or cancel button try that. Look in your manual for a reset
procedure or troubleshooting section. It is just stuck in a cycle and needs to be reset
or cancelled.
Marty Mouse just a housewife.
Jun 05, 2011 | Whirlpool 24 in. GU3200XTP Built-in...
Washing indicators light is flashing and dishwasher won`t start
try to start again while applying closing pressure {push in} at the top of door where latch mechanism is if it starts then it's an adjustment that needs to be done on the door latch
Feb 20, 2009 | Frigidaire 24 in. FDB1050REC Stainless...
Frigidaire 24 in. PLD2850 Built-in Dishwasher Logo
2,602 people viewed this question
Top Frigidaire Dishwashers Experts
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
