Question about Electrolux EW1200i Front Load Washer / Dryer
Fills with water slowly when not in use
The nachine is constantly slowly filling with water, this means that I have to set it to drain istelf before onpening and also renders the dryer unusable
  • Andrew993 Jan 23, 2008
    Thank you!!!, valve cost £14.00 and machine is now as good as new.
  • 139 Answers
You have a faulty solenoid valve..
At the back Where the water inlet pipe connects to the machine, the valve it connects too is faulty order a new one and replace it yourself... al you have to do is remove the top to get to it.. and its straight forward ......
Hope this helps any questions dont hesitate to ask ....
Posted on Jan 22, 2008
  • Shaf Ahmed Jan 23, 2008
    I really should get a fixya for that ...no worries there is more to life....
6ya staff
SOURCE:
Dishwasher slowly fills after cycle
If water slowly fills in the tub when not in use.
a) Most likely your machine inlet water valve not seating properly and closing. Change the machine water valve.
b) May be sink drain water back flowing to the tub. But you have checked that.
So it has to be the machine inlet water valve.
Apr 11, 2015 | Whirlpool Dishwashers
Washer continuously fills
Not sure if you mean that it fills all the time and overflows or you mean that it just always fills and never has enough water.
The first problem would refer to a faulty water level switch - need to replace.
The second would be that the washer drains as it fills - if the drain hose is lower than the washer, inspect the anti-siphon valve.
Apr 10, 2014 | Maytag PAV2300 Top Load Washer
Washing machine constantly fills
The pressure switch, also called the water level switch, is what control the amount of water goes in the machine, If your machine is constantly filling to the overflow point, then that is your problem. Now, if water is going in and the level is staying the same then your machine drain line is lower than the pump and your siphoning out the water as it goes in. Pull the drain up a little a that should fix the problem.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
May 08, 2012 | Whirlpool Clothes Washer Water Level...
Toiley cistern continually fills up but never reaches full because the water continually empties down the bowl slowly
check flapper for proper seating or cracking if water constantly draining into bowl
Nov 15, 2009 | Home
Washer drains then spins then fills again and drains but no spin
Try this, unplug washer for two minutes, plug back in, open and close lid seven times slowly, this will reset the computer and the electronic motor. Also on water level switch, make sure hose from switch to tub is not plugged, blow it out, gets clogged with soap.
Sep 09, 2009 | GE WBSR3140DW Top Load Washer
Gets to the spin cycle and does not spin and drain
What is error code?
Does unit spin?
Does unit drain?
Does unit fill on all water settings?
Ie set to hot, warm, and cold and see if fills.
Jul 14, 2009 | Frigidaire GLTF2940ES Front Load Washer
Washer Fills/Drains at the same time
check that the drain hose saises above the water level of the tub. I f the hose does not come above the water level, the water will just drain right out
Dec 01, 2008 | Whirlpool LSB6200KQ Top Load Washer
Washing Machines slowly fills with water over a few days
could be leaking inlet valve or if drain is plkumbed in unbder sink, could be filling thro drain pipe when you emptyt sink
Mar 17, 2007 | AEG Lavamat 16810 Front Load Washer/Dryer
Electrolux EW1200i Front Load Washer / Dryer Logo
Top Electrolux Washing Machines Experts
Gerry Harvey
Gerry Harvey
jimorris77
Poppa Maddo
Poppa Maddo
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
