Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
Help with tv
We can get the movie to come up on th screen , but cant get the main menu to clear from the screen. Then if we push a button to see if it will come off , it automatically will go back to regular tv . One more thing i dont have the remote for the tv , its universal the one that iam using .
  • 84 Answers
RCA controls everything from the remote control. Unfortunately you will need to purchase the original remote from the manufacturer or an authorized parts retail supplier.
Posted on Feb 10, 2008
Cat stepped on remote TV went black have sound but no picture i have tried every menu option?
Try doing this:
Self-check indication only:
Produce TV reception screen, and while pressing [VOLUME ( - )] button on the main unit, press [OK] button on the remote control
for more than 3 seconds.
Self-check indication and forced to factory shipment setting:
Produce TV reception screen, and while pressing [VOLUME ( - )] button on the main unit, press [MENU] button on the remote
control for more than 3 seconds.
9.1.2. Exit
Disconnect the AC cord from wall outlet.
This is straight out of the service manual.
Joseph Van Buren
Aug 01, 2014 | Panasonic TH-42PX75U 42 in. Plasma HDTV
I cant get the menu to leave the screen. I dont know what button to push.
Hitting the menu button again will clear this off most of the time. Make sure you are using the correct remote. If it is the cable menu use the remote that came with the cable box. If it is the tv menu uses the original television remote control. This can also be taken care of with the buttons on the television itself. Should be a menu button on the side or bottom.
Apr 02, 2014 | Dynex Televison & Video
Turn your television and Apex DT250 receiver on.
Push the "Menu" button on the Apex DT250 remote control.
Press the remote's "Up" and "Down" buttons to scroll through the menu options. Stop when "Parental Controls" is highlighted. Press the "Right" button to select this option.
Enter your four-digit password. If you have not set your password, use the default code of "0000."
Use the "Up" and "Down" arrows to change or set the parental control movie ratings. You can select from "None," "G," "PG," "PG-13," "R," "NC-17" and "X." Once your setting is highlighted, press the "Right" button to go to the next screen.
Use the "Up" and "Down" arrows to change or set the parental control TV ratings. You can select from "None," "TV-Y," "TV-Y7," "TV-G," "TV-PG," "TV-14" and "TV-MA." Once your desired setting is highlighted, press the "OK" button to save your settings. Once the settings are saved, you will be taken back to the main menu. Press the "Exit" key to exit the main menu.
Oct 31, 2012 | Apex Digital PF2020 20" TV
I am deaf and must have subtitles (Closed Captions) when I view DVD movies, which I buy, rent, or get from the library. I have 3 DVD players, all set up to show CC. 95% of the time there is no problem. ...
Movies said have CC close captioning sometimes just an add on print.Must go to the movies main Menu.To see if it have a Title on the main menu said SUBTITLES English,Spanish or French.Press that SUBTITLES to get close captioning printing words on the screen.But if u push the underline word said SUBTITLES,nothing is showing up on the screen,than the DVD movie disc have a problems or the add on print said CC is a lies.That the world for u,nothing are 100%.
Dec 04, 2010 | Samsung Televison & Video
Picture on screen is narrow and I cannot select normal view
use menue button on tv if this does not work change main board in tv
Jun 05, 2010 | Panasonic Viera TH-42PZ80U Plasma TV
I have a comcast Motorola HD capable cable box with DVI output - going through a converter cable into an HDMI input. When I change from a hi def channel to a std def channed, the screen gets split, and...
Here sounds like your override setting on cable box needs to be set.
Here is how to fix that-
1. On remote push the button at the top that says CBL or Cable.
2. On remote push power button.
3. On the remote push the menu button.
This should bring up an internal menu called user settings.
4 Use the remote to scroll down to 4:3 OVERRIDE and use the LEFT or RIGHT arrow keys on the remote to change the value to 480i and see if this clears up your problem. If not repeat and change the setting to 480p and one of these settings should fix your problem.
Good Luck and please rate this solution.
Jan 04, 2010 | Panasonic TH-42PX60U Television
Cant get the subtitles of the screen been pressing the subtitle button thanks.
Are you sure they are subtitles rather than closed captioning (if it is TV rather than DVD, it is closed captioning)?
If it is closed caption, pressing subtitle won't turn them off. If there is a button that says "Closed Caption" or "CC" press it. If not, press menu and look for the CC option (it should be under video or audio depending on the TV). Turn it off.
If you are watching a foreign language movie on TV (not DVD) it is likely hardsubbed (you can't turn the subs off because they are burned into the video).
Sep 19, 2009 | Panasonic TH-42PWD3 42 in. Television
My monotor its all black but u can
This should be an (LCD) screen. They are the ones that usually have this kind of problem. You will need to take it to have it checked if the problem is the VGA signal cable leading to the monitor. They will check if it is properly connected or has gone bad. It is very unlikely that the screen is bad. When this VGA signal cable goes bad it could result in a totally blank screen.
Sep 13, 2009 | Dell Computers & Internet
Panasonic Viera TH-42PX600B, menu and channel info
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here.
Jul 10, 2017 | Panasonic VIERA TH-65PV500 65 in. Plasma...
1080p Prob with TH-50PE700U
try diffrent hdmi cable, sometimes with this new digital stuff there are compatibility issues, not common, but not unheard of
Feb 20, 2008 | Panasonic (TH-50PZ700U) Television
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
42 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
