Question about Apple iPod nano
Battery charging When I charge battery, on the screen it still shows as normal (with charging sign and "Do not connect" line). But it charges for 6 hours already (plug into a PC and the computer is working). The screen still ahows that it is charging. I don't know if it's charged or not yet finished. Please help. Van
    Problem Solver:
  • 14 Answers
Try a nother charger if you no any one with a apple ? if not look at the voltige and perches a multy charger from argos
Posted on Jan 27, 2008
Toyota prius problems
hi there, my Toyota Prius 1999 hybrid car shows tortoise sign after running on highway, and the screen shows low charge/almost empty( empty yellow color battery ), then it starts charging again and back to normal charging level and become green, I come across this when I drive on motorway or after finishing high speed zone. can anyone explain it?
Jan 01, 2014 | Cars & Trucks
My Samsung galaxy tablet 7.0 died out while im playing a game, when I tried to recharge it a battery icon with caution sign show up. It does not recharge anymore. Tried another charger of my other Samsung...
Connection on tablet from charger to battery is not being made and that is why it is not charging in one unit but charging in other. Till problem is resolved charge battery in other working unit.
Aug 28, 2017 | Tablets & eReaders
My blackberry curve 8520 is at low battery and wont charge or show the charge lightning bolt
King, many times this happen, don't worry, put your device on charge 2 to 5hours it will solved, if problem persist, change battery, because this sounds me a only battery problem. there is one another way (if you are not sure don't try this) we call that direct charging
first take one charger who has light on head and then cut the charging connector of charger and then you will see two colours of wires separate the black and red wires (red wire is positive line and black is negative line) and then connect to current supply but make sure there wire are separated otherwise it will have a short circuit and then take battery and search + and - connector and then red wire connect on battery positive connector and black on negative connector if you connect properly you will see the charging light are getting dim. that mean it is charging, do direct charge for 10 min and then switch on your device with battery and put in charge normally. this will solve your problem. if my sugetion was helpful please rate it.
Jul 02, 2012 | RIM BlackBerry Curve 8520 Smartphone
Hello, I have a Marquette Mac 6. recently the battery went dead and we just replaced it. but now after replacing it still says the battery is 0/50. I went through the instruction manual and followed all...
hi,
You have to chek the battery charging circuit of your Mac 1200. If the the charging circuit is faulty then the battery will not get charged. In all ecg machines AC line is used only for charging the batteries . Even though if you are connected the AC line the machine will work on battery. It uses a 18V 1.4Ah battery. To get this battery to full charge it need a charging voltage up to 20 to 21.5 volts. Connect the machine to the line and check the votage at the battery terminal. The volatge should gradually increase. If not then the charging circuit is faulty. You have to check the Inductor coil L3 and Thermistor R5 in the charging circuit board after removing the battery and power line.It shouid show an OHMS bellow 5 OHMS. Also you have to check the 24V input to the charging circuit from the power supply.
ok
Aug 10, 2011 | Ge Medical Systems Ge Marquette Mac 1200...
When i am putting charger in charging light is keep blinking and on the sign it says charger connected but not charging can u please tell me what is wrong.
When you point your mouse into the battery icon sometime it shows that it is not charging, kindly try to monitor it as it will eventually change into charging mode.
- normally this happens when the battery is fully drained.
May 10, 2011 | HEWLETT-PACKARD HP G56-122US Notebook
I tried to charge my Lg Ke970 today and it wasn't charging normally when I plug the charger in and connect it to my mobile it comes up with a battery sign but this time it kept on coming on and off and...
Hello, my friend had the same problem with his LG. He talked with the dealer who told him the battery was "dead". They had to "push" some electrical-shock into the battery, then it worked and the battery charged normally again=). Talk with the phone's dealer for help=) Good Luck! Regards, David.
Jul 08, 2009 | LG Shine KE970 Cellular Phone
Cannot charge
SONY NWZ-E436F DIGITAL media player | PROBLEM : my battery was low So i tried charging it by connecting the usb to my computer...it charges for 3-4 seconds till the time it shows do not disconnect the moment it shows connecting it shows the battery sign full.... i tried it again and now it has hung and i try to put it on it just shows every moment has its music...and the battery is still low i believe it doesnt go further
Jun 25, 2009 | Sony Audio Players & Recorders
Charging problem?
your firmware needs reflashing, take the phone to any mobile service center and have them do it for you.
Jan 30, 2008 | Motorola Mobility MOTORIZR Z3 Cellular...
Apple iPod nano Logo
171 people viewed this question
Top Apple Audio Players & Recorders Experts
Nagendra Baliga
Computer Repairing
Computer Repairing
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
