Acer aspire external monitor not responding.
I opened up acer icon for projector i think by mistake, when i closed icon on taskbar, external monitor no longer responds, my laptop screen was broken hence the external monitor, but now when i power off/on i cant get display on external monitor, i've tried toggle switch fn + f5/f6 ? I've tried connecting to tv which used to work as monitor also, but not now, is there a simple keyboard function to revert as it is only since i opened that acer icon on desktop ??
    Scholar:
  • 198 Answers
Sounds like an inverter problem. If the power supply is internal replace the capacitors coming out of the voltage regulators. These are usually 1000mf and/or 470mf. If that doesn't do the trick look up the numbers on the 8-pin chips that drive the secondary transformers on the inverter to see if they are getting the right voltages.
Good Luck!
Posted on Feb 20, 2008
My Netbook Acer Aspire One will not hook up to the LCD projector.
Connecting an External Monitor or Data Projector
You can switch to anexternal monitor or data projector by two methods.1. Connect the externalmonitor to the laptop's video port, power up the external monitor first and thelaptop. The video information will automatically switch to the externalmonitor.2. If you power up thelaptop first then you can switch the video output to the external monitor bypressing the Fn key and one of the Function keys, depending upon your make andmodel laptop. You can also toggle between the external monitor or both LCDscreen plus the external monitor or back to LCD screen only by pressing the Fnkey plus one of the function key. Here is a list of keycombinations for some of the laptops :-IBM ThinkPad = Fn + F7HP and Compaq = Fn + F4Toshiba = Fn + F5Dell = Fn + F8
Jul 24, 2012 | Acer Aspire One Netbook 8.9" Notebook
I have got acer aspire net book size is 8.9 inch. Ca i connect it to external monitor
Hi.
Sure you can with a standard VGA video cable.
Maybe you will have to change your screen resolution to get the best display layout.
Hope it helps!
Feb 10, 2011 | Acer Aspire One AOA150-1784 Netbook
My Acer Aspire 3610 is not sending an image to the EX30 projector. How can I fix that?
Use the FN key with the appropriate F key that has the screen icon on it to switch between laptop, external, both.
Aug 18, 2010 | Epson EX30 LCD Projector
Acer 5515 on external monitor
Get an VGA cable and connect your external monitor to your laptop via a VGA port that is usually used for digital projectors. In this VGA port, you can initiate dual monitors.
Then look at your keyboard and look an icon in your function keys (F1 to F12) that looks like a pair of an LCD and a TV like this {LCD icon/ TV icon}. In most laptop keyboards, this is located in F4.
When found, and with the external monitor hooked to the laptop via VGA port using a VGA cable, press and hold down the FN key and press the function key where the icons described above is located. Example, FN + F4 to toggle a single and a dual monitor.
Give it a try.
Jun 26, 2010 | Computers & Internet
I need to show Powerpoint slides from my Acer Aspire One netbook. When I connect to the projector it does not work. Why?
Have you pressed Fn+F5? It commands using external monitor/ projector. Try this:
1. Connect to projector with projector in ON position
2. Restart your PC
If it won't work:
1. Restart your PC, press F8 frequently, choose "enable vga mode"
May 01, 2010 | Acer Aspire One PC Notebook
Acer Aspire 3680 Cracked Screen *help*
Hi there
yes you can plug an external monitor to the laptop, the screen switch keyboard toggle is hold down Fn and is should one other the F keys with a monitor icon on it, just press that to activate the external monitor
Good luck and thanks for using Fixya!!!
Feb 11, 2009 | Acer Aspire 5050-3242 Notebook
How to disable mousepad?
normally the Fn and F7 key, it's the key with a finger on a square icon, or right click on the touchpad icon in taskbar>pointing device properties and select device settings and then dissable.
Sep 14, 2008 | Acer Aspire 3000 Notebook
Cant duplacate on extended monitor or on projector
Use your Q menu to select the "Internal and External" display. If this choice is not enabled on your Q menu, go to tablet settings and enable it there.
Feb 27, 2008 | Compaq tc1100 Tablet PC
Acer Aspire 3680 + View Sonic Projector
does it work with external monitor ?
the key should be Fn+F5 or Fn+F6
I believe you need to hold fn and press f5 to choose the target (lcd, monitor, lcd and monitor).
Feb 26, 2008 | Computers & Internet
Conect projektoer to the my laptop
follow the user manual
when u are done connecting and powering on your computer and projector, hold the fn key and press the monitor icon on your laptop's upper keys
this would transfer/share the image with the external monitor. (the projector is an external monitor)
Oct 13, 2007 | Acer Aspire 5630 Notebook
Computers & Internet Logo
751 people viewed this question
Alun Cox
David Payne
David Payne
