Question about Ricoh 3310LE Plain Paper Laser Fax
Ricoh 3320l DTMF tones
How do i turn DTMF tones on this FAX Machine please
  • 3 more comments
  • Anonymous Mar 20, 2014
    We have replaced the PCU on a Ricoh 3320L fax machine but the message, "Replace PCU" is still there and won't go away. We tried the manual reset also but the msg. is still there.
  • Anonymous Mar 25, 2014
    does ricoh 3320L fax machine have volitaile memory?
  • Anonymous Mar 27, 2014
    Hello. How to reset drum message on Ricoh 3320L
  • Anonymous Mar 29, 2014
    paper in tray with paper light on
    paper error won't print
    An user who is expert in 3 categories / brands.
  • Ricoh Master
  • 1,362 Answers
What does time to change pcu mean?
Hi, PCU stands for photo conductor unit, most of us call it a drum unit. You should be able to order from any office supply. It is easy to install and will come with directions.
Oct 08, 2014 | Ricoh 3320L Laser Fax
Can receive faxes but can't send them
did someone reverse the line cord to "telephone"? Do you have a dialtone when using monitor
Apr 04, 2014 | Ricoh 3320L Laser Fax
MMY fax machine can receive faxes but i cant send any fax ?
If you machine has a telphone handset attached, see if you can make an outgoing telephone call. if it can then your machine has a dialling problem. Check to see if your dialling method is set to tone/DTMF. It may be on pulse and if in the uk it may cause the problem. If it is on tone/DTMF then it may not be sending any tones. These are usually generated on the modem chip. If this is the case then a new control board will be required. Before buying a new one it may be prudent to RAM CLEAR the board (a full reset). It you want to do that then repost telling us what make and model you have. Good luck
May 09, 2011 | HP Office Equipment & Supplies
How To Enable DTMF Digits on AR_M_280N Fax machine??
have you tried adding * 's they add a pause between numbers. You may have to add several, but that will put a slight delay in the dialing.
Jul 23, 2010 | Sharp AR-M280N Copier
How do you do a factory reset on a Ricoh 3320L
You never do a fatory setting on these machines.Whats the problem and i may be able to help you Contact me at
Jun 24, 2010 | Ricoh 3320L Laser Fax
I cannot delete voice messages after having heard them. The dialpad does not recognize the touch to keys. How do I reset?
Enable or Disable Touch Tones (DTMF) for the LG Xenon (GR500) Fix:
LG Xenon (GR500) Keypad Layout
Enable or Disable DTMF tones
  1. From the standby screen, tap the menu icon.
  2. Tap the settings icon.
  3. Tap Call.
  4. Tap On or Off.
Feb 27, 2010 | LG Xenon GR500 Cell Phone
Accidentally set the pulse/tone dialing feature to pulse for a Ricoh 4430L. How do I change it ?
Option setting within "Setup" menu (need access code of 2222) allows you to see advanced features not normally viewed after installation of fax machine is completed. Within these advanced features is a parameter to choose analog line setting of either tone or pulse.
Jan 09, 2010 | Ricoh 4430L Laser Fax
No fax tone giving if this fax mode only
Using "on hook" you should hear a dial tone, if you have one then dial a known good fax number. It could also be in manual receive mode. -Carl
May 05, 2009 | Ricoh FAX1900L Plain Paper Laser
SF-515 does not dial anymore
Hi there try this press menu then using the arrow keys go into machine settings I think if not you are looking for line type. Once in the make sure it is set to tone.
Once you have done this come out and try if this doesn't work then the control panel maybe faulty and you could take it apart and clean the number pad keys and make sure that the buttons move freely.
If they do cleanup and put back together and check machine if it still doesn't work then the panel will more than likely need replacing.
Thanks J
Nov 14, 2007 | Samsung SF-515 Plain Paper Laser Fax
Ricoh 3310LE Plain Paper Laser Fax Logo
607 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
