Miele CVA2660 Stainless Steel Coffee Maker
Problem for Miele CVA2660 Stainless Steel Coffee Maker
Have to change power input from 120V/60Hz to 230V/50Hz
By hentsche on Jan 22, 2008
I am using the CVA-2660 in the US with 120V/60Hz power supply. Now I am preparing for the move to Singapore where they have 230V/50Hz power supply. What should I do? Get a transformer 230V>>120V would be one option I guess. But is there a better solution like getting the suitable 230V/50Hz power supply and install it inside the machine? Or are there motors inside the machine that are running on 120V?? In this case I assume it would be too expensive and troublesome to replace those with the 230V version I need in Singapore.
Greetings,
Norbert Hentschel
Best Solution
posted on Jan 22, 2008
Helpful)
exspert
Rank: Wiz
Rating: 80%, 49 votes
ok " check the net for plug and power converters that plug in to
Singapore receptacle
Had a set for Europe worked great
Was this helpful?
Yes
No
Popular Solutions for Miele CVA2660 Stainless Steel
Questions and Unsolved Problems for Miele CVA2660 Stainless Steel
Do you recommend Miele CVA2660 Stainless Steel Coffee Maker?
Answer
Answer
no water from hot water dispenser and no steam from steamer only produces the coffee
Answer
How can I override descaling on a Miele coffee maker?
Answer
having descaled the miele built in coffee machine cva 2660 error f74 came up and it will no longer... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Coffee and... Experts
Top Small Appliance Repairmen
in , CA
(316) 283-4211
(316) 283-8664
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
