Question about Haier Air Conditioner
No heating The A/C goes dead when switching to heating mode, plus the fan is extermly slow
  • 1,420 Answers
Make and Model number please.
Posted on Jan 23, 2008
How Do I Know that the Huawei S5700 series switch's Fan Operates Normally in Intelligent Mode?
The fans can work in the intelligent mode or forcible mode.
In the intelligent mode, the fans start to operate only when the ambient temperature goes higher than a specified value. In V200R003C00 and later versions, you can run the display fan speed-adjust threshold minus command on the switches that use the intelligent heat dissipation mode to view the temperature thresholds for the fans to start and stop running. The set fan speed-adjust threshold minus command can be used to lower these temperature thresholds.
Intelligent heat dissipation:
Huawei S5700-24TP-SI-AC
Huawei S5700-24TP-SI-DC
Huawei S5700-48TP-SI-AC
Huawei S5700-48TP-SI-DC
Sep 14, 2017 | Huawei Computers & Internet
Heat Pump comes on, fans slow down, switches off?
Sounds like a bad temp sensor or switch. Like in cars my guess is that the switch is failing to work causing the fans to stop despite the pump getting hot.
Jun 23, 2014 | Aquacal ICEBRKR HEAT/COOL 110K TITANIUM...
Fan motor is slowing down and not keeping the desired temperature
The circuit diagram for the standard control model shows the blower has a two-speed motor, connected directly to the power line in "Cool" mode, or connected to the temperature control in "Cook" mode. When the blower slows down during cooking, switch it temporarily to "Cool" mode. If it goes to normal speed, the problem is with the mode switch contacts or the wiring terminals between the fan mode switch and the temperature control board, or the control board itself.
If the speed does not change, check the wiring terminals at the speed switch common terminal (I assume your problem occurs in both low and high speeds). If you find tarnished, loose, or burned terminals, clean, repair or replace as needed. (In extreme cases, a loose terminal will cause the wire to overheat, damaging the insulation, oxidizing the terminal and causing a high-resistance condition that will reduce the voltage available to the motor.) If the connections are all good, the motor bearings are probably getting sticky at high temperatures. Let the oven get hot enough for the blower to slow down, then shut it off and check the blower bearings while wearing oven mitts.
May 12, 2014 | Southbend SLGS-22SC Gas Double Oven
Fans not working ,or dont go fast enough on to keep radiator cool
check fuses, check fan relays , per fsm
Fsm = factory service manual.
alldata.com
there are 3 cooling fan relays Hi/low and control
the ECU outputs only high and low.
the ECU is hard coded, (softrware) to run fans. and uses
the ECT as the input sensor.
so if the low is dead the relay is dead.
if the the high is dead , high relay is bad.
if the relays look the same, why not swap them to see if the
2 fans switch fail mode.
Jan 26, 2014 | 2006 Suzuki Forenza
Indoor fan blowing cold air when on heating
The indoor fan will continue to run. When heat pump goes into defrost the outdoor fan stops, the reversing valve switches and the unit is basically working in the cooling mode. In order for you not to feel a blast of cold air in the winter the electric strip heat also comes on so the indoor fan must run while the strip heaters are on.
Jun 03, 2010 | Heating & Cooling
I have Hp Compaq 6820s...and i have heating problem...my Cpu temp is around 90°C
The cause of this problem is first in the dust, which could have accumulated on the fan, which in the process of cooling the processor and chipset, chipset graphics card and motherboard as a whole and could be sensitive part of the temperature that controls the work of the fan has been by the damage and does not work and resolve This problem must be connected to the fan stream directly from the motherboard does not exceed 3 volts in order to operate the fan
Mar 14, 2010 | HP Compaq 6820s Notebook PC - Intel Core 2...
Fan slows to about half speed when heat cycle kicks in
The heat fan speed is slower than the cooling speed. About 300 rpm less.
You may not have a problem.
May 20, 2009 | LG Heating & Cooling
Wire diagram for pull chain on ceiling fan hunter original
if you indeed have a 23852 hunter original...
Black goes to L, High is Red, Gray is medium and yellow is low. Make sure you have the right switch.
Mar 21, 2009 | Hunter 23852 Classic Original Ceiling Fan
Airconditioner LG LSk181-N2 shutting off
Sounds like your aircon is stuck on heating mode. Or. The outdoor fan speed is affected by ambient temperature, or low refrigerant. In heating mode the indoor fan will come on for a while to sense temperature and will then wait for the outdoor unit to pump up pressure and build up heat.
Feb 01, 2009 | LG LS-K1830CL Cool Mini Split Air...
Soleus KFGHP-09-ID Mini Split
This is normal operation for these styles of minisplits. The thermostat is not in the remote but is located on the return air of the indoor coil, so the air needs to be flowing in order for the thermostat to measure the rooms temperature. Set your fan speed to auto and the fan will slow down when setpoint tempurature is met.
Phil Hodges,
Tech support Soleusair
May 18, 2008 | Soleus KFS18GW 18,000 BTU Heat & Cool 230V...
Heating & Cooling Logo
Top Haier Heating & Cooling Experts
Tom Chichester
Matt
Matt
Level 1 Expert
Vincent Schnittert
Vincent Schnittert
Level 1 Expert
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
