Acer monitor problem
I hav 19inches LCD monitor ,,i hav bought it a week ago,,, it was working well but today when i started it ,,, i got a white blank display... and still it persist.... plese need your help .....
    Problem Solver:
  • 19 Answers
First thing to do is check the cables and reset the monitor. If it is one of those that has the DVI conncection and the DVI connection, try the other connection. Some graphics cards need special drivers to use the DVI signal.
Posted on Jan 23, 2008
  • Ted Conner
    Ted Conner Feb 15, 2009
    Good place to start Ihamu. I would do that in a certain way.
    First, as with any messed up electronics, remove all electricity and leave it for awhile. Come back and plug everything back in, starting at the wall socket, then your monitor, computer, printer, etc.
    When the monitor first powers up it will perform a degaussing if a crt type, Not so for the lcd type (no need).
    If resetting the power doesn't fix the problem, try these things.
    If your video card has two types of outputs for dvi, and vga you can try switching it to the other adapter. If it works, just install the driver for the one you want to use, and plug it in there.
    As your system powers on when booting, what does the power on light on the monitor do? Mine is yellow if there is no signal and green when there is.The question here is Is the computer sending a signal? and is it making it to the monitor. The problem will be connections, like wrong one on video card or cable no good. If the white screen persists, then it will be the monitor or computer video card. Borrow a monitor and substitute it for yours. You should be able to tell if that is the trouble. Otherwise borrow a video card and put in your computer, see if the signal makes it from there to the monitor.
    Contact me if you find none of that works, I will help you find a diagnostic to help.
I hav buyed a new acer v173 lcd monitor,and used upto 10 months till now.Lastday when i switch on my lcd,it showed the Acer logo , and suddenly the color of the screen changed,now the lcd works but i could...
Sounds like a problem with the video board of the monitor. I would contact Acer, since it less than 3 yrs old, tell them the problem that you are having get an RMA number and they will fix it for free. You only have to pay for shipping it back. Hope this helps.
Jul 29, 2010 | Acer V173 b Monitor
My acer monitor X203w has a pink rather than white background. That is very annoying. It just started a day or so ago. Is there a simple fix?
The pick tint is caused by the backlights not going to full brightness. It is going to be either the back light tubes or the power supply/inverter board. Your monitor should still be under warranty with Acer so you need to contact them and get it serviced. The longer you wait the worse the tint will be until the monitor quits working all together.
Corporate Computer
Jan 21, 2010 | Acer X203W 20" LCD Monitor
This monitor has been working fine for 8 months on another machine. I just moved it to another laptop. The mointo works, but is the same size as the laptop, not 19inches. Help
You need to alter the resolution settings on your laptop (Control Panel - Display) so they are the same as your 19" monitor.
Aug 15, 2009 | Soyo 19" LCD Flat Panel Monitor
Acer lcd monitor ''no signal''
It is screen resolution problem.
when you power up the computer press F8 key thene nter in enable vga mode then go to diaply property and set screnn resolution to 1024*768 thenh apply and ok.
Jul 12, 2009 | Acer AL1916W 19" LCD Monitor
Have a new Acer LCD monitor -- will not power on.
I checked all cords connecting the monitor to the computer, made sure nothing was loose.  Then I re-booted the computer, and the monitor is on.
Apr 10, 2009 | Acer Computers & Internet
It may not be a problem with the lcd.
This is most likely a problem in the video card of the laptop.
but you can test it out, if you plugin a extra screen to the laptop to see if the white dots come to the other monitor aswell.
If you see white dots in both of the screens this means the video card is about to fail. and would need to be replaced.
If you don't see any white dots on the external screen then the problem is in the lcd.
You can call bestbuy they should give you another phone number to call for repairs / parts.
Jun 10, 2008 | Acer Aspire 3680 PC Notebook
ACER LCD monitor no image, appears white color only
Quickly go to the Acer website and check FAQ's and while there also find out how to get an RMA to return it. My guess is you have a bad monitor. At $200 roughly for a replacement I would hustle. I am assuming you got nothing but a white screen but did get video on your TV.
Jan 11, 2008 | Acer AL1916W 19" LCD Monitor
Monitor does not work
sounds like a slightly damaged power supply. try powering up with an equivalent supply. if only an ac wall cord is plugged in for power, then internal supply is at fault
May 28, 2007 | Acer AL707 17" LCD Monitor
298 people viewed this question
