Question about ASUS P4S8X Motherboard
3x 1GB DDR400 Problem on booting!
I have this Asus P4S8X-X motherboard and now I bought 3 sticks of 1GB each of DDR400 High Density, Non-ECC.
the problem is that the system only boots with 2GB or even 2 of those sticks + 512MB 333MHz.
So, I assume that is a problem with frequency.
What do you suggest me to do? I've updated my Bios and there's an option of maximum 200Mhz for memory !!!!!
Your help is very appreciated since I from Portugal and bought from Ebay (USA) this memory, so I must move quickly.
Thanks in advance.
  • Anonymous Feb 08, 2008
    i have the same problem. just bought 2 more 1 gig pc3200
    will only run with 2 gig. stops at boot up. can someone please help. jwr@bellsouth.net
  • Ernest Gould
    Ernest Gould Jun 12, 2008
    i bought 2 sticks 1gb ddr333 will only work with one stick
This is a limitation of the SiS 648 / 963 chipset used on this motherboard.
This SiS chipset officially supports:
3GB max of PC2100/PC1600 memory, or
2GB max of PC2700 memory (PC3200 is also unofficially supported)
Hence the reason you can only run 2 x 1GB sticks of PC2700 or PC3200 (aka. DDR333 or DDR400) memory.
DDR400 is backward compatible so you could slow these stick down in BIOS to PC2100 (DDR266) settings if you want to use 3 x 1GB.
Posted on Jan 09, 2009
    Problem Solver:
  • 42 Answers
The details for your case can be obtained in this site.....................
http://www.memory4less.com/m4l_results.asp?ref=mem&modelid=800121
read carefully to understand the limitations that arise with your motherboard.
cheers....................
Posted on Jan 22, 2008
Fdmdgo-03014s
For a Chaintech 9BIA motherboard;
Motherboard chipset is an Intel 845,
http://en.wikipedia.org/wiki/List_of_intel_chipsets#Pentium_4_chipsets
http://www.firingsquad.com/hw/168/Chaintech_9BIA/
PC133 (SDR Sdram at 133MegaHertz;
{Single Data Rate. The proper term, not just Sdram.
Double Data Rate Sdram is Sdram.
Double Data Rate 2 Sdram is Sdram.
Double Data Rate 3 Sdram is Sdram.
DDR Sdram, DDR2 Sdram, DDR3 Sdram.
Synchronous Dynamic Random Access Memory )
Low-Density, Unbuffered, Non-ECC, Cas Latency of 3
(Don't get some cr@p off of Ebay.
It's usually high-density, ECC, that was used by old server computers)
http://www.newegg.com/Product/Product.aspx?Item=N82E16820146305
WHEW! Unless you just want to run 1GB of ram memory, I would toss that board! (Two 512MB sticks) ->
-> Need two 1GB sticks of SDR Sdram at 133MHz
http://www.directron.com/ct128m72s4r75.html
$400 smakeroos USD!!
Bah! That is just cra-zy!
Maximum TOTAL Amount is 2GigaByte. (2GB)
Maximum Amount for EACH ram memory slot is 1GB.
IF, you only have ONE ram memory module ('Stick'), it goes in Slot 1. (DIMM 1)
That is the ram memory slot closest to the processor socket.
The Processor reads ram memory Slot 1 first.
http://www.cpu-upgrade.com/mb-Chaintech/9BIA.html
Regards,
joecoolvette
Nov 26, 2012 | Chaintech 9BIA (CT-9BIA) Motherboard
I have p4p800 se 2.6 ht cpu I recently bought 2-1gig sticks of ddr400 pc3200 cl3 hp memory and tried everything I could think of wont boot can anyone help
Asus gives this as the board memory spec:
-4 x 184-pin DIMM Sockets support max. 4GB DDR400/333/266 non-ECC DDR SDRAM memory
I suspect you bought DDR2 type memory.
Apr 16, 2010 | ASUS P4P800 SE (890552603657) Motherboard
Ram used for asus P5P800S
2 x 184-pin DIMM sockets support max. 2GB
PC3200/PC2700/PC2100 non-ECC DDR SDRAM memory.
Or if you prefer it a bit plainer a maximum of 2 x 1GB DDR400/DDR333/DDR266 SDRAM memory.
you will find the full specs as well as the drivers on the asus global website.
Mar 18, 2010 | ASUS P5P800S (90MBL0Q0G0UAYZ) Motherboard
I have a Emachine 335 Desktop, motherboard E210882.
best to install with matching pairs- if it wont boot chances are its the wrong type of ram---check if its low density vs high density- ecc vs non-ecc, parity vs non parity etc.
Sep 17, 2009 | Intel Motherboard
Does GA-8I945P motherboard support high density memory?
You have 4 slots available. Each slot can take a 1gb non ecc memory module with the specs below.
4 DDR II DIMM memory slots (supports up to 4GB memory)
Supports 1.8V DDR II DIMM
Supports dual channel DDR II 667/533/400 DIMM
Mar 22, 2009 | ASUS P4VP-MX Motherboard
Memory upgrade issue
Most ram has to go in pairs. Buy another stick of the 1GB, and it will run fine.
Jan 23, 2009 | FIC K8-800T Motherboard
P4S8X-X motherboard. Latest list of compatable RAM 1.gb
Each memory slot can hold DDR PC2700,DDR PC3200 with a maximum of 1GB per slot.
  • Chipset: SiS 648
  • Supported DRAM Types: DDR SDRAM only
  • 184-pin DIMM Banking: 3 (3 banks of 1)
  • Module Types Supported: Unbuffered only
  • Max Unbuffered DDR SDRAM: 3072MB
  • Error Detection Support: Non-ECC only
  • Graphics Support: AGP 8X
  • Max Component Density: 512Mb
  • USB Support: 2.x Compliant
  • Jul 06, 2008 | ASUS Computers & Internet
    Memory Stick Installation
    So it seems you got the DDR / DDR2 side of the equation correct, but unknown to most, there is 'low' and 'high' density memory.
    The density of memory refers to the number of chips used to make the total amount of memory that your memory stick contains. e.g. High density memory has few, large capacity chips to make up the 1024MB of memory on the stick, whereas low density memory uses many, small capacity chips to make up the same 1024MB total on the stick.
    Typically, if it is a low / high density conflict, it is the 'low density' sticks only that will boot.
    Me, I purchase Kingston memory when I'm unsure what the motherboard will be, and it has never failed to work.
    I fix computers.
    May 19, 2008 | EliteGroup PM800M2 Motherboard
    High density memory
    need low densisty on ebay 35 buck eash 1 gb ok works on picky mobos way better
    Feb 07, 2008 | Dell (E210882) Motherboard
    Type of memory for e210882 motherboard
    the memory you're about to purchase will not work. the maximum gig that the computer can handle per stick is only 1 gig. this system is not designed for 4 gig barrier.
    hope this helps.
    thanks.
    Feb 05, 2008 | Dell (E210882) Motherboard
    ASUS P4S8X Motherboard Logo
    289 people viewed this question
    Top ASUS Computers & Internet Experts
    Alun Cox
    David
    David
    Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
