Question about Nx Networks Globetrotter 70 (RBX70S-E2) Router
Info on system requirements for NX4
I would like to know what r the system requirements like processor,processor speed, ram, system space etc for UGS NX4 or NX5
0 characters
1 Points
My yahoo is so slow how do i speed it up
For running slow there are many causes:
Microsoft Registry Problems = Slow Computer!
Below can help you speed up your pc:
For IE, click Tools, Internet Options delete files (offline files) clear history (set days to save to 0 if you want) click o.k., and Restart
For Firfox, press ctrl+shift+del, and click clean private data.
Manage your startup:
Open your Start menu -> Click Run -> In the command screen type "msconfig.exe" -> In the "system configuration utility", click either "service" or "startup" tab -> Uncheck all programs that your are no longer using.
1. Right click of C Disk.
2. Click properties.
3. Click tools tab.
4. Click "Defragment now".
5. Click Defragment.
You can search which process full use you cpu, and end the process.
Under steps:
1. right click on the TaskBar.
2. click the Task Manager.
3. click the processes tab.
4. double click the CPU.
5. find if the "System Idle Process" is max.
6. if not right click and click end process.
Learn "Why Is My Computer Running so Slow?" and "How to Speed it UP":
Use the tool:
May 14, 2014 | Routers
Slow internet, not loading fast enough
Is your wireless Secured by a password? Unplug the wireless,and Modem, remove battery, if applicable, check all connections, cables, replace battery, plug in modem, allow it to selftset, plug in wireless, allow to selftest, reboot computer. if no change, contact ISP for testing. Most likely it's not your wireless it's your computer and specificly your broswer. I don;t know waht your computer is or what OS you are using , so Try these tips, choose your OS : OR : OR Delete ALL TOOLBARS, in Manage Add-ons , remove, disable, ALL unnessary TOOLBARS, Skype, Chat,etc. In Search Providers remove all but Google. I suppest Downloading MALWAREBYTES freeware at : UNCHECK the TRIAL PRO version, you wat the freeware. Run a FULL SCAN, DELETE ALL RESULTS. ALSO, another freeware program CCLEANER at : This will clean the junk from your system , also in the STARTUP section, disable ALL unnessary startup programs. Run a FULL SCAN with your UP-TO-DATE Anti Virus, REBOOT THE Machine.
Dec 24, 2012 | 2wire (2701HG-B) Wireless Router
How do i speed up my wifi?
There're a number of ways to "broaden" your Broadband Wi-Fi link.
(a) move laptop closer to the Wireless Router, and/or remove signal obstructions between laptop and Wireless Router.
(b) move the Wireless Router to a channel other than the default (channel 6).
HOW: login to the Router management pages at, and change it.
(c) upgrade your Wireless-G router to Wireless-N (with the Linksys WRT310N you've aready done that, however).
(d) Switch from Wi-Fi to hardwired with a Cat 5e ethernet cable - you'll have better throughput and fewer CRC errors with a hardwired link.
(e) Recognize that 99% of the time the upload/download speed bottleneck is not the Broadband link, but the computer laptop system itself, so the best way to increase the speed of your Wi-Fi link is to optimize the computer system. Normally, increasing the physical link speed is wasted time and money - something those Verizon FIOS commercials will never tell you.
Put your money into upgrading RAM and running fewer startup group processes eating into system virtual memory (SWAPFILE.SYS) space.
If you can access only trusted web sites (typical of a workplace workstation), then you can optimize browser operation by eliminating Real-Time Anti-Virus shields such as: (File System Shield) scan on open, (File System Shield) scan on write, HTTP shield, Network shield, suspicious behavoir shield, Script Shield, and IM Shield. This will help to optimize your browser's activities. Web browser software is well known to be among the least efficient software ever devised. The typical user will have half a dozen Browser Extensions, and a dozen or more Browser Plug-ins, each further burdening an already over-burdened Browser. Most Users don't even know how many Browser Extensions and Plug-ins they're running, and inadvertently permit new ones to be installed daily.
Consider upgrading your laptop's CPU, rolling back from Windows 7 to Windows XP, and changing Operating Systems from a Microsoft Windows OS to Linux. Also consider using an Apple MacBook.
Lastly, perform a security scan on your system - nothing wrecks a laptop's performance faster than a virus/worm/trojan horse/rootkit/malware/spyware/tracking cookies/supercookies, etc.
Dec 04, 2011 | Linksys WRT310N Wireless Router
Computer running slowly
Wen you say the computer is running slowly, do you mean the overall programs or just Internet (browser)???
If it's the computer, first check all components (RAM, HARD DRIVE, NETWORK CARD, etc...) than check for VIRUS, MALWARE, SPYWARE, etc..
If it's the Internet connection, first check the modem connectivity, the router's connectivity, wiring, wireless connectivity, etc..., call your Internet provider to make sure they don't have any connection problems, do a speed test, (
Mar 22, 2011 | Routers
I am trying to change the cfe on my netgear wgr614 V6 tdc but the jtag doesn't see it. The ends I am trying to get to is putting dd-wrt on it. Any ideas?
I don't know TDC version of v6, if you still have it please provide info about components (processor, flash, RAM). I have some with processor BCM5352, flash 29LV800 (some with 29LV160), RAM Samsung K4S641632
Mar 14, 2011 | NetGear WGR614 Wireless Router
Problem may be one of these:
1. Windows 7 required atleast 1GB RAM otherwise your PC will slow down
2. Keep maximum Partion size of c drive or where u installed windows 7.
3.Your processor needs to be atleast core family processor
4.Have u installed drivers for windows 7 correctly?
5.Or there may be possibility of virus in your PC.
Rate IT
Have a Nice Day!
Mar 06, 2011 | Routers
Game won't load it is the only zynga game that will not load.
1. Check for current anti-virus before doing step below.
2.Check firewall allowances or permission to be sure game is allowed
3. Try "port forwarding
4. Check the game / verify ports need for multiplayer gaming.
5. Please forward all ports UDP/ TCP To gaming computers IP address.\
6. Log in to router and place gaming computer in to DMZ.
7. When done gaming disable the game in the DMZ.
8. You may have to uninstall game then re-install
9. Check hard drive space to see if you have ample space to load game.
10. remove any saved game to gain more storage space.
11. check the manufactures site for the game mentioned and check to see if it is compatible with your operating system and RAM ( random access memory) requirements
Feb 16, 2011 | Routers
I lost mine too, saw this post, and then they turned up, so here you are:
Surface Mounted 2/6a Slave Wall Plate - with ADSL Filter
  • Remove wall plate back box by removing the two screws on the front face
  • Fix wall plate to skirting board or wall with screws supplied, allowing adequate space for cable entry
  • Insert exisiting telephone wires into screw connections on the ADSL face plate, following cable colour coding according to the list below, and ensure screws are correctly tightened
  • Screw wall plate onto the back box with the screws supplied, ensuring screws are sufficiently tightened
Cable Colour Coding
1. Not Used
2. Blue with white banding
3. Orange with white banding
4. White with orange banding
5. White with blue banding
6. Not Used
  • No need for external filter
  • Surface fitting, replaces existing wallplate
  • Quick set-up
  • With back box
* If more than one phone or fax IS required to run off the same line, simply add more filters where required. Each individual piece of equipment will require a seperate ADSL filter
* Multiple telephone connections, long runs of cable (over 20m) or low quality telephone cable can adverely effect the performance of your connection speed
Safety Information
Before carrying out any electrical work, always switch off at the mains. If in doubt consult a qualified electrician.
Item Code: 41603016
Distributed by Commtel UK Ltd
It might be worth mentioning that this filter swaps the polarity of the telephone wires: I don't know why. I rewired mine to use it as a master socket, and I have connected the other extensions to the filtered output. This can improve broadband speeds: see
Oct 23, 2010 | Routers
My computer very slow can u help ty
Make sure there is enough space on your C drive or system partition. Run a malware detection software and scan your system for Virus. Go to add/Remove program and look for suspicious program and remove them. If you system still runs slow, Upgrade your RAM.
Aug 14, 2010 | Routers
Nx Networks Globetrotter 70 (RBX70S-E2) Router Logo
604 people viewed this question
Top Nx Networks Routers Experts
 C. Dante
C. Dante
Are you a Nx Networks Router Expert? Answer questions, earn points and help others
