Software Utilities
Problem for Software Utilities
Generic problem for all Software Utilities
I have win32 virus in my pc...
By maruth on Jan 22, 2008
i have win32virus in my pc...can u help me with this?
Same Problem
Jul 27, 2008
-   scan more mail symantec antivirus-   hkabir06
Best Solution
posted on Jan 22, 2008
Helpful)
Maanita
Rank: Wiz
Rating: 83%, 448 votes
The following instructions pertain to all current and recent Symantec antivirus products, including the Symantec AntiVirus and Norton AntiVirus product lines.
Disable System Restore (Windows Me/XP).
Remove all the entries that the risk added to the hosts file.
Update the virus definitions.
Run a full system scan and delete all the files detected.
Delete any values added to the registry.
For specific details on each of these steps, read the following instructions.
1. To disable System Restore (Windows Me/XP)
If you are running Windows Me or Windows XP, we recommend that you temporarily turn off System Restore. Windows Me/XP uses this feature, which is enabled by default, to restore the files on your computer in case they become damaged. If a virus, worm, or Trojan infects a computer, System Restore may back up the virus, worm, or Trojan on the computer.
Windows prevents outside programs, including antivirus programs, from modifying System Restore. Therefore, antivirus programs or tools cannot remove threats in the System Restore folder. As a result, System Restore has the potential of restoring an infected file on your computer, even after you have cleaned the infected files from all the other locations.
Also, a virus scan may detect a threat in the System Restore folder even though you have removed the threat.
For instructions on how to turn off System Restore, read your Windows documentation, or one of the following articles:
How to disable or enable Windows Me System Restore
How to turn off or turn on Windows XP System Restore
Note: When you are completely finished with the removal procedure and are satisfied that the threat has been removed, reenable System Restore by following the instructions in the aforementioned documents.
For additional information, and an alternative to disabling Windows Me System Restore, see the Microsoft Knowledge Base article: Antivirus Tools Cannot Clean Infected Files in the _Restore Folder (Article ID: Q263455).
2. To remove all the entries that the risk added to the hosts file
Navigate to the following location:
Windows 95/98/Me:
%Windir%
Windows NT/2000/XP:
%Windir%\System32\drivers\etc
Notes:
The location of the hosts file may vary and some computers may not have this file. There may also be multiple copies of this file in different locations. If the file is not located in these folders, search your disk drives for the hosts file, and then complete the following steps for each instance found.
%Windir% is a variable that refers to the Windows installation folder. By default, this is C:\Windows (Windows 95/98/Me/XP) or C:\Winnt (Windows NT/2000).
Double-click the hosts file.
If necessary, deselect the "Always use this program to open this program" check box.
Scroll through the list of programs and double-click Notepad.
When the file opens, delete all the entries added by the risk. (See the Technical Details section for a complete list of entries.)
Close Notepad and save your changes when prompted.
3. To update the virus definitions
Symantec Security Response fully tests all the virus definitions for quality assurance before they are posted to our servers. There are two ways to obtain the most recent virus definitions:
Running LiveUpdate, which is the easiest way to obtain virus definitions: These virus definitions are posted to the LiveUpdate servers once each week (usually on Wednesdays), unless there is a major virus outbreak. To determine whether definitions for this threat are available by LiveUpdate, refer to Virus Definitions (LiveUpdate).
Downloading the definitions using the Intelligent Updater: The Intelligent Updater virus definitions are posted daily. You should download the definitions from the Symantec Security Response Web site and manually install them. To determine whether definitions for this threat are available by the Intelligent Updater, refer to Virus Definitions (Intelligent Updater).
The latest Intelligent Updater virus definitions can be obtained here: Intelligent Updater virus definitions. For detailed instructions read the document: How to update virus definition files using the Intelligent Updater.
4. To scan for and delete the infected files
Start your Symantec antivirus program and make sure that it is configured to scan all the files.
For Norton AntiVirus consumer products: Read the document: How to configure Norton AntiVirus to scan all files.
For Symantec AntiVirus Enterprise products: Read the document: How to verify that a Symantec Corporate antivirus product is set to scan all files.
Run a full system scan.
If any files are detected, click Delete.
Important: If you are unable to start your Symantec antivirus product or the product reports that it cannot delete a detected file, you may need to stop the risk from running in order to remove it. To do this, run the scan in Safe mode. For instructions, read the document, How to start the computer in Safe Mode. Once you have restarted in Safe mode, run the scan again.
After the files are deleted, restart the computer in Normal mode and proceed with the next section.
Warning messages may be displayed when the computer is restarted, since the threat may not be fully removed at this point. You can ignore these messages and click OK. These messages will not appear when the computer is restarted after the removal instructions have been fully completed. The messages displayed may be similar to the following:
Title: [FILE PATH]
Message body: Windows cannot find [FILE NAME]. Make sure you typed the name correctly, and then try again. To search for a file, click the Start button, and then click Search.
5. To delete the value from the registry
Important: Symantec strongly recommends that you back up the registry before making any changes to it. Incorrect changes to the registry can result in permanent data loss or corrupted files. Modify the specified subkeys only. For instructions refer to the document: How to make a backup of the Windows registry.
Click Start > Run.
Type regedit
Click OK.
Note: If the registry editor fails to open the threat may have modified the registry to prevent access to the registry editor. Security Response has developed a tool to resolve this problem. Download and run this tool, and then continue with the removal.
Navigate to and delete the subkey:
HKEY_LOCAL_MACHINE\System\CurrentControlSet\Services\RpcRemotes
Navigate to the subkey:
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Setup
In the right pane, delete the value:
"Ph4nt0m" = "Ph4nt0m"
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\wuauserv
In the right pane, reset the value to the original value if applicable:
"Start"
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\SharedAccess
"Start"
Exit the Registry Editor.
also u can use the link for free download of virus removal tool
http://www.bitdefender.com/site/Download/browseFreeRemovalTool/
Was this helpful?
Yes
No
Popular Solutions for Software Utilities
Questions and Unsolved Problems for Software Utilities
Answer
what is another music loader other than limewire? p.s. that is free!
Answer
My HP MediaSmart TV Software has stopped working properly. i have downloaded sp42505.exe. Do i have... (More)
Answer
Describe your scansoft paperport deluxe 9 windows Vista printer drivers Problem Can not install why
Answer
just over one hour and 59 minutes into the game escape the museum program freezes why?
Answer
Windows security alert keeps poping up,saying there isn't any anti-virus program running.There... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Software Utility Experts
Top Computer & Laptop Repairmen
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
