Question about Proview PL713S 17" Flat Panel LCD Monitor
The monitor goes dark when I switch on my pc
Dear Sir,
I need a help from you..I have a Acer flat monitor..now when I switch on my monitor..the contrast level pop ups and then the contrast level goes on decreasing and reaches the level 00..that is the monitor becomes dark and black...so I am unable to work on that...so will you please help me out to solve the problem and give some instruction to recover from this kind of problem..
  • Anonymous Feb 13, 2008
    Whenever i switch my monitor on the contrast goes to zero automatically. when i redo it, again its gets back to its original form which is dark in color.
    Champion:
  • 220 Answers
Front switch panel is suspect.
Posted on Feb 19, 2008
Monitor flashes on then goes dark
You might need to replace your monitor. But you can use an external one, one of the Fn buttons should switch the main monitor to the external one.
Nov 08, 2013 | Acer Computers & Internet
Acer aspire notebook 5517 screen goes dark randomly
Sounds like either a loose connection where the screen cable connects to the motherboard or that the screen is on the way out. Re-seat the monitor ribbon on to the motherboard.
Aug 06, 2013 | Computers & Internet
Acer Aspire 5050 - screen is dark as if contrast not working. It has played up for some weeks, going dark but after 10-15 mins it returns to normal. now it appears permanent. Have adjusted the GAMA and...
put and external monitor and if fail remains then your gpu is damaged, if monitor goes good then your screen is damage or the video cable, so in that case will require a technician to fix it. good luck
Jul 29, 2011 | Acer Aspire 5050-3242 Notebook
The screen goes dark. When U cycle the power switch off then on again the screen display returns for about 1 second then goes dark again. I would appreciate suggestions on what to do.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
May 21, 2010 | Samsung SyncMaster 174V 17" Flat Panel LCD...
Acer laptop has developed a fully dark screen
I am assuming that you have tried switching from external monitor output and local monitor. There should be a hot key on the keyboard to switch it. Also, try looking to make sure the driver for the display is up to date. I f it was update recently try rolling the driver back. If you need help with doing any of this post a comment. Hope this has helped some.
Dec 02, 2008 | Acer Aspire 3680 Laptop
SCREEN GOES DARK TWO SECONDS AFTER ITS SWITCHED ON
when it goes dark disconnect the data cable of the monitor from the system end and if u still see nothing
monitor bad and if u see the colour scheme monitor working system is the culprit
Oct 04, 2008 | Dell E172FP 17" LCD Flat Panel Monitor
My screen has gone black
try to reseat the vga cable of the monitor,reseat at the back of the computer and on the monitor,if the cable is disconnected,make sure that you can see the power on self test with different colors in it,if you cant see it then your monitor went bad,try to connect another monitor to your computer,see what will happen,try using other cables as well
Jul 05, 2008 | Dell UltraSharp 2405FPW 24" Flat Panel LCD...
Monitor problem.
This just happened to me last night.  My web research indicates that the monitor is bad...others have had the exact same problem.
Oct 25, 2007 | Gateway FPD 1730 17" Flat Panel LCD...
Open Questions:
See all Proview PL713S 17" Flat Panel LCD Monitor Questions
Proview PL713S 17" Flat Panel LCD Monitor Logo
51 people viewed this question
Top Proview Computers & Internet Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Frank Russell
Frank Russell
Are you a Proview Computer and Internet Expert? Answer questions, earn points and help others
