Question about SimpleTech 250GB USB2.0 7200 RPM External 250 GB IDE Hard Drive
Simpletech 160 Portable doesn't show up
The harddrive worked fine on my laptop. On the desktop, it at first looked for hardware. The harddrive never showed up. I tried different usb ports. It doesn't show up in Computer Management.
THanks
Carl
  • 4 more comments
  • Anonymous Dec 17, 2008
    My 250 GB Simpletech portable drive icon no longer shows up in my My Computer file, and I can't access it
  • Anonymous Jan 03, 2009
    All I get is a red light and nothing appears on the screen and Best Buy told me to phone GeekSquad for free advice and that was a lie, cost $39 for help they provide
  • Anonymous Jan 13, 2009
    BUFFALO MINISTATION
  • ryandawg103 Jan 14, 2009
    I've got the same HDD and it worked fine about 3 days ago and now my computer won't recognize it. It doesn't show in My Computer or Computer Management
  • GLOWP101 Jan 24, 2009
    my other system at work can pick up the files, but i am trying to open the folders on my home computer and cannot.
  • Anonymous Mar 22, 2014
    This is a SATA Enclosure and I am just getting a red light .Harddrive seems to be running but nothing else happening .Thanks
    Problem Solver:
  • 12 Answers
Go into the control panel and click add/remove hardware... and manually add the device and then use the auto update to download the drivers
Posted on Jan 24, 2008
6ya staff
SOURCE:
Both my desktop and laptop computers do not recognize my Signature mini external hard drive. I've replaced the cable. No difference. The ports work fine because they work with my printer. I have...
External hard drives of this type are mainly composed of a USB-to-SATA interface & a 2.5" SATA hard drive. If any of these components is defective, then you won't be able to access your data.
So, basically we have 2 possibilities:
1. A failing USB-to-SATA interface. You can test this possibility by disassembling the device, taking the hard drive out, & testing the hard drive in your desktop computer using a 2.5" to 3.5" SATA adapter. If the hard drive works fine, then the problem lies within the USB-to-SATA interface.
3. In the previous step, if the hard drive could not be detected by your desktop computer or is not working properly, then it is the failing part.
Jun 11, 2011 | SimpleTech Signature Mini 320GB External...
When hd is plugged in, it installs device and drivers automatically. it never shows up under my computer but in the taskbar it shows safely remove hardware. power light shows orange but harddrive light...
First make sure usb cable connected to harddrive is working fine. try it in different usb ports. Press windows key +R key so you can see run then type in run "devmgmt.msc" then press ok so you can see device manager uninstall all usb drivers then it automatic install usb drivers. then check. Also you need to change registry for that type in run "regedit" then press ok then you can see registry editor then locate below key. HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11 CE-BFC1-08002BE10318} And remove upper filter and lower filter.Then restart computer then check. Let me know if you need further assistance. Thanks for using FixYa
Nov 14, 2010 | Seagate (9W2063500) 120 GB Hard Drive
My external Harddrive just up and stopped showing up on the computer. I mean the lights (red and blue) are on, it just doesnt show up. i even plugged both cables into my comp, and still nothing. I noticed...
First make sure usb cable connected to harddrive is working fine. try it in different usb ports. Press windows key +R key so you can see run then type in run "devmgmt.msc" then press ok so you can see device manager uninstall all usb drivers then it automatic install usb drivers. then check. Also you need to change registry for that type in run "regedit" then press ok then you can see registry editor then locate below key. HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11 CE-BFC1-08002BE10318} And remove upper filter and lower filter.Then restart computer then check. Try your harddrive in different computer if it is not recognized on another computer too then power adapter of harddisk or your harddrive has internal issue.
Oct 15, 2010 | SimpleTech SimpleDrive 160 GB External USB...
I have ROCO 320 GB extranal hard disk which is not recognized in my laptop windows 2007. I had stored so many data from my desk top computer. Any solution please.
Connect your harddrive to another computer like windows xp then if it is recognize then take data backup . If your harddrive is fine then follow below for laptop. First make sure usb cable connected to harddrive is working fine.
then check.
Try your harddrive in different computer if it is not recognized on another computer too then your harddrive has internal issue.
Sep 14, 2010 | Toshiba HDDR500E04XL 500 GB USB Hard Drive
My sata external usb western digital 320 gb drive only shows up as an unknown USB device. Is there any way to get my computer to recognize it. I have a laptop using windows xp. Ive tried unplugging...
then check.
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11­CE-BFC1-08002BE10318}
If your harddrive still not recognized then you need to repair your harddrive.Try your harddrive in different computer if it is not recognized on another computer then your harddrive has internal issue.
Jun 25, 2010 | Western Digital 320GB MyBook External USB...
All USB ports on my emachines T6542 do not work
try to see the BIOS SET UP if the USB port are in enbled status..
if its not,, enabled them...
and see the connection of the USB port into your motherboard if it connect properly..
Oct 27, 2009 | E-Machines eMachines Desktop PC
USB External harddrive not accessible
A couple of possibilities:
1. Not enough power to the drive.
Does the external have its own power supply?
If not it may not get enough power from the USB bus to spin the drive up properly. Put your ear up to the drive and compare how it sounds when you have it in the desktop.
I have an external drive that has an extra connector for just that occasion. If yours does not have this , you will need to get a powered USB hub to rectify the situation.
2. Corruption on the drive. While it is plugged into the desktop , right click on the drive in explorer , go to properties , then tools and error checking. Run a scan and fix any errors.
Apr 07, 2009 | IBM ThinkPad T43 Notebook
USB drive problem
I had a client with this same issue. However, her issue was that the top left USB port would only accept flash drives. Your external harddrive is probably not getting enough power from your USB port. Try using two USB ports (you can get a connector for this) to power up the external harddrive.
Apr 06, 2009 | HP Compaq nx6325 Notebook
Laptop does not recognize my Drive Station, External USB 2.0 Hard Drive, maker: Buffalo worked fine for months now nothing.
I will help you diagnose.
Lets check the easy stuff first.
1. First- Just switch to a different usb port.
Try?
2. Try using a different cable.
Try?
3. go to my computer, properties, hardware, devices, scroll down- delete usbs-
unplug your harddrive from your computer -after having turned it off of course.
leave off for eight seconds
Plug hard drive back in
Try?
4. Try restore computer to a time the Hard Drive Worked?
Try?
Diagnosis Crashed Drive
Mar 26, 2009 | Computers & Internet
because it is not properly connected.connect it well.
Jan 13, 2009 | Computers & Internet
SimpleTech 250GB USB2.0 7200 RPM External 250 GB IDE Hard Drive Logo
784 people viewed this question
Top SimpleTech Computers & Internet Experts
Ekse
GFXTech
Marvin
Marvin
Are you a SimpleTech Computer and Internet Expert? Answer questions, earn points and help others
