Question about Motorola Mobility HS820 Consumer Headset
HS820 do not have manual and cannot get heas=dset to connect to lease
  • Edward Lanham Jul 29, 2008
    try pairing bluetooth to phone and it keeps telling that it can't find it and that there is no list for it. any suggestions as to what the problem is or whaat I maybe doing wrong.
  • 2,130 Answers
Download a copy of the manual here:
Good Luck!
- Jim
Posted on Jan 22, 2008
    SHARCNET-USA Feb 07, 2008
    Sorry that you voted me only "thanks for trying". The link I sent you was the correct link for your model.
    I really wanted to help you.
    - Jim
My droid 2 is not recognizing the motorola hs820 bluetooth device; I have no info on how to set the hs820 to pair
I think I can help here:
Make sure your headset and phone are charged before doing anything else. The blue light on your headset will come on when it is charging, and will shut off when fully charged.
To put your headset in pairing mode, make sure it is completely off first (no blinking blue light). Then hold down the Call button for 6-10 seconds until the blue light stays on. (It will likely flash once and shut off, but keep holding until it is all the way on and stays there!)
From there, go into the settings on your Droid 2 and access the bluetooth connections. Do a new scan for your headset if you don't see it listed, pair, and connect!
Feb 23, 2011 | Motorola Mobility Droid (2 GB) Cell Phone
I need instructions for a motorola hs820 bluetooths
You can download user guide for Motorola HS820 from below website
Thank You
Aug 10, 2010 | Cell Phones
How to connect a Motorola HS820 headset with a Sony Ericsson C510
the interface between motorola and sony ericson works only in some models..try some other headsets (of your friend's ). of the same company.if it works then its not possible to connect the device
May 27, 2009 | Cell Phones
Record outgoing message
Call your service provider and ask them what their voicemail service number is an dset up your voicemail that way.
Mar 11, 2009 | Samsung SGH-G800 Cellular Phone
People can hea me but i can hea dm
check your phone settings then select enhancement settings.. if aint solve maybe the buzzer of the your phone is defective..
Sep 23, 2008 | Nokia N91 Cellular Phone
the default passcode is 0000 for the hs820
Hope this helps
Jun 30, 2008 | LG KG800 Cellular Phone
1.Press and hold the Multifunction button in the middle of a boom headset while the headset is closed. The light will glow blue.2.Open the boom microphone and the blue light should remain on. If not, repeat step 1.
3.On the cell phone, press Menu > Settings > Connection > Bluetooth > Handsfree > New Device
4.Select HS820 once a connection is detected.
5.The passkey "0000" is now entered to confirm the connection has been made.
6.The cell phone screen will now read "Bluetooth Connection".
1.Provided you set the Bluetooth power to "On" after the initial connection has been made, the phone will automatically re-connect to the headset.
2.To set the Bluetooth power on - Press Menu, Select Settings, then Connections, then Bluetooth link, scroll to Setup and select that. Scroll to Power and chose Change. Scroll to On and press Select. The screen should now read "Changed: Power On".
3.Test Your Connection: Close the headset and watch for cell phone to say "Disconnected". Re-open the headset and the phone should be connected automatically and will now display "Bluetooth Connected".
please give good rating if the solution works.
Thanks for using FixYa.
Mar 15, 2008 | Motorola Mobility HS820 Consumer Headset
My Phone Does Not Locate My HS820 Headset
Try the following:
1) Make sure the HS820 is fully charged up.
2) Remove the battery and SIM card from your phone for about 1 minute and put them back in.
3) As soon as your phone is booted up, access the "find devices" function for adding your HS820.
4) Hold the HS820 button down until the blue light is solid.
5) Then do whatever your phone requres to "search for devices."
6) Here's the key: as the phone is searching for devices, PHYSICALLY TOUCH touch the HS820 to the phone.
I couldn't get my HS820 to synch with my new Blackberry Curve the normal way and ultimately got it to synch by going through this process.
Sep 11, 2007 | Motorola Mobility HS820 Consumer Headset
Motorola HS820
the always on light mens that it is in pairing mode and wont go out until it has paired with a phone, if you wish to turn it off, press and hold for 3 seconds, it will then flash 3 times and then go off. Try pairing again by pressing and holding the button until the light stays on.
Jul 10, 2007 | Motorola Mobility HS820 Consumer Headset
Motorola Mobility HS820 Consumer Headset Logo
140 people viewed this question
Top Motorola Mobility Radio Communications Experts
Lawrence Oravetz
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
