Question about ACE -Air 18,000BTU Heat Pump A/C Free DVD Install it yourself Air Conditioner
Unit shuts down
The unit shuts down after operation with a E4 error message.
  • Gary Davd
    Gary Davd May 11, 2010
    check the drain
  • 26 Answers
The E4 error in display its mean the wire sensor connector to thermostat is loose pls fix , or have a problem in PCB Board on thermostat, pls go to the nearest repairman to repair that.
Thank you,have a nice day
Edgz
Posted on Jan 25, 2008
6ya staff
SOURCE:
Unit stopped, displayed E4
the unit is not draining properly. unplug it from the current outlet, check behind there should be two places to drain the machine. unplug the two drain plugs in the back and let the water empty out. the e4 error message comes up when the unit is filling up with water.
Sep 04, 2011 | Royal Sovereign Portable Air Conditioner
NOMA air conditioner/dehumidifier/fan model 043-5441-8 gives E4 error message and shuts down. This is a new unit and the owner's manual and Hisense USA company are useless! Help, please!
the unit is full of water, carefully lift unit into bathtub and drain all the water, both top and bottom corks removed. Usually caused by airlock in drain hose
Jun 29, 2011 | Heating & Cooling
My dishwasher says E4
The error code E4 means selector switch pads is stuck.
First try a hard reset. Unplug the unit for 10 minutes and then switch on the dishwasher. Most cases you won't get the error message.
If you still get the error message then you need to take to service center to get it repaired. Mostly, the inner connectivity between the pad and circuit board is loose/bad.
Hope this helps.
Shane
Feb 27, 2011 | Kenwood KDW243A Builtin Dishwasher
E4 error message
I have the same problem. Want to buy a new one, but would like to know if this can be fixed.
Apr 04, 2009 | Uniden TRU9485 Cordless Phone
Base unit displaying E4 after we experienced a power black out
e4 error code that means it ihas defective base unit. it happened due to a spike in the power lines that may cause this error
Feb 09, 2009 | Uniden 5.8GHz Cordless Phone
E4 Error
york hvac unit e4 error code Troubleshooting
Aug 05, 2008 | DeLonghi CF210 Portable Air Conditioner
Mio digi walker 220
application MioUtility,exe has performed an illegal operation and will be shut down. if the problem persists, contact the program vendor
program:MioUtility,exe
Exception:0xC000000D
Address:8C06DF8C
Mar 20, 2008 | GPS
Danby DWC283BLS Wine Cooler - Error message E3 & E4
Is the compressor running? I don't know this unit, but know that if you are too warm that is the first thing to check. In reading about another unit that had a different problem, it was mentioned that there is a ciruit board. If it has relays on it then these are the most likely culprit. They are either not making contact or staying in contact too long... sometimes just tapping each relay usually a black plastic component will cause it to work intermittently..Not sure if you can get these but call the company help line at 1-800-263-2629.
Jun 12, 2007 | Danby DWC283BLS Wine Cooler
E4 error being displayed
This error message is because the water tank is full. Just empty it out and put it back in and the AC will start to work again. If that doesn't work then I don't know what the problem is, but I just had the E4 error and did that and the problem was solved.
Mar 30, 2007 | Soleus MobilAir MA9000 Air Conditioner
Heating & Cooling Logo
1,045 people viewed this question
Top ACE Heating & Cooling Experts
Andrew Taylor
Andrew Taylor
deton8 von Splosion
Tom Chichester
Are you an ACE Heating and Cooling Expert? Answer questions, earn points and help others
