Question about Lexmark P4350 All-In-One InkJet Printer
Paper feed problem.
Paper wont feed into printer, pressure on paper from feed roller assembly is non-existant. If roller feed assembly is manually pressed onto paper, paper will feed. Getting the case apart to gain access is a problem as well how is that achieved? have managed to get small rear cover but can only see 2 screws on top of machine take it these will allow case to be split.
  • ElDavo Mar 01, 2008
    I have exactly the same symptoms with my Lexmark p6250. There's no obnvious way in to the machine to check out whether the roller spring has become disconnected or broken. :-(
I have just removed the panel where the power and USB cable lock into. It's a case of 1 screww from the rear and 2 catchs underneath the printer. From there you should be able to see the mechanism for the roller, a set of small white cogs. below that you should be able to see a very small spring which is acting as the pressure. Mine was still attached but as you say was pulling no pressure on the roller what so ever.
Solution:
Find yourself a large-ish rubber band and slip the band over the whole mechansim. Best way is through the paper feed slot, slip it over the roller and then move it through to the area where you removed the panel. Position the rubber band as far down the cogs as possible, don't worry the cog casing prevents the band interfearing with the cogs. Now pull the band reasonably tight and with the other hand test the pressure of the roller. Adjust till you feel OK with it. Now put the panel back in with the end of the rubber band trapped and poking out from the panel behind the printer, holding it in place. Redo the screw and give it a try.
My first attempt found it a bit too restrictive and feeded to sheets at a time but adjusted it once and its back to normal. I know its a bodge but its a cheap one and it uses a rubber band, just how I fixed my Punto's windscreen wiper, £120 part or a rubber band once a month... Mmmm...
Posted on Feb 21, 2009
    Genius:
  • 2,035 Answers
Feed the paper manually into the printer:
Place a sheet of plain A4 paper in the paper feed tray.
Move the paper support on the left-hand side to the left end of the paper.
Press the paper feed button.
If the paper does not feed, continue with step 2.
Check for any obstructions in the paper feed path:
Disconnect the cables from the back of the printer.
Open the front of the printer and check for anything that may be blocking the paper path.
Close the front lid and remove any paper from the paper feed tray.
Holding the printer in both hands, turn it upside down to see if anything falls out of the paper feed area. (Sometimes objects such as pens, paper clips and so on can fall into the paper feed area and cause blockages.)
Posted on Mar 16, 2008
I followed Ajkill's advice. After repeatedly cleaning the rollers with no clear-up of the problem(I had exactly the same problem), I read his solution, pulled out the cords and turned my printer over. A 3/4- inch screw fell out. Then my printer, with its shiny clean rollers, worked like a dream. Thanks a million!
Posted on Sep 18, 2008
The paper wont feed thru the printer. What is the problem?
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button.
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Oct 16, 2009 | Lexmark Office Equipment & Supplies
Paper feed
Please follow these steps :
Feb 25, 2009 | Dell Office Equipment & Supplies
Paper wont feed in my dell 944 printer
Okay try these steps \:
Feb 25, 2009 | Dell 944 All-In-One InkJet Printer
Paper Jam
Feb 16, 2009 | HP DeskJet 3650 InkJet Printer
I receive out of paper message with paper loaded and ready
Try these steps :
3. Turn the printer on, load some paper, and press the Form Feed button. (On the X83, press the Select button.)
Jan 27, 2009 | Lexmark X5150 All-In-One InkJet Printer
Paper jammed
Nov 25, 2008 | Canon MX700 Office All-In-One InkJet...
Paper does not feed completely properly.
If the error still exists then its the problem with rollers it needs to be serviced..
Good luck..
Nov 13, 2008 | Lexmark P4350 All-In-One InkJet Printer
Lexmark z1300
Aug 19, 2008 | Lexmark Z1300 InkJet Photo Printer
Paper fed
Mar 08, 2008 | Lexmark P915 InkJet Photo Printer
Paper jam
Feb 28, 2008 | IBM Lexmark Z715 InkJet Printer
Lexmark P4350 All-In-One InkJet Printer Logo
724 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
