Question about Ovens
Wall oven again
Our westinghouse we discovered needs a new fan motor, the element went bright red the other night where normally it never does do you think it needs a new thermostat or would it be the fact that the fan wasnt working correctly? also there is a lot of blackness around the insulation and wires at the back of the element wires as it has been singed, is this a sign of danger or is it perfectly normal? thanks
    Scholar:
  • 64 Answers
Singed wires suggest electrical fault or excessive heat, i personally suggest you have the unit checked out by a professional to ensure your own safety.
Posted on Jan 22, 2008
Last night, we were using our Frigidaire oven to heat some salmon. My wife openned the oven door and there was a bright flash with sparks and a crackling noise, and a 1/2 inch portion of the element caught...
Kill the power to the stove. L2 is always hot to the element. If it welded itself to the frame whats left of the element stays hot. Easy fix but power needs to be OFF
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Apr 17, 2010 | Ovens
Heating elementglowing bright red funny smell
I
make sure the fan is working o/k, because if it is not, then the element will get bright red hot.
If the fan is working o/k, then the element will still get red hot, but not bright red.
If the fan is not working, then it needs replacing.
Jan 15, 2010 | AEG D5701-4 Electric Double Oven
Replace fan motor in an electric fan oven
For all Free appliance repair videos visit our VIDEO TUTORIALS
1, If the fan motor in the back of the oven is going round and the temperature light is on (normally little red light), but there is no heat then you will probably need a new oven element, these are generally very easy to fit and readily available from our website these can be tested with a electric meter.
To gain access to the NEFF element you will have to remove the back plate from inside the oven. Once removed you will see the fan and element, if you look closely at the element you will probably see a small hole burnt in it where it has blown. Sometimes however there is no evidence of a fault but the element is open circuit ie: broken inside the element casing, either way it will need replacing. Some elements will are fixed from inside the oven and some are held in place by nuts from the rear of the machine.
2, If your NEFF fan oven is getting warm but takes a very long time to cook or is burning the food more on one side than the other, then you need to check if your oven fan motor is working you will see the blade turning fast if it is ok. if the element is heating but the fan motor is not blowing the heat into the oven then you need To replace the oven fan motor is a little more expensive and a bit more involved.
3. If you have the opposite problem ie: your oven is over heating and burning everything then you will need to replace your NEFF oven thermostat
4, A quite common and easily overlooked answer is if your NEFF oven is not working at all ie: no heat and no fan then the chances are that someone has put the oven timer into AUTO mode, simply put oven back to MANUAL mode and all should be working again.
Jan 13, 2010 | Neff B1421 Electric Single Oven
Oven on fan setting not working ;fan is still working but oven is not getting hot on large oven
The oven element is faulty, and needs replacing.
This is located at the rear of the oven compartment behind a removeable cover.
Please rate my solution.
Thankyou.
Jan 12, 2010 | Neff U1452 Double circotherm plus Electric...
Need to put new bulbs and elements in fan oven
the bulbs are screw fit normally Neff fan oven element video. 1, If the fan motor . in the back of the oven is going round and the temperature light is on (normally little red light), but there is no heat then you will probably need a new oven element, these are generally very easy to fit and readily available from our website these can be tested with a electric meter.
To gain access to the NEFF element .you will have to remove the back plate from inside the oven. Once removed you will see the fan and element,. if you look closely at the element .you will probably see a small hole burnt in it where it has blown. Sometimes however there is no evidence of a fault but the element is open circuit ie: broken inside the element casing, either way it will need replacing. Some elements will are fixed from inside the oven and some are held in place by nuts from the rear of the machine.
Jan 12, 2010 | Ovens
The bottom (fan oven) of my Neff U1721 made soft bang noise and failed. The fan stopped, the oven light went out and the thermostat light. I replaced the burnt out heating with a new element with a 32.5...
The power to the fan and thermostat is the fault. You will need to trace wiring from these elements to power source and I suspect that where the power cord meets the oven is where you'll find the cause.
Dec 15, 2009 | Neff U1721 Double circotherm Electric Oven
Neff b1421n not heating up, grill and fan ok
breakers off ,,,back wall bottom center is a mounting plate 2 screws to take out the pull out wires and remove wires(careful not to let them slide back in)install new element...wires first the push back in place(no need to open back) don't forget breakers on now...you did it.... good for you.
Aug 25, 2009 | Neff B1421 Electric Single Oven
Neff oven fan not turning and element blown. Is the motor bad as well?
it might also be the timer For all Free appliance repair videos visit our VIDEOTUTORIALS Nefffan oven element video1, If the fan motor in the back of the oven is going round andthe temperature light is on (normally little red light), but there is no heatthen you will probably need a new oven element, these are generally very easyto fit and readily available from our website these can be tested with aelectric meter.
To gain access to the NEFF element you willhave to remove the back plate from inside the oven. Once removed you will seethe fan and element, if youlook closely at the element you willprobably see a small hole burnt in it where it has blown. Sometimes howeverthere is no evidence of a fault but the element is open circuit ie:broken inside the element casing, either way it will need replacing. Someelements will are fixed from inside the oven and some are held in place by nutsfrom the rear of the machine.
2, If your NEFF fanoven is getting warm but takes a very long time to cook or is burning the foodmore on one side than the other, then you need to check if your oven fan motor is working you willsee the blade turning fast if it is ok. if the element is heating but the fan motor is not blowing the heat into the oven thenyou need To replace the oven fan motor is a little moreexpensive and a bit more involved.
3. If you have the opposite problem ie: your oven is over heatingand burning everything then you will need to replace your NEFF oven thermostat
4, A quite common and easily overlooked answer is if your NEFF oven is not working at all ie: noheat and no fan then the chances are that someone has put the oven timer into AUTO mode,simply put oven back to MANUAL mode and all should be working again.
Jun 19, 2009 | Neff U1452 Double circotherm plus Electric...
Oven not heating up! Fan works. Grill works OK. Don't know what model it is? It's stainless with black hideaway buttons. It's a built-in Neff single oven. We had just roasted a duck, everything was...
Hi, The main problem I find with this fault is the fan element has blown. This usually cannot be seen without taking the fan cover off inside the oven. Thanks.
Jun 15, 2009 | Neff B1641 Single circotherm super...
Ovens Logo
100 people viewed this question
Top Ovens Experts
Marvin
Marvin
Sal De
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
