Question about Creda W100FW Front Load Washer
Zanussi washing machine
Could you please let me know which end of the washing machine water hoses goes where ???????? Is the end with the filter plugged to the mains or is it connected to the actual machine ??? Very many thanks
Juan Ignacio
  • 126 Answers
Can you explain the problem more? :)
Posted on Jan 22, 2008
My zanussi washer zwh6160 p stopped working yesterday. It stopped with a load in it. We gad to manually drain it, then git the door open. We cleaned the filter and inlet pipe filter. We switched it on
Considering that machine did not show any error first check that is not activated option "rinse hold" what mean's "stop drum with full of water". I advise you to make a simple test that will show you where the problem is. In the washing machine or somewhere else. Disconnect the drain hose and lift it up to 1m in height and its end hold over the tub or some larger container. Select short drain program and press the start / pause button. If drain hose ejects a solid water stream then is a problem in-house installation of drain water. If does't or poorly drain water then is problem in the washing machine.
Nov 10, 2014 | Zanussi Washing Machines
Zanussi 1250 washing machine FLS 1383 W does not drain
Sump hose probably blocked. Tilt washer backwards so u can get under it. Pipe comes from bottom of tub too filter housing, squeeze it you will be able too feel if anything is stuck inside it, simply remove pipe at one end and remove blockage.refit pipe and test
Jun 20, 2013 | Zanussi Washing Machines
It might be waiting for water feed as a guess?
If you have checked that the hot and cold water taps are turned on fully and the hoses are not kinked or squashed at the back, it is worth while checking both the hot and cold water inlet filters. Turn the taps off and remove both hoses at the washer end. Inside each inlet port there is normally a little filter which should just slide out. Clean if necessary and replace each one and the hoses. If after turning the taps back on there is no improvement, the problem is symptomatic of a malfunctioning hot or cold water control valve. Sorry but it needs a service call and a check that it isn't the control PCB ;-0(
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck,
John C
Sep 04, 2011 | Zanussi Washing Machines
Washer goes through program very quickly, doesn't spin for long or get up to speed?
3 things to check
1. Make sure the extra quick wash is not selected
2. Make sure the drain hose is correctly positioned that the water can drain freely and the end does not ever get submerged
3.Make sure filter is clear
Other than that without an error code I can't see what else it could be.
let us know what you find please
Feb 01, 2011 | Zanussi ZWF1430W Front Load Washer
My Zanussi ZWF14581 washing machine shows an error
The error code E10 is in relation to low water pressure.Have you checked that the hose at rear is not kinked or check the filters in the ends of the hose.Also make sure when you have hose off check the pressure in the supply.If all that is ok then it could be a faulty solenoid valve.
Hope this helps.
May 09, 2010 | Washing Machines
I have a Zanussi 1600 Jet System Washing Machine, it has started the cycle and 4 mins into it, an E10 error reads on the display, have turned the machine off, and back on, checked pipes, can see you...
This error code relates to water pressure check that the pipes are not kinked,check the water valves are fully on also check if the little filters in the end of the hoses are cleaned.Make sure that the mains water pressure has not been reduced.There could still be a fault with one of the inlet valves but it is most probably the little gauze filters
Apr 26, 2010 | Zanussi IZ161S Front Load Washer
Zanussi washing machine filter
Open the panel at the bottom right of the front of the washer. Then pull out the drain hose and pull the plug from its end - this will drain most of the water. Then the filter turns anti-clockwise - if it is too stiff to turn by hand I use an open set of pliers or strong scissors to give more grip (It may be an idea to put a cloth between the pliers/scissors and the filter to offer some protection.
Jun 15, 2009 | Zanussi F1245W Front Load Washer
Zanussi ZWF1437W E23
E23 indicates Drain pump faulty; Wiring faulty; PCB faulty.
The service information also says it should stop with the door open.
Unplug the appliance and manually remove the water via the filter or front drain point if it's fitted.
Drain it into a shallow dish, tighten the filter when you need to stop the water (or plug the hose if draining via a hose) while you empty the container.
Once empty, try the door again.
Take the filter out and clean out any debris in it.
Plug the appliance in and put the machine on a drain programe.
Listen/look at the open filter to check that the drain pump is running.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jan 27, 2009 | Washing Machines
Zanussi ZWF 1021 W The door won't release after the end of any cycle, even empty or spin. What can I do to get the clothes out?
First thing would be to check the filter at front of machine as any blockage will cause this problem.
Try this and come back for further assistance.
Dec 06, 2008 | Zanussi Washing Machines
Zanussi F1045W Front Load
indicated low water pressure from your external supply or blocked filters in the fill hose. turn water off, remove hose and check filter in end of hose - it is just a bit of gauze. also look into the valve and clean out if needed
Jul 20, 2008 | Zanussi F1045W Front Load Washer
Creda W100FW Front Load Washer Logo
23 people viewed this question
Top Creda Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
Are you a Creda Washing Machine Expert? Answer questions, earn points and help others
