Question about Canon FAX-L350 Plain Paper Laser
Changing where the receiving faxes come from
How do I change where the receiving faxes come from? It used to print out at the top but now it prints out below.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Canon Master
  • 1,363 Answers
Sounds like you have a door or switch open. Some models have a door in the back that you can open and receive the faxes in the back of the machine, others have a lever.
Posted on Jan 22, 2008
6ya staff
SOURCE:
Samsung 4521f print fax received in memory
Changing the Fax Setup options:
1 Press Menu until "Fax Setup" appears on the top line of
the display.
The first available menu item, "Default-Change", displays
on the bottom line.
2 Press the scroll button ( or ) until you see the desired
menu item on the bottom line and press Enter.
If you select "Default-Change", you will see "Resolution".
Press Enter again.
3 Use the scroll button ( or ) to find the desired status or
use the number keypad to enter the value for the option
you have selected.
4 Press Enter to make your selection. The next Fax Setup
option appears.
5 If necessary, repeat steps 2 through 4.
6 To return to Standby mode, press Stop/Clear.
Read More..FAQs Mono Multi function Receive fax for SCX 4521F
and Tech Support Printer
Jun 27, 2014 | HP Office Equipment & Supplies
How can I delete the memory on a brother mfc-465cn printer fax machine? It will not receive faxes due to this
Review page 65 in your manual. Changing the "Advanced Fax Operations:"
If received faxes are left in your machine's
memory when you change the Advanced Fax
Operations, the LCD will ask you one of the
following questions:
Erase All Fax?
Yes - Press 1
No - Press 2
Print All Fax?
Yes - Press 1
No - Press 2
• If you press 1, faxes in the memory will
be erased or printed before the setting
changes. If a backup copy has already
been printed it will not be printed again.
• If you press 2, faxes in the memory will
not be erased or printed and the setting
will be unchanged.
Dec 11, 2009 | Brother MFC-465CN InkJet Printer
Can't get my intel fgax 1860c to receive fax's....just started...it will ring and says it is recieving but i get no fax....
Hi
Thanks for using FixYa. Receive faxes to memory option might be enabled and all the faxes are been stored in the internal memory and not been printed. to retrieve them you can try printing from the memory. You can retrieve these faxes by changing the receive mode from main menu.
You can also see the operation guide for your Intellifax model 1860c from this link--
Brother Intellifax 1860c operating instructions & guide
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Oct 13, 2009 | Cell Phones
How can i generate incoming call report ?
To print a report:
  1. Press the [Menu] button on the Control Panel, until Reports is displayed on the top line of the Display Screen. The Phone Book menu item will be displayed on the bottom line.
  2. Press the right or left arrow button to scroll until the report or list you want to print is displayed on the bottom line.
    • Phone Book: Phonebook list
    • Sent Report: Sent fax report
    • RCV Report: Received fax report
    • System Data: System data list
    • Scheduled Jobs: Scheduled job information
    • MSG Confirm: Message confirmation
    • Junk Fax List: Junk fax number list
  3. Press [Enter] to print the selected information.
Your machine can print reports containing useful information. The following reports are available:
  • Phonebook List: This list shows all of the numbers currently stored in the machine's memory as Speed Dial and Group Dial numbers. You can print this phonebook list using the [Phonebook] button.
  • Sent Fax Repor: This report shows information of the faxes you recently sent.
  • Received Fax Report: This report shows information of the faxes you recently received.
  • System Data List: This list shows the status of the user-selectable options. You may print this list to confirm your changes after changing any settings.
  • Scheduled Job Information: This list shows the document currently stored for Delayed faxes or Toll Save faxes. The list shows the starting time and type of operation.
  • Message Confirmation: This report shows the fax number, the number of pages, the elapsed time of the job, the communication mode, and the communication results. You can set up your machine to automatically print the message confirmation report after each fax job.
  • Junk Fax Number List: This list shows up to 10 fax numbers specified as the junk fax numbers by using the Junk Fax Setup menu. When the Junk Fax Barrier feature is turned on, incoming faxes from those numbers will be blocked. This feature recognizes the last 6 digits of the fax number set as a remote fax machine’s ID.
  • Multi-Communication Report: This report is printed automatically after sending documents from more than one location.
  • Power Failure Report: This report is printed out automatically when power is restored after a power failure, if any data loss occurs due to the power failure.
NOTE: The lists you have set to automatically print out will not print out when there is no paper loaded or a paper jam has occurred.
Aug 04, 2009 | Xerox PE120i Laser Printer
My HP 6100 series all in one wants to align cartridge
This document explains the different results obtained when using or not using the Automatic Reduction (or Auto Reduction) Feature. The following issues usually result when the Automatic Reduction feature is not set correctly:
  • Faxes printing too small
  • Faxes printing on more than one page
  • A blank page ejecting between each printed fax page
This feature can be turned ON (the default) or OFF from the Advanced Fax Features menu. The two main purposes of the Auto Reduction feature
  • Fits a received fax page onto the paper size loaded in the paper tray and selected in the paper size setting of the Basic Fax Setup. For example; if letter size paper is loaded in the paper tray and selected in the fax settings and a legal size document is received, each page will be reduced and printed on one letter sized paper.
  • Allows the addition of the fax header margin at the top of every printed fax without extending the fax onto another page. The fax header is printed at the top of every fax received with identifying information about the fax sender. Since this increases the overall page length, the page must be reduced to fit onto one page. Auto reduction slightly shrinks the fax as it is received so the entire page will print on one piece of paper even though a top margin is allowed for the fax header.
Jun 16, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Printing wrong fax number on paper headings
HI
Cant find a manual for that model but this is close enough for changing the details i think.
Download it from here
http://safemanuals.com/user-guide-instructions-owner-manual/CANON/IMAGERUNNER%202025I-_E
Feb 16, 2009 | Canon imageRUNNER 3035 Black and White...
Received fax in memory but not printing
I just checked this out as I had the same problem. It seems that the machine is programmed to stop printing faxes when the Toner is "out". Even though the toner is not completely out. I was positive that the note on the screen was false since I could print out documents and copies (I am not using Samsung original Toner). But the fax will refuse to print.  I fixed this by changing the toner (again with a non-Samsung toner) and it is printing all the faxes in memory.  It is stupid that they haven't set up a menu item to force it to print all the faxes in memory but voila, that seems to be the fix. I guess this is a way for them to control that we only use Samsung toner.
Dec 12, 2008 | Samsung SCX 4521F All-In-One Laser Printer
Lexmark x5150 all-in-one inkjet printer. trying to get the fax to work. i have dsl.
You may have to experiment to get the fax to work on DSL. Try these suggestions: press MENU, then scroll to:PRINT REPORTS. Scroll to HELP LIST and press SET BUTTON. Press START button to print HELP LIST. On the HELP LIST printout, locate the FAX MENU. Using a cell phone, call your fax and see if the fax answers. If not, try changing the following settings (change one setting, then call the fax with the cell and see if it answers, Make sure you set each changed setting back to what it was, until you find the right one.) try changing: RING DELAY, F/T RING TIME, EASY RECEIVE, OVERSEAS MODE. Also on the HELP LIST, find the INITIAL SETUP MENU. Select RECEIVE MODE, and try each option, again calling the fax with your cell until it answers.After you get the fax to answer calls from your cell, try sending and receiving with another fax, or use Brothers AUTOMATIC FAX-BACK SYSTEM, which will automatically send your fax a test printout when you call it. Just call 1-800-521-2846 from your fax machine, IT MAY BE ALREADY PROGRAMMED INTO YOUR MACHINES AUTO DIAL LIST, AUTO DIAL NUMBER 001..
Aug 16, 2008 | Lexmark Office Equipment & Supplies
Canon pixma mp530 all-in-one printer set up
Receive Mode Setting
On the operation panel, press the following buttons to select the appropriate receive mode.
  1. Press <Fax>.
  2. Press <Menu>.
  3. Press the right or left arrow button to select [Receive mode set], then press <OK>.
  4. Press the right or left arrow button to select the receive mode that best suits your needs, then press <OK>.
    FAX ONLY MODE: When you want to receive only faxes automatically with your machine, or have a dedicated telephone line for FAX use only.
    MANUAL MODE: When you receive mainly voice calls and sometimes faxes, or want to receive faxes manually.
    ANS MACHINE MODE: When you want to receive voice messages on your answering machine and receive faxes automatically.
    FAX/TEL AUTO SW: When you want to receive faxes automatically as well as voice calls.
    DRPD: When you have subscribed to a DRPD service with your telephone company.
  5. Press <Stop/Reset> repeatedly to return to fax standby mode.
Solution: Changing the TX report MP530
Change the TX Report 1. Press the <Menu> button to display [FAX SETTINGS].
2. Use the [ left.gif] or [ right.gif ] to select [TX SETTINGS] then press <OK>.
3. Use the [ left.gif] or [ right.gif ] to select [TX REPORT] then press <OK>.
4. Use the [ left.gif] or [ right.gif ] to select [PRINT ERROR ONLY] or [PRINT FOR EACH RX] then press <OK>.
5. Use the [ left.gif] or [ right.gif ] to select [YES] or [NO] for [ATTACH TX IMAGE:] then press <OK>.
6. Press <Stop/Reset>.
Changing the Paper Size, Type and Source
Changing the Paper Source
Before printing, confirm that the location where you have loaded paper is selected as a paper source. Press <Feed Switch> to change the paper source.
(A) Auto Sheet Feeder Lamp
(B) <Feed Switch>
(C) Cassette Lamp
Note: Press <Feed Switch> so that the Auto Sheet Feeder Lamp lights when loading paper in the
Auto Sheet Feeder and the Cassette Lamp lights when loading paper in the Cassette.
You can also select the paper source with the printer driver when printing from the
computer.
Changing the Page Size and Media Type
Note: The asterisk <* > on the LCD indicates the current setting.
1 . Press <Paper>.
When you do not need to change the page size, press <OK> to proceed to step 4.
2 . Use leftright.gif to select the page size: A4 / B5 / A5 / 4x6 / 5x7 / C-CARD / 8.5x11 / 8.5x14
sizetypelcd.gif 3 . Press <OK>.
4 . Use leftright.gif to select the media type: PLAIN / PHOTO PRO / PHOTO PLUS / MATT PHOTO / GLOSSY
Note: In order to obtain optimal quality print results, when copying photographs, use Canon-recommended Photo Paper Pro or Photo Paper Plus Glossy.
5 . Press <OK>.
Entering the Date and Time Note: When your machine is connected to a computer with the MP driver installed, even if the date and time are entered from the Operation Panel of the machine, the date and time will be read from your computer every time you start the computer, turn the machine on, or disconnect and connect the USB cable. When using your machine connecting to your computer, set the date and time on your computer precisely.
The date and time will be reset when you disconnect the power cord or there is a power failure. In this case, you can set it again on the machine. Alternatively, it can be read from your computer and set on the machine by connecting the machine to your computer with the MP driver installed.
1. Press [FAX], then press [Menu].
2. Use [ left.gif] or [ right.gif] to select <USER SETTINGS>.
3. Press [OK] two times.
datetimeset.gif 4. Use the numeric buttons to enter the date and time (in 24-hour format). Enter only the last two digits of the year.
Note: If you misentered the date and time, use [ left.gif] or [ right.gif] to move the cursor under the number to enter the correct number. Three formats of date are available.
5. Press [OK].
6. Press [Stop/Reset].
I hope it helps!!!
Nov 25, 2007 | Canon PIXMA MP530 All-In-One InkJet...
Canon FAX-L350 Plain Paper Laser Logo
75 people viewed this question
Clive
Clive
old marine
old marine
Ekse
