Question about Panasonic Toughbook Y2 Notebook
Modem cannot read port name in registry. cannot disconnect the pc from the telephone line-no modem detected
  • pinkalee Jan 25, 2008
    Yes! the error could be the pcmcia modem card! THANK YOU!
  • Anonymous May 11, 2010
    have u re-install your operation system
    Novelist:
  • 123 Answers
Yes! the error could be the pcmcia modem card.
A PCMCIA Card is used to connect to your laptop different components that you it doesn't have.
More information about PCMCIA
For most ISPs all you need to connect to the Internet is a network card. Check if your laptop has an integrated network card. Then contact your ISP and ask him if you need something else except a network card to connect to Internet.
Posted on Jan 27, 2008
6ya staff
SOURCE:
My dimension 3100 is not detecting a modem
Sir,
Respectfully please first check if there is a modem in the desktop PC since the dimension 3100 is not pre-equipped with a modem. you have to attach an internal modem manually on one or more PCI slots on the mother board.
the process is given here....
  • Turn off the computer. Unplug the power cord from the electrical outlet. Disconnect the power cord, attached peripheral devices and any other cables.
  • 2 Locate the cover release latch on top of the computer, near the back. Place the computer on its side, with the removable cover facing upwards. Slide the cover release latch back and lift the removable cover off of the computer. Set the removable cover aside.
  • Locate the PCI and PCI Express slots near the bottom of the system board. Select a slot that corresponds with your internal modem card. Open the card retention door on the back of the computer and remove the filler bracket for the card slot you will be using.
  • 4 Place the internal modem card into the appropriate card slot and press it firmly into place. Close the card retention door. Replace the removable cover and return the computer to an upright position.
  • 5 Connect one end of the telephone cord into the LINE port on your internal modem card; plug the remaining end into a telephone jack. If desired, connect a telephone to the internal modem card via the PHONE port.
  • 6 Reconnect the power cord and all previously disconnected cables. Plug the power cord into an available electrical outlet. Turn on the computer. If any installation software came packaged with the internal modem card, run the program and follow the onscreen directions. Your internal modem is now ready for use.
  • May 06, 2011 | Dell Dimension 3100 PC Desktop
    My ISP gave me a USB modem(Wanadoo ADSL) which i connect my telephone line and a USB to connect the modem to my pc.I bought a D-link DIR-825.Do i connect the telephone line directly to the DIR-825 or i...
    Plug the modem filter in the wall, plug the modem into the filter, then plug the router into the modem. From there you should be able to set up your network or personal internet.
    Mar 12, 2011 | D-Link DIR-825 Wireless QuadBand Router
    Need manual for connecting fax to phone line and computer
    Simple:
    * one telephone-wire from wall-outlet to port on FAX labelled "line" or "telco";
    * one telephone-wire from port labelled "phone" (or an icon of a telephone) to the port on your computer's modem labelled "tel" or "telco" (if your modem has more than just one port).
    So, "incoming" telephone-calls go the FAX, to be "answered" by the FAX, while "outgoing" dial-up-Internet connections from your computer's modem "pass-through" the FAX, and to to the wall-port, and further along to the Internet Service Provider.
    Jun 15, 2010 | HP DESKJET PRINTER, HP OR COMPATIBLE
    D-link DSL-320T Dead
    yes it can be a problem... thats why it is advisable to buy telephone line surge protectors or disconnect the telephone cable connecting to DSL router.
    Aug 05, 2009 | Computers & Internet
    My modem cant work
    633 - The port is already in use or is not configured for Remote Access dialout
    This error can occur if:
    The modem is actually in use - make sure you don't have other applications that are using the modem. Applications that can use the modem include fax software, terminal software (like HyperTerminal), as well as voice software including software that can make your modem an answering machine or speakerphone.
    One way of seeing all running applications is to press CTRL+ALT+DEL and look at the Task List or Task Manager. This will display the actual program names - it may be difficult to pinpoint which, if any, programs are accessing the modem. Terminating tasks are about the only way - however, if you terminate certain tasks, your system may crash or become unstable.
    The telephone.ini file is missing or damaged - If the telephone.ini file is missing or damaged, you can create a new one by running Tapiini.exe - this file is in the \windows\system folder. Before you run this, rename the telephone.ini file and reboot your PC if it already exists. Then, run the tapiini.exe file. This program will run very quickly and may not appear to do anything. You can verify the program created the telephone.ini file by searching for it.
    The telephone.ini file is a Microsoft Windows file that stores settings for all TAPI-enabled applications including DUNS.
    Make sure the modem named in the DUNS entry matches the name of your installed modem - You can check the name of your modem in ControlPanel->Modems.
    Windows 95/98 - Can occur if the Unimodem TAPI file (unimdm.tsp) is missing or damaged. See MS KB Q150619
    Windows XP - Can occur if another device's driver has a conflict with the modem driver. MS KB 324760 indicates this can occur with older Palm Desktop HotSynch Software.
    Apr 21, 2009 | Smartlink All 56K Modems: V.92 PCI Chipset...
    Hi, I am setting up a canon mp730 for a friend. I have run into a problem with the fax phone line. I have connected the lines correctly to the copier and her answering machine but when I try to use the...
    Remove the connection and once again try to re connect the lines between the copier and phone line . You might have some connection . Just give a try .
    If this doesnot work . I will let you know how to proceed further .
    Oct 12, 2008 | Canon Office Equipment & Supplies
    The Computer Modem does not hang up the telephone line to the computer. If the telephone line remain plugged into the computer port the line remains open until it is unplugged from the computer. What...
    depends what you are doing at the time, but you would have to click disconnect as a rule, the only time it will do it automatically is when you send and recieve e mails as there is an option in outlook express to disconnect after send and recieve.
    Sep 08, 2008 | Computers & Internet
    I have a Arris TM502G and it's refusing to detect telephone 1 and my phone isn't working but my internet and my cable is working. everything is hooked up right and I've hit reset a few times and it's still...
    Taken from the user guide:
    http://www.arrisi.com/support/guides/_docs/TM502_User_Guide.pdf
    Wiring Problems
    If the Telephony Modem begins flashing all its lights for more than 10 seconds, this indicates a problem
    with the telephone wiring — the red and green wires may be shorted (touching), or there may
    be undesired voltage on the lines. If this pattern persists for more than 10 seconds, disconnect the
    telephone lines from the Telephony Modem, then call a wiring technician for assistance.
    Jul 13, 2008 | Televison & Video
    For dummies
    Hello, Good question..Phone line to DSL modem, Ethernet cable to WAN port on Router. If connecting a PC wired to Router, connect Ethernet cable from 1 of 4 LAN ports on Back of router to ethernet port on PC. This would be Physical connection...
    It's always smart to set a restore point in case something goes wrong during installation of any program. For wireless connection from laptop or PC: install router software on computer. Reboot computer. In browser address bar enter 192.168.1.1. This brings up a window for user name and password. Enter "admin" for both. This allows you to change many settings including Changing SSID(Router Name), User name and password. Enabling WEP or WPA security. Hope this Helps, Good Luck..!!
    Mar 26, 2008 | NetGear RangeMax WPN824 Wireless Router...
    Internet connexion
    Hello marieclaude,
    How exactly are you trying to connect? via modem, if that is the case the "disconnected" warning or notice you are seeing is probably the LAN line. That is the other port that looks like a telephone jack, but is a little bigger.
    If you can get online and there is no problem except that annoying notice you can; go to control panel, double click 'network connections', right click the 'Local Area Connection' next to it should read - disconnected, after right click - select 'disable'.
    Now you won't get that message or that box with the red x in the corner anymore. If you ever do need to connect through that port in the future, you will have to go back to control panel, follow same steps and then select - 'enable'.
    Regards,
    -Chester
    Dec 27, 2007 | Acer LXA3706003 Notebook
    Open Questions:
    See all Panasonic Toughbook Y2 Notebook Questions
    Panasonic Toughbook Y2 Notebook Logo
    73 people viewed this question
    Top Panasonic Computers & Internet Experts
    Ekse
    Marvin
    Marvin
    Are you a Panasonic Computer and Internet Expert? Answer questions, earn points and help others
