Question about Fisher and Paykel Fisher & Paykel Washer
Top loader beeps every second - lights 3,5,7 & 8 all lit
My F&P smart-drive 9 died today. It won't reset (60 second power down) and just comes back to where ever it was in the failure and won't advance. Trying to start another wash cycle sees the washer add water in 1-2 second bursts and then time out after about 15 seconds. Manual makes no mention of this particular error.
  • 4 more comments
  • miss6litre Jan 23, 2008
    my washing machine also died 2 weeks ago with the same problem. one minute it was working and than it came up with the same error message and symptons.
  • hazybob Feb 02, 2008
    I have the same problem it was working fine then it just started beeping then it would start and stop at intervills then after about 4 or 5 intervills it would just stop it sounds like it is trying to work but something is restricting it
  • elricho22 Feb 16, 2008
    I have the same problem with Fisher and Paykel as well.
  • Anonymous May 19, 2008
    same here..it trys to work but stops and beeps continuously. I cycled the switch under the circuit boards (no change) then move the switch under the lid... and it all came good. Thanks guys!
  • Anonymous Jun 15, 2008
    My washers Out-Of-Balance micro-switch was rusted/broken and stuck in the "on" position, indicating the washer was always out of balance and hence the error.
    Steps to fix the problem:
    0. Disconnect washer from power socket
    1. Remove two screws from back of control touch panel
    2. Remove control touch panel
    3. Remove screw from front-middle of lower circuit board
    4. Remove lower circuit board to reveal Out-Of-Balance micro-switch at back-right under lower circuit board
    5. Push washer bowl far in the direction of the Out-Of-Balance micro-switch
    6. Replace micro-switch if it doesn't click each time the washer bowl moves in that direction
  • gleno_wilson Mar 01, 2009
    yes the same problem, just that'' out of balance'' micro-switch,needed replacement.not clicking back out , staying in the ON position.
    Sergeant:
  • 351 Answers
Check the reed switch under the lid,and the oobalance switch under the lower board they may be rusty so the machine thinks the lid is open causing this fault.hope this helps.
Posted on Mar 07, 2008
  • Hira Barrett Sep 27, 2011
    That sounds more like a rotor position sensor fault on the motor.
I had this exact problem with a smartdrive 703, I was quoted over $150 just to come and see. I didnt have a replacement switch, but a bit of marsking tape (temporarily) till I get the part has worked perfectly. Thanks so much. I dont have a husband and now dont feel like I need one!!!
Posted on Jul 26, 2008
Thanks to whom ever you are who posted the step by step guide to fixing my problem, which was also OOB Switch. I found that a wee little button was the core of my problem. Thanks lots, no need for a new washing machine for moment. :)
Posted on May 13, 2010
  • stynee1 May 13, 2010
    Just curious as to what would have been the cost to have someone out to look at it. Does anyone know or wish to share? :)
Hey, thanks for that, my washing machine is fixed. I took the  micro-switch out as you said and flicked the small switch on the side of the unit a dozen or so times until it was working properly again. It was stiff to start with but it did free up. I am hoping it will stay ok and i wont need to buy a new one.Cheers from NZ.
Posted on Apr 23, 2009
Had the same problem with a 10yr old F&P excellence 7.5kg. Inspected the switch and all was ok - the bowl seemed out of alignment though and we found that re-levelling the machine fixed the problem.
Posted on Dec 11, 2008
This worked for me
Posted on Jun 21, 2008
I have a Sony VAIO VGN-NS20E laptop. When I start it the message comes " SMART Failure Predited on Hard Disk. Warning: Immediately back-up your data and replace your hard disk drive. A failure may be
Smart error, failure or S.M.A.R.T. has been tripped. They all mean the same thing. Your PC's HDD is dying, how fast? Nobody knows. So what it really comes down to is that you have a limited amount of time to access your HDD in more ways than your panicked mind can come up with right now. So until you can figure out a plan, the most important thing you can do is turn off your PC. Remember running your HDD is using up valuable time. So remove the HDD, Go get a reliable replacement (your HDD is dying) and install your favourite O/S. At this point I would suggest you purchase an external HDD enclosure so can hook up the old HDD and transfer back the important files.
Dec 18, 2014 | Sony Computers & Internet
Kssc42qms01 side-by-side. About a month ago refridgerator side was too warm. Removed top grill and cleaned coils. All was fine until today. High temp warning (beep) and both compartments now reading...
I just checked my sheets on this unit, this unit has to be turn off first, turn it back on and can only enter the service mode within 13 second after power up. Hold the filter rest then power button for three second. I hope this helps. Good Luck
Oct 01, 2013 | KitchenAid Refrigerators
I have a 1998 Jeep cherokee sport. Was driving today and it died. Now there is no spark and no power to fuel pump. Changed fuel pump today and it won't run. Recently replaced oxygen sensors too
U need to check the crankshaft position sensor. The fuel pump will only have power for 2 seconds I till it sees a crank signal. It' controls the asd relay which turns on your spark and fuel
Apr 19, 2013 | 1998 Jeep Cherokee
My fisher and paykel smart drive 9 5.5kg won't power up
It is possible that the machine does not start off the cycle because there are errors due to feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting from the flow of water into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
If there is no power it can be due to a failure of the power supply.
Jan 15, 2013 | Fisher and Paykel Washing Machines
SMART Failure Predicted on Hard Disk 0: WDC WD3200BEVT-75ZCT2-(S1) WARNING: Immediately back-up your data and replace your hard disk drive. A failure may be imminent. Press F1 to Continue
just means its time to backup all your information, as if the hard drive does fail theres a good chance you may lose some or all of your information.
hard drives aint that expensive around 30 pounds +
and you can replace it with any sata hard drive.
Jun 17, 2012 | Western Digital Computers & Internet
Fisher and Paykel Smart Drive Excellence 9 5.5kg won't work at all, no power, no lights, no nothing! help :(
it has fuse boards and the probally burnt out one or more of them ,, if so its cheaper to just junk it .
Mar 29, 2012 | Washing Machines
Red light on front is lit up- beeping- assume it has lost its battery power
You are assuming right. With the UPS on push and hold the on button for 3 seconds. This will start a self test. If the UPS dies then replace batteries
Aug 15, 2011 | APC Smart-UPS 1000VA UPS System
I can't get the control panel to reset. The wash cycle light comes on but it just beeps and the dishwasher won't start. I press the start button and it stops beeping for a minute but it still...
II might need the actual model number. However, you can go to page 9 on this manual and check if the flashing options can fix the problem. I am assuming you have already tried to turn the power off and back on.
The ohter thing to try is the reset sequence. Within 6-7 secs press High Temp/ Heat Dry/ High Temp/ Heat Dry/ High Temp/ Heat Dry. All lights should light up, press Start button to exit.
Jun 24, 2011 | GE Nautilus 24" Built-in Dishwasher
I have an 11 year old 5.5 excellence top loader by F&P. it won;t continue on with any cycle or programme. it wants to start, but after couple seconds it stops, then it tries again, and then stops,...
Hi just read your posting.When the machine stops and beeps a series of lights will light up on the wash progress line of lights.Starting from left to right which lights are lit when the machine is beeping,is it the 2nd and 6th or the 3rd and 7th etc?Please reply with additional information and I am sure I can help you.Looking forward to your reply.
Jun 19, 2011 | Fisher and Paykel GWL11 Top Load Washer
My 9" Pandigital eReader won't turn back on. The
Plug it back in. Hold the power key and the house key for 5 seconds. It will then come back on.
Feb 19, 2011 | Computers & Internet
Washing Machines Logo
1,365 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
