Question about iLO DVD Recorder DVDR05
Switching on my san0218-250gb
Hi, it will not boot up if that is the correct term. i switch on and all i get is a dvdisc revolving on the screen of tv. i have tried repowering by unplugging unit from wall. sometimes i can use standby up to 4 times and it will eventually run, but tonight i can't get it to boot up.Who can repair as i only just bought unit as new from interstate. and is it an easy repair. hope you can help. regards John
  • dunja2024 Mar 09, 2009
    "HELLO" then turns off again, exactly what I'm seeing.
    So is it as simple as getting a new 250GB drive or do you have to be able to extract data from the original drive?
    Not worried about recorded data, but didn't want to buy a drive if there is OS on the drive.
    Thanks!
    Habit-Forming:
  • 31 Answers
Does the machine display "HELLO" for 30 seconds then power off again?
If so the HDD (Hard Disk Drive) has failed and needs replacing.
Posted on Feb 02, 2009
Where is location of netueal safety switch on 04 century
Here's a link showing where the switch is. Questions Answers for Buick Century neutral safety switch bypass
Mar 14, 2017 | 2004 Buick Century
When i boot my computer on the windows screen it freezes i bought the TP45E combo Biostar motherboard
Try to remove the memory modules. Then try to switch the memory modules' positions in terms of slots. Example, if you have 2 RAM slots, RAM1 goes to RAM2 and vice versa.
May 08, 2010 | Biostar TP45E Combo Motherboard
I press the power switch on my Acer Aspire RC900 and PC shows up on the screen on the harddrive, however the computer won't boot. When I press the power button to turn it off, it won't switch off.
if it wont continue on the booting operation it may be a problem in your memory module.. try cleaning it first... and when you can switch the power on but cant turn it of you should look in the function panel (the pins on yuor mobo where your front panel is connected ) and check if the front panel connection is correct, if its correct your mobo is more likely to be grounded on the casing.
Jul 10, 2009 | Computers & Internet
Light comes on, trun table revolves, does not heat
the magnetron might be defective, also check the door interlock switches, they cause a variety of problems.
Jun 28, 2009 | LG LRM1250 Microwave Oven
Computer not booting
reinstall xp but select repair but if this is a bios prob you must turn off then hold down f12, or f4, or f8 depending on your cpu. hold down till you hear a beep then read screen when u get to boot config dis able hdd and network boot and make sure its boot from c.d. or floppy only. and your back. u must in the future disconnect from the cpu app before you physially pull any plug or unistalls, when you dont it gives the mothers borad a mild stroke type thing or a long term daze or confusion type state.
Mar 15, 2009 | Intel Computers & Internet
TomTom Go 300
boot up failure / switching off part way through the boot up is usually caused by corrupted data or files on your SD card.
When booting up with faulty data the TomTom has 3 options
  1. Continue to boot up and run the errored software
  2. Boot up until a file cannot be correctly loaded then shut down
  3. Try to boot up but if not possible show a RED X on the screen
The other cause for shutting down is a partly charged battery but since you are running off a charger lead this cannot be the case .
So , with the above in mind , its most likely that you have corrupted SD card . The only ways to recover from this is to format and re-install from a backup of the card. OR , it might be possible to overwrite some files or folders from a similar "friends" card in the hope that you overwrite the correct / corrupted file. This is a longshot in the dark but is a possible cure.
Good luck
Mar 08, 2008 | Tomtom GO 300 GPS Receiver
Nad turntable
the belt (aka rubber band) should be changed when it starts to slip
it is not whats causing the table to turn backwards. it's the motor or circut that drives the motor.
Jan 22, 2008 | NAD 533 Turntable
Nokia 7373
try another battery
Sep 05, 2007 | Nokia 7373 Cellular Phone
iLO DVD Recorder DVDR05 Logo
112 people viewed this question
Top iLO Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Jim Goldsmith
Jim Goldsmith
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
