Question about Roadstar CD-258US/512 CD Player
Radio stations Hi, I just bougt Roadstar CD-258US/512 and all seems to work fine exept that when i release the front panel i loose all my radio stations and i have to put them in memory all over agan.
The +12V_Memory (pin 4 on A connector) must be connected to a permanent (not shutoff by ignition key) +12V.
HTH
Posted on Jun 10, 2011
Ca900 radio wont work - the radio lights up as expected but the main area that normally displays what station yo are listening to is blank. No sound comes out except from the beeps when pressing buttons on...
Hello Dan, have you tried to reset the unit using the reset button behind the front panel? also try to clean the panel metal contacts, clean them using a cotton swabs or an handkerchief wet with alcohol, both side (main unit & detachable panel)
Oct 23, 2013 | Car Audio & Video
2007 chevy radio weak signal. Iknow being out of range is not the problem.
it could be a loose antenna is juest come loose from the back of the radio the antenna is for long distant stations
Dec 18, 2012 | Spyder 07-11 CHEVY SILVERADO 1500 PICKUP...
Honda Jazz 2003 1.4i DSI S radio is not working. CD plays fine. Radio stuck on one station and seems frozen. No sound and no way of changing the channel. CD plays fine.
Seem like there is a short in the radio reciever, hence the problem, you could take it your local car udio repair center , or you could upgrade to an aftermarket system which may work out cheaper if your not happy just keeping with the cd.
Aug 10, 2011 | Honda Car Audio & Video
I cannot adjust the stations, switch to CD or Radio mode or anything as it's stuck on one XM station. The presets won't even change the station. I noticed the disp/title button seems to be sort of stuck...
Yes, Disp/Title stuck button could be cause of no other button function because one button can be operated at one time in these units and if any button stuck for some reason, other buttons would be inoperative.
Take off front panel by pressing eject button at lower left side and try to release Disp/Title button with finger nail, if that does not help then remove screws at back of front panel, take off back cover then take out circuit board carefully and press gently, little bit Disp/Title knob from inside front panel to send it back in its original position then put circuit board and put back cover and tight screws.
Check Disp/ Title button gives little click sound while pressing as other buttons give that sound. Put front panel in unit and check.
Hope these info will help you.
Let me know if you have additional question.
Thanks.
Nov 13, 2010 | Alpine CDA-9820XM CD Player
Jammed CD
remove the unit,, and take the top off, inside you will see the sensor that travels along the disc, 3 screws will release this,, and you can remove the disc,,
Aug 02, 2010 | Roadstar CD-258US/512 CD Player
I can t figure out how to connect my radio up like i got the cd player to work just fine but the radio doesn t work
Press the source button to select fm, press and hold BTM button until Btm flashes. This will automatically store stations for you. Page 8 in this users guide covers same as well as manually setting stations. You do have the antena connected?
http://www.docs.sony.com/release/CDXGT20W_200.pdf
Oct 23, 2009 | Sony XPLOD CDX-GT200 CD Player
Cant tune radio
IS YOUR AERIAL CONNECTOR CONNECTED
Apr 05, 2009 | 2004 Ford Focus
2007 Chrysler 300 , AM radio not working , but FM works fine
Usually when you lose only AM it is an antenna issue. Check for a loose antenna plug on the back of the radio or connection to the antenna.
Nov 15, 2008 | JBL - MR4W Am/Fm with CD Player White
Alpine CDA-9820XM CD player trouble
remove the face plate again, in the lower right of the unit there is a tiny reset button (paperclip or pen required) press this button and see what happens this will reset all of your radio stations, audio settings and such, but if it works, may save you a trip to your local repair depot.. if this does not work, you probably need to take it to your local repair depot.. hehe
Aug 15, 2007 | Alpine CDA-9820XM CD Player
Roadstar CD-258US/512 CD Player Logo
104 people viewed this question
Top Roadstar Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Roadstar Car Audio and Video Expert? Answer questions, earn points and help others
