VIDEO/DVD RECORDER I have tried to play a video and also DVD on my machine and nothing is happening. The screen on the TV is also not working through the channel where it was playing. As soon as i press play on the remote control to play the video nothing happens. There is a noise to suggest it is trying to play the video but doesn't. Also i put a DVD in to play and again it says it is playing on the front of the machine but nothing is coming out on the screen. The power is working and there is no video stuck in the machine because i have ejected two of them to make sure that it is not the video itself. Can you help please.
  • GRIMMER Jan 22, 2008
    THE MODEL IS A PANASONIC DVD RECORDER. MODEL NUMBER - EZ47VEB
    Thanks for your comments. However the set up has been working propely recently. So i know that all the connections are OK and the AV in and out is OK.
    Therefore i think it is a question of referring it as your point 8. Can you recommend any body who would come out and look at it first in the home , rather than disconnecting it and taking to a repairer.
    POSTCODE is SG8 AREA.
    Many Thanks.
    Scholar:
  • 64 Answers
Ok here is a small checklist for you before going into panic mode.
  1. Most combo DVD/VID players will have a button on the face of the unit for switching between DVD & VIDEO, ensure this is set for the correct mode of operation.
  2. AV channel on TV's come in several different modes for multi outlets on the TV itself (ie: it may have more then 1 outlet for AV - rear, side & front on some TV's) ensure you have the correct AV channel selected.
  3. Check the connection configuration in your user manual, there may also be incorrect connection to the TV or Unit itself.
  4. The yellow lead usually is the Video lead ( this is for both modes DVD & VIDEO ), this is the one that is most likely incorrectly connected. Double check where it needs to go. The correct lead & socket should also be yellow if this is the case.
  5. AV in and AV out - Make sure you check both on the TV and the unit for the label AV IN and AV OUT, this is the most common connection error, it should be AV OUT from the unit > AV IN on the TV ( mostly the rear connection points will have this as with the ones on the rear of the unit )
  6. One other possible scenario is that you are not using AV leads ( commonly referred to as RCA Leads ) - you may well be using 5.1 connections ( All in one bundle that connects directly to the back of the unit and also the TV. This usually eliminates connection errors as it has several smaller pins in either end that connect at both ends. It is highly unlikely that these are incorrect in any case. This would most likely only be on the incorrect TV channel selection. Ensure you are on the correct one by cycling the channels with the unit playing either DVD or VIDEO.
  7. There can be other scenarios that will make your life difficult, however i feel in the majority of cases, the ones described above are the most common offenders.
  8. Other then this, perhaps consider having the unit checked by a professional ( to ensure it works normally ) this would confirm if either the unit is faulty and needs repair or the connections are incorrect.
Hope some of this helps, as most of these problems can be solved on the spot with a quick visual, however seeing your current setup is not possible and these tips are the most likely to help. Trust you find it's something simple of this nature.
Posted on Jan 22, 2008
My dvd player keeps saying 'incorrect disk' why? and what can i do to stop it?
I don't understand your problem.
Is it the TV or is it the DVD? You say you tried other dvds and the problem is still there. Looks like the TV is the problem. Sometimes it's hard to help people when they only mention on screen issues. How can first DVD say 'incorrect disk' and then another dvd, and another still say 'incorrect disk'? It just doesn't seem to make sense. Is the contents on the disk a computer recorded movie, film or home movie? If so, you have to record the film on the disk with a format that accept the DVD. Could the DVD be a Blu-Ray, can it play a number of video formats, DVD, DivX, KviD DVD, etc.? Try first with a purchased movie DVD disc, if it doesn't work, then the DVD is faulty. DVD players these days are meant to play a wide range of video format, including CD discs. If you have an old DVD player, you may not play latest discs. But if the DVD is incorporated with the TV, then you have to insert a new movie and see if it plays. Go to an appliance or TV DVD store and talk to them. Or you can purchase a new movie and insert it in. If it doesn't work, you can always return it. As you said, you've tried different DVDs, sounds like it is a separate DVD player. If so, try other movie discs. I get the same warning only when I insert discs with movies I recorded on my computer, such as Pinnacle video editor.
Dec 27, 2014 | Digihome LCD TV
Cannot get picture/menu on screen!
The Sony recorder is connected to the TV via the RCA cables (for both audio and video)? How many inputs does your TV have? One cable input and one RCA line in (making a total of two? Did you eliminate the possibility that the recorder might be defective by trying it on another TV?
Dec 25, 2007 | Sony RDR-VX555
How do I get my dvds to play on computor after finalizing disc.
Hello!
1) Are you sute that the DVD are finalized?
2) For me, it works either on tv and on computer. And if your DVD are readable on TV, it prooves the problem is not from your Toshiba DVR620 machine.
3) Maybe a problem on your computer?
A lack of codecs for your video player software ?
Try this for free: a pack of codecs DIVX, and it comes with a free video player and video converter software : http://www.divx.com/en
4) You can try also the video player VLC, it is free, and it reads almost everything! (It's a lot better than Windows Madia Player...)
http://www.videolan.org/vlc/index.html
5) Maybe the problem is in your hardware DVD player ?
If the autorun does not launch automatically, look at this tutorial :
Why does nothing happen when I insert a disc?
http://ask-leo.com/why_does_nothing_happen_when_i_insert_a_disc.html
Hoping these cues can help... ;-)
Jun 16, 2014 | Toshiba DVR620 DVD Recorder/VCR
Green tint on TV screen when playing DVD's or Videos 2nd problem and can't record anything
1: Hi i would recommend trying the recorder on a different tv to check if the problem continues. If the green tint is gone then its the tvs inputs. If it is still green then its the player or the cord. Try a different cord if the green tint is still there then the player has a problem.
2: Now for the VHS to DVD. There are general a lock out encoded on the VHS if it is a store bought movie. This is to protect the content on the VHS from piracy and that would case the DVD to be blank. The VHS to DVD are made for converting your home videos like family vacations and stuff you record your self and not for commercial movies like the ones you bye at the store. If you want to convert old VHS movies to DVD you would have to get another VHS player and another device in between the VHS player and the VHS to DVD recorder.
Mar 19, 2014 | Televison & Video
I have a DVD/VCR recording device and I need to hook up my camcorder to record videos to a DVD to submit to an organization for my son to receive a service dog. I can hook up camcorder straight to TV...
To record to the DVD, connect the A/V cables from the JVC GR-D347U to the A/V In on the DVD recorder. Since the DVD already plays to the TV, you just have to keep the TV set to that input. Put a blank DVD in the recorder. Set the DVD recorder to record on from the appropriate Line In (input) with the DVD as the target recording media. To make sure that all of the devices are on and receiving the output from the camera and DVD recorder, start playback on the GR-D347U and check that it displays on the TV. Forward the tape in the camera to the point where you want to record to the DVD. Stop playback. Press REC for the DVD recorder and restart your playback. Press stop for both the DVD recorder and then the camera when the desired video segment has been played back.
See page 21 of the manual for the GR-D347U. Treat the DVD recorder as a VCR for this situation. The manual is available here: https://www.manualslib.com/manual/82266/Jvc-Gr-D347u.html?page=21#manual .
I hope this helps. Please add a comment with the details of the DVD recorder for more information on connecting the unit in this daisy chain.
(Many recorders have at least two composite video Line In inputs. That's why you need select the correct one for recording.)
May 19, 2017 | JVC GR-D347U Camcorder
I have a 8 mm camera connected to the front inputs I have the Insignia plugged in and av2 mode i have a dvdr in the machine I simply hit the record button and nothing happens? I just want to plug my camera...
can't do it that way. you'll need to plug it in to the tv, play it on the tv, and the video output from the tv to the dvd player. make sure you have the correct format of the dvds for that player. some formats of dvds does not work for certain dvd recorders.
let me know what other issues you have
Oct 18, 2009 | Insignia IS-DVD1001 DVD Recorder/VCR
Programming TV-channels on old Samsung VHS video recorder VB-520T
I tried another position of te range switches and scanned again and again and then I found the tv channels finally.
Mar 25, 2009 | Televison & Video
I HAVE A MAGNAVOX DVD RECORDER MWR10D6 AND I AM TRYING TO RECORD VHS TAPE FROM A VCR TO THE DVD RECORDER. CAN YOU HELP ME WITH THE CORRECT CORRECTIONS; NOTHING IS RECORDING
Play the video on your through your recorder if possible, then record it that way. It works for me. Just go to your watch tv setting and record it off channel three while the vcr plays the video.
Jan 08, 2009 | Philips Magnavox MWR10D6 DVD Recorder
VCR WON'T RECORD
you may have the outputs hooked up correctly however you may need to set the inputs to the selected type of cable you are using. S video 1 cable or video input witch is an rca adapter yellow in color. you will find these setting in the "setup section" on the remote set up button will get you there and then input or source.
Dec 04, 2008 | Philips Magnavox MWR10D6 DVD Recorder
Can't get picture to show up . .
You should be connecting video in of Dvdrecorder to video out of Tv.
Samir
Feb 29, 2008 | Lite On LVW-1105HC DVD Recorder
Televison & Video Logo
125 people viewed this question
Top Televison & Video Experts
