Question about Panasonic KX-TG6053S Phone
Feedback through base unit
I have these 3 phones through the house,when my kids are on the other phones then the base unit starts making noices like it picking up there conversation. Its really annoying if you can possibly help me.Thanks in advance
  • 1 more comment
  • Anonymous Jan 22, 2008
    Its more like static but yeah you can hear there voices in the static. I went in the menu and the speakerphone is turned off cuz thats the 1st thing I thought of
  • Anonymous Jan 23, 2008
    yes there is so I might take it back to the store and exchange it but i do like panasonic also,.so we'll see what happens.
    Thank you
  • Anonymous Apr 06, 2008
    I HAVE THE PANASONIC CORDLESS PHONEMODEL KX-TG6074B AND WHEN I MAKE A CALL OR RECIEVE CALL, I CAN HERE SOUNDS IN THE BASE AS IF THE SPEAKER WAS ON BUT IT'S NOT AND WHEN I HANG UP THE BASE GIVE A POP, THEN TWO MORE POP, WHAT CAN I DO.
    Problem Solver:
  • 4 Answers
If the kids are using the satellite phones that came in the set, then it's possible this would happen because they're all on the same frequency. Maybe you have "speaker phone" turned on. When you say noises, do you mean you hear they're voices?
Posted on Jan 22, 2008
  • Jim Jan 23, 2008
    Sounds a little like a design problem. Cordless phones are not a flwless technology by any stretch of the imagination. I found that usually the more you pay the better the performance.
    If the base unit has it's own seperate volume control you could try turning it down. If the unit is new I would consider returning it and getting a different set. I do like Panasonic. You may just try getting another one like it or switch to a different brand. Is there a help number in your instruction manual?
    Jim
6ya staff
SOURCE:
When I plug the phone line (Comcast is the provider) into my GN Netcom GN7100 Base it "shorts out" (according to the Comcast Tech) the voice modem and so I can't get a dial tone. This makes it impossible...
1. Be sure the jack on the base unit is clean and that the pins inside are straight. 2. If try line another cord - the cord is often the problem due to twisting or crimping. You can test the cord on another phone if you don't have a spare. 3. Make sure the headset is in the off or "on-hook" position. 4. To see if the unit itself is defective try it at a friend's house. Do other phones work OK on that line?
Aug 11, 2010 | GN Netcom GN 7100 Corded Phone (GN7100)
Humming and buzzing
You're getting electrical interference, probably near the base unit since you hear it on all the phones. Try moving the base unit to the other side of the desk (away from say a clock or radio), or check where your phone wire going to the base unit is running. It may be laying on top of an electrical cord or going across some other electrical device that has a motor.
Jun 02, 2009 | Panasonic KX-TG1033S Cordless Phone
Let our Experts solve your "Panasonic tga101cs base will not play back messages The message is recoverable from the 3 hand sets" Problem
I've just got a 2nd system of 3 handsets (KX-TG1033, DECT 6.0). I have also the same sytem in my house. Is it possible to expand 3 new hansets (number 4,5 and 6) to my existing base unit?
Mar 23, 2009 | Panasonic KX-TG1033S Cordless Phone
Panasonic KX-TG6071B - Feedback from base station
-Possibly the hands set is away too far and its base can't communicate.
Good luck & enjoy
Mai
Oct 23, 2017 | Panasonic KX-TG6071M Cordless Phone
Sync a new handset to kx-tg5632 phone
This works on MY panasonic; May work on yours too!
Registering a handset
The included handset and base unit are
preregistered. If for some reason the
handset is not registered to the base
unit, register the handset.
1 Handset:
{MENU} i {0}{0}{1}
2 Base unit:
Press and hold {LOCATOR/
INTERCOM} until the IN USE
indicator flashes.
LAfter the IN USE indicator starts
flashing, the rest of the procedure
must be completed within 1
minute.
3 Handset:
Press {OK}, then wait until a beep
sounds.
4 {OFF}
Registering an additional handset
See page 5 for information on the
available model.
Start from step 2.
Dec 29, 2008 | Panasonic KX-TG5632 Phone
Whole house ringing when cordless phone is used
try deleting all headsets using primary headset (marked with no.1): 4-base/8-deregister/default pin '0000' and register them again using each headset (3-headset/8-register/same pin). it worked for me.
Oct 20, 2008 | Lands Phones
Out of Range
Make certain that the phone line cable is plugged securely into the base unit in the back. Disconnect it and re-insert it into the connector firmly. That should do it if the battery pack has been sufficiently charged.....12-16 hours should do it for the initial charge. Of course, you can't ecxpect it to find the base unit if it is 2 miles away, under a metal box! Just kidding!!
Dec 28, 2007 | GE 28112EE2 Cordless Phone
Md 760 series cordless telephone system
Try unplugging all telephone (including the base unit), then try to call the number again. If there is still a busy signal, then the problem is with your telephone line/connection and you need to call your phone provider. On the other hand if the number rings, then chances are that base unit is defective (or one of your other phones physically connected to the tel line.).
To verify that it is the base unit or one of the other wired telephones,  reconnect them one by one and determine which of them will cause the busy signal. Problems like this can be caused by a power surge, near lightning strike or a simple component failure.
If it is the base unit, it is very likely an electronic problem and therefore would require familiarity with components and circuitry diagnosis, soldering and use of a DVM. Perhaps your best bet would be to seek the services of a qualified phone technician.
Hope this be of some help/idea. Post back how things turned up or should you need additional information.
Good luck and kind regards.
Nov 02, 2007 | Motorola Mobility MD761 Cordless Phone
Lost comunication
I solved this problem with a RESET of the handset. Instructions from the Philips website: Please perform a reset of your device. You will not loose your recorded data (phonebook and personal settings are being kept). 1. Unplug the mains of the base station. 2. Remove one of the batteries of each handset. 3. Put the batteries back in and re-plug the mains of the base station.
Mar 09, 2006 | Xact Communication XG2200 Cordless Phone
Panasonic KX-TG6053S Phone Logo
62 people viewed this question
Top Panasonic Lands Phones Experts
Ekse
martin hogg
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
